Question about Garden
I have a hitachi cordless radio and it's just stoped working with the batteries and the AC cord it just displays "npc" every time i try to turn it on. any one know what the problem could be???
  • howard799
    howard799 Mar 22, 2013
    Same on mine, did you have any luck finding a solution
I also have same problem where my radio is showing npc and does nothing
Posted on May 29, 2013
Radio will not work on battery but battery runs drill.
What is the relationship of the drill, radio, and battery? Is it a rechargeable battery for a cordless drill, or what? You are leaving out a lot a details here. Perhaps the voltage and polarity of the battery is correct for the drill but not the radio.
Jan 23, 2016 | Drills
The display screen is showing the word "SEARCHING" on the screen, can't get the phone to work, cannot pick up an incoming call, the display also displays "HANDSET OUT OF RANGE" WHEN ANY BUTTON IS...
From the Uniden support site.
You can first try a Basic Reset.
A reset is done by following the below steps:
1. Disconnect the battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect battery into handset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base
reference
Mar 13, 2015 | Uniden DECT 6.0 Cordless Phone ID
Hitachi UR18DSL site radio. works when plugged in, but not when fully charged battery inserted
test the battery with multimer for to see is o.k with the voltage. measure. Otherwise you can put the package with plastic bag(windzip) and put by 24 hours in the freezer from your refrigerator for to revival of your battery. and try again in your radio. ( this is smal secret for revival battery rechargeable.
God bless you
Nov 07, 2013 | Tivo DirectTV Remote Remote Control
Works on batteries. does not work on ac. If you leave cord in it and turn off ac it still will not work, but if you take cord out of the unit it will then work on batteries.
If the AC cord can be removed from the back of the radio, then there is a mechanical lever inside where the AC cord plugs into the radio. That lever will cause the battery connection inside to be open (or disconnected) so that it will run off AC and not blow up the batteries. That is why it won't run on batteries when that cord is plugged in.
If it runs on batteries but not AC, find another cord to try. Most radios use about the same cord. If a second cord still doesn't make it work, it's most likely a fuse inside for the AC circuitry. they are usually mounted on a circuit board inside the radio right near where the AC cord plugs into the radio.
You should be able to take the radio apart (while it's unplugged from AC of'course) and find that fuse. If your good with a soldering iron you can replace the fuse. Replacements can be found at Radio Shack. If your reading these instructions to begin with, your probably not good with a soldering iron and you should just buy a new radio. Good luck.
Nov 26, 2009 | Durabrand CD Player with Cassette...
Uniden base display does not work after chargin for 1st time.
Reset Procedure for Cordless Phones
Question:
What is the general reset procedure for cordless phones?
Answer:
1. Disconnect Battery from handset(s)
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances
May 05, 2009 | Uniden DECT 6.0 Cordless Phone ID
After charging a Uniden 2180-2 DECT 6.0, the base stope showing anything on its display. As for the other handset, their display report " searching" since they can' t connect to the base. What is goin
Question:
Answer:
May 05, 2009 | Lands Phones
Can use the phone it is only reading searching on the display.
Question:
Answer:
Apr 07, 2009 | Uniden DECT 6.0 Cordless Phone ID
Cordless or cord saw Comparison
Cordless tools lose power as the battery drains, while corded tools deliver reliable, consistent performance with unlimited run time. Corded reciprocating saws range from less than 5 amps to 15 amps or more, with more than 10 amps providing optimal power for heavy-duty commercial use.
Aug 27, 2008 | Hitachi 11A Motor, Reciprocating Saw,...
Milwaukee Job site radio
Questions:
1. Does the AC cord look ok? Not damaged?
2. Have you tried another AC outlet?
3. Does the AC cord unplug from the radio?
When you operate the radio from the AC power cord, the radio uses an internal power supply consisting of a step-down transformer, rectifier, and filter that converts the AC to DC to operate the radio.
When you run the radio off of batteries, it powers the radio directly. In some radios, when you plug the AC cord into the radio, it activates a switch that disconnects the battery voltage to the radio so that the batteries wont be damaged from the voltage created by the internal supply.
The radio can be powered by either the batteries or the internal supply. You don't want either supply affecting the other, so that is why a switch is sometimes used.
Since the radio works fine off of batteries, that would indicate that there is a problem with the internal power supply. This could be a blown fuse, bad transformer or bad rectifier diode.
Good Luck,
- Jim
Jan 24, 2008 | GE Superadio III AM/FM
Cordless phone 25881
Sounds like a power problem.
This model of phone will work as a regular corded phone when no ac power is available.
IE the cordless function is only available when you have electricity.
- is the ac adapter plugged into a working outlet.
- is the ac adapter working.
- is the ac adapter pluged into the base.
hope this helps
Nov 30, 2007 | GE 25881EE3 Phone
Garden Logo
234 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
