After inserting the xp cd. it goes for few step then blur dump error message comes. kindly suggest ho to install xp .
    Problem Solver:
  • 11 Answers
I suggest that you try to clean the disc first (please see http://www.ehow.com/video_2499_clean-cds.html OR you can also use detergent to clean the disc) and if this doesn't helps try another disc.
To install the Windows XP it's simple, just follow the steps. In case of doubt, please see http://www.buildeasypc.com/sw/windows_xp.htm.
Posted on Mar 22, 2011
How to fix when got error message says Could not start because "windows root\system32\ntoskrnl.exe" pls re install...
do these steps:
1- Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
2- Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
3- In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
4- Select the operating system you wish to fix, and then enter the administrator password.
5- Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
6- You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
7- Type exit to reboot the computer.
Jan 15, 2011 | Twinhead N23PB PC Notebook
Error message at start up. Running windows xp. HP Pavilion a700N PC desktop. The message is: This application has failed to start because hpzjrd01.dllwas not found. re-installing the applicationmay fix...
To fix hpzjrd01.dll errors occurring due to corrupt or incomplete installation of HP printer software, uninstall your printer driver and reinstall it again.
To ensure the HP printer software is completely uninstalled from your system, we recommend you either use the built-in Add or Remove Programs utility or use the help of a third-party uninstaller, such as Perfect Uninstaller.
for more information and help click here hope this helps you.
Thanks
Michel
Dec 18, 2010 | HP Pavilion A700N (PJ516AA) PC Desktop
Hello, Whenever I boot up my machine I get an error message saying new hardware found - base system device. It then doesn't find any software to instal and goes away after a few clicks. However, I have...
Hello Dear,
I would suggest to use the Chipset Drivers CD to install all the drivers. I hope you would be having the CD which comes with the Laptop.
WIth regards
FIXYA team
Oct 09, 2010 | Dell Inspiron 6400 Notebook
I have just installed a new hard disc in my samsung x05 but keep getting an error message coming up saying windows (xp) has been shut down etc then kernel_data_inpage_error, followed by atapi.sys - address...
Well if it does that you should make sure all media is unplugged from the computer. If you have the Windows XP Original Release disk insert it and re-install Windows XP. If still says the same error "operating system not found" take it to a computer specialist near you or go on another computer and contact www.microsoft.com, thats all I can say.
Apr 07, 2010 | Samsung X05 Notebook
Ntoskrnl.exe is missing or corrupt solution
Issue:NTOSKRNL.EXE is missing or corrupt.
Related errors:
Below is a listing of the full error message that may be related to this error.
Windows NT could not start because the below file is missing or corrupt:
C:\Winnt\System32\Ntoskrnl.exe
Cause:
  1. Keyboard issue
  2. Miscellaneous corruption
  3. Corrupt boot.ini file.
  4. Missing boot.ini file.
  5. Missing or corrupt ntoskrnl.exe file.
  6. Windows NT installed on a partition bigger then 7.8GB
  7. Corrupted hard disk drive or severely corrupted Windows.
Solution:Keyboard issue
This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer.
Make sure the line pointing to the operating system and its drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
Microsoft Windows XP users:
If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648.
Microsoft Windows NT and Windows 2000 users:
To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
  1. Boot the computer with your Windows NT three setup diskettes or the Windows 2000 setup disc.
  2. In the setup menu, type R to start the repair.
  3. When prompted for the ERD diskette insert the diskette and inspect the startup environment.
If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
  1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
  2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
  3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
  4. Select the operating system you wish to fix, and then enter the administrator password.
  5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
  6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
  7. Type exit to reboot the computer.
If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the error message as shown below.
OS Loader v4.01
Disk I/O error status=00000001
Windows NT could not start because the below file is missing or corrupt: winnt\system32\Ntoskrnl.exe
Please reinstall a copy of the above file.
If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Attempt to check the hard disk drive for any errors by running the chkdsk program. To do this follow the below steps.
  5. Once at the recovery console type chkdsk /r
  6. Once completed type exit and see if issue is resolved.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186.
Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
Oct 01, 2009 | Microsoft Windows XP Professional
MS Office 2007 Professional won't install on my Laptop with XP
yor ms office 2007 cd or dump is corrupt pls try another one
Jun 24, 2009 | Microsoft Office Publisher 2007 for PC
Internet explorer will not allow to go to secure settings
Cause:
  1. Keyboard issue
Solutions
Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration.(this can be done by tapping the F8 key while booting and selecting last known good configuration)
  1. Insert the Microsoft Windows XP CD into the computer. Note: If you have a system recovery CD or restore CD (not a Microsoft CD) these steps will likely not work for your computer.
  2. Reboot the computer with the CD and press any key when prompted to press any key to boot from the CD.
  3. Once in the Microsoft Setup menu press R to open the recovery console.
  4. Select the operating system you wish to use; if you only have Windows XP on the computer you will only have one prompt.
  5. Once prompted for the password enter the Admin password and press enter.
  6. Once at the command prompt type bootcfg /rebuild to start the rebuild process.
  7. The rebuild process will step you through a number of steps depending upon how many operating systems you have on the computer and how the computer is setup. Below is a listing of the common steps you are likely going to encounter.
    * Prompt for the identified versions of Windows installed. When you receive this prompt press Y if the bootcfg command properly identified each of the Windows operating systems installed on the computer. It is important to realize this command will only detect Windows XP, Windows 2000, and Windows NT installations.
    * Prompt to enter the load identifier. This is the name of the operating system for the boot.ini. For example, Microsoft Windows XP Home users would enter "Microsoft Windows XP Home edition".
    * Prompt to Enter OS load options. When this prompt is received type /fastdetect to automatically detect the available options.
  8. Once you have completed all the available options in the rebuild and are back at the prompt type exit to reboot the computer.
Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
Jun 04, 2009 | Gateway GT5656 Desktop PC
Audio Problem
http://intel.driversdown.com/Intel-drivers/Intel-Desktop-Board-D945GCNL-HD-Audio-Controller-5605-Windows-Vista(32-64)-XP(32-64)-2000_77686.shtml
Intel Desktop Board D945GCNL HD Audio Controller 5605 Windows Vista(32/64)/XP(32/64)/2000
Installs the Realtek audio driver version 5605 for Intel® Desktop Boards.
IMPORTANT: Audio drivers may fail to install in Windows* XP 64-Bit Edition. Symptoms may include error messages, such as "Error in installation" or "Unknown error". Microsoft's Update for Windows XP x64 Edition (KB901105) fixes this issue. After installing this update, the audio drivers for Windows XP 64-Bit Edition will successfully install.
Apr 23, 2009 | Intel D945GCL Motherboard
FATAL ERROR MESSAGE/DELL OPTIPLEX GX150 DESKTOP/WINDOWS XP PRO
I have experienced this problem as well, it is either the CD is scratch or the CD-rom lens needs cleaning, however it can read the content of the CD, I would susgest you try a another CD-rom , borrow it from a friend. It works for me.
Nov 06, 2008 | Dell OptiPlex GX150 SF PC Desktop
Installation
insert xp bootable cd
hit delete or F2 to enter setup while starting computer
select boot priority or first boot device as "cd rom"
exit saving changes.
boot only 1 time from cd and then follow the installation wizard steps.
Nov 16, 2007 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
