Question about LG Heating & Cooling
LG split system air con unit. Model LS-H246TNB0. Turns on and blows air but not cold can feel the air being blown through whilst stood underneath unit, does not cool room efficiently. Filters have been cleaned with no effect?
  • 234 Answers
SOURCE: split ac not cooling
I would check the drain to see if it is stop up.Next check to see if the unit inside is freezing up.If it is check to see if fan is running and if fan is running the you proable have a freon leak. Low charge on freon will make it freeze up and the fan not running also.
Posted on Apr 07, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: we have a fujitsu air
Sounds like you have it in heating mode or it is low on charge. In cooling mode, the outside fan should blow hot air not cold.
Posted on Jul 31, 2008
  • 400 Answers
SOURCE: LG Room Air Conditioner Model
I would say that your return air sensor is faulty or not positioned correctly. Check sensor
Posted on Mar 05, 2009
  • 400 Answers
SOURCE: RECOMEDENT SIZE OF ROOM TO USE SPLIT UNITS FROM 12000BTU TO 24000
650btu/square meter
Posted on Mar 25, 2009
  • 400 Answers
SOURCE: Will Not Heat
On the outdoor unit the fan should not be running, on the indoor unit the fan should be running. If you then check the outdoor unit with fan not running, you should be able to hear clearly that the compressor is actually working. If this is all correct, it is possible that your fourway reverse valve is seeping and needs to be replaced.
Posted on Apr 15, 2009
Air-Con Mini split --gives error code 4 shuts down after 25 minutes
Hi Emanuel,
Your out door unit could be very dirty or the outdoor unit temperature sensor is out of position.
May 04, 2014 | LG LS-K1830CL Cool Mini Split Air...
We have LG air con system (hot and cold) coming up with error code CH33. What does this mean?
CH 33 -Excessive rise of standard compressor discharge temperature. If over 105°C check refrigerant charge. Over charged, release little gas still to normal PSI. If condenser full of debris, clean it.
Dec 18, 2010 | LG LS-L1210CL Mini Split Air Conditioner
I have a split system model ls-k2464hl the remote works but will not turn on the unit.The unit will force run but only in cold
It sound like a defective receiver pcb. Have this professionally checked. I take the time to help, so please rate me!
Jun 15, 2010 | LG LS-K2430HL Heat Cool Mini Split Air...
Cant turn air con of with control
if the remote is lg it haven't code the eye of the plate has burned
Feb 21, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Heating & Cooling Logo
216 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
