Question about Maytag Dryers
How do I replace the belt on my old maytag dryer?
    President:
  • 2,468 Answers
Remove 2 screws from front panel near floor,then swing panel upward toward you and remove,then remove drum support screws around the front door and then you can slip belt around drum and reverse assembly,its very tight getting the belt around the idler and motor pulleys,but its possible going in around the blower case with both hands one on each side
Posted on Mar 22, 2011
Replace belts on dryer?
I presume you are in the US
Maytag produce their machines under various names.
Parts can be obtained from
http://www.maytagpartsonline.com/
On most washing machines and dryers you take the back panel off.
loosen the motor retainers and remove the old belt.
Fit the new belt and adjust the tension with the motor retainers and retighten. You normally have about 1/2 inch slack in middle of belt.
Good luck
Chris UK
Jul 09, 2014 | Maytag MDE9316 Dryer
Trying to replace the dryer belt forgot how the old one came off b/c it broke. not sure how to get it back on to the pullys. maytag dryer model de7600.
This link is a listing of diagrams of belt configuration on various brand dryers the diagram for how the belt goes on the motor/idler pulley on the Maytag brand is going to be diagram E
http://www.repairclinic.com/Dryer-Belt-Diagrams#DiagramE
GENE
Aug 31, 2011 | Maytag Dryers
Maytag Neptune MDE3000 electric dryer replacement of belt
The top comes off then the front panel is next.
remove the drum by pulling it out to replace the belt. replace the tensioners pully as well for it has a bearing that wears out then squeals loadly when old and dried up
Mar 27, 2010 | Maytag Neptune MDE4000 Electric Dryer
Changing dryer belt on maytag performa
Here is a link for both old-style and new-style Maytags.
At the top of the page you'll see the word "here" -- click on the appropriate one to get the belt-change procedure.
Charlie
http://www.applianceaid.com/maytag-dryers.html#belt
Aug 31, 2009 | Maytag Dryers
Maytag dyer was squealing now smells like burnt rubber
Sounds like you may have a belt slipping.Take the back off &see what the belt looks like.
Aug 28, 2009 | Whirlpool LER4634J Electric Dryer
Replace dryer belt
Pull the front panel off, remove the top screws and tilt top back. Rout the new belt around drum at the old wear spot with the grooved side against the drum. Next remove the back access door and rout the belt around the idler pulley and motor pulley. There is only one way to do this and get proper tension on the belt.
Also, when you order the belt, ask if it has a belt routing diagram on the belt package.
Apr 07, 2009 | Maytag PYE2300AY Electric Dryer
Need routing diagram of dryer belt on maytag dryer D7600
Go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the following page, locate the "Dryer Belt Diagrams" link under the "Special Features" section. Scroll down to Maytag. The dryer belt diagram for Maytag should be listed as diagram E. I hope this helps you.
Jan 28, 2009 | Maytag PYE2300AY Electric Dryer
Needing 15-20 year old apartment sized dryer belt.
go to a Maytag service agent
even the unit is old , there is a good possibility that the belt is still in use or was discontinue recently and they may have spares
Aug 19, 2017 | Zanussi TC180W Electric Portable Dryer
Dryer
there iws another pully with a spring to rap the belt around neer the motor.this pully puts pressure on the belt.
Aug 19, 2008 | Maytag Dryers
Maytag elc dryer
Your drive belt is old and has glazed. It will likely break soon. Replace it. Make sure the belt contact area is clean and free of any kind of dirt or grease.
Dec 05, 2007 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
59 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
