Question about Video Game Consoles & Games
I need help with wii usb loader error wbfs_open failed:-1 and how to fix it
My front loader washer is having the error code od and will not start. What does this mean and how can I fix this?
OD: Opened Door not sensed by machine control board. in this case the lid switch needs attention. or washer door. hope this helps ! 1.Make sure door is closed. Check for loose wire connections at switch and/ or machine control board. .Check for failed door monitor switch. good-day !
Nov 14, 2011 | Maytag Neptune MAH5500B Front Load Washer
It doesn't recognize the wii fit plus disc it tells me to insert disc
Are you inserting the disc properly? And when is the last time you ran a laser lens cleaner through your Wii system. Dust and contaminants can cause disc read errors.
Oct 28, 2010 | Nintendo Wii Fit for Wii
My wii is semi-bricked?
Wat is your wii version On YouTube type in homebrew channel thn your wii version there should be som links in the descriptions download them the put the file boot.elf or boot.dol and private then put in your wii if you have version 4.0 or higher click the blue ad card at the bottem of your screen it will load up thn run then install homebrew channel and DVD x leave boot mii alone click exit put your sd carad back in your computer and create a folder called apps then go to wiibrew.org and serch homebrew browser downlad it and put it in the apps folder then put back in your wii and load up homebrew channel and there your done Hope this helps Bye
Jul 09, 2010 | Nintendo Wii Console
Wii error code 86420
Error Code: 86420 This error occurs when there is a communication problem between players during online gameplay.
Try this:
  1. If your router's security software (firewall) is turned on, it may block communication that is required for online gameplay. To fix this, try disabling the router's firewall*.
    1. Most firewall settings are located under the "Advanced" or "Security" tab.
  2. If the problem still persists with the firewall off, you may need to open ports on your router through the Port Forwarding feature.
    1. Create a manual connection on your Wii and assign a static IP Address.
    2. Open ports 1 through 65535 as both TCP and UDP.
    3. Ensure the ports are forwarded to the same IP Address given to the Wii during the manual setup.
Trouble connecting to a friend?
If the above steps have not resolved the issue and you are trying to connect with specific friends, the problem could potentially be an issue on your friend's network. Your friend will have to perform these troubleshooting steps with their home network.
Using USB Connector or Lan Adapter? Please call 1-800-255-3700 so that we can assist you further.
*While Nintendo provides this information for our consumers' use, it is up to each consumer to determine what security needs they have for their own networks, and to decide how best to configure their network settings to meet those needs.
Apr 13, 2010 | Nintendo Wii Console
My blackberry 7290 gives error 507 with a circle at the top
You will receive the following Java error 507 message on your BlackBerry smartphone while using the application loader tool to install or upgrade the BlackBerry Device Software.
Cause 1:
This might occurs while using the application loader tool to install BlackBerry Device Software, existing applications on the BlackBerry smartphone are erased, and new applications are not loaded.
To resolve this error you need to complete the following steps:
  1. Verify that you have the BlackBerry Device Software installed on your computer.
  2. If your BlackBerry smartphone is connected to a laptop computer in a docking station, disconnect the laptop computer from the docking station and connect the BlackBerry smartphone directly to the laptop computer.
  3. If a third-party program, such as a virus scanner, is using the same communications port (COM port) as BlackBerry® Desktop Manager, close the third-party program to free the COM port for use.
  4. If you are using a USB adapter to connect your BlackBerry smartphone to a serial port on your computer, temporarily connect your BlackBerry smartphone to a computer with a USB port.
  5. Open BlackBerry Desktop Manager and double-click the Application Loader icon.
  6. Use the application loader tool to install the BlackBerry Device Software.
Cause 2
This might occurs while all data and applications are removed when an incorrect password is typed ten times into the BlackBerry smartphone.
  1. Open BlackBerry Desktop Manager and double-click the Application Loader icon.
  2. Use the application loader tool to install the BlackBerry Device Software.
Cause 3:
This might occurs while the Power Management feature on the computer turns off the USB ports.
  1. On your computer, click Start > Settings > Control Panel.
  2. In the Control Panel, double-click the System icon. The System Properties window opens.
  3. Click the Hardware tab of the System Properties, and click Device Manager.
  4. In the Device Manager, double-click Universal Serial Bus Controllers.
  5. Right-click the first USB root hub, and click Properties.
  6. In the Properties window, click the Power Management tab.
  7. Clear the Allow the computer to turn off this device to save power check box.
  8. Repeat steps 5 to 7 for all other USB root hubs.
  9. Restart your computer.
Cause 4:
This might occurs while the BlackBerry smartphone is connected to a laptop computer using a docking station.
  1. Disconnect the docking station from the laptop computer and connect the BlackBerry smartphone directly to the laptop computer using a USB cable.
  2. Re-install the BlackBerry Device Software using the application loader tool.
I Hope it helped you.
Thank you for using ' Fixya ' and have a nice day!!
Oct 21, 2009 | RIM BlackBerry 7290
I put a game into the wii (blank screen)
it will be a recent game your trying to load probabaly with an out of date loader. newer games have something called an .002 problem where they can just crash due to disk errors.
install an up to date loader such as gamma loader and in config you can turn on "002 fix" and it will run.
it did it on mine with the new EA fitness game, and the above sorted it. mines softmodded running 3.2E
Mar 14, 2009 | Nintendo Wii Console
Wii console won't read disc
wash disc with 1 drop dawn rince pat dry
Feb 17, 2009 | Nintendo Wii Console
Wii loader problem
have you tried to unplug it then plug it back in? cuz it might not be able to get fixed.
Apr 28, 2008 | Nintendo Wii Console
Unable to read wii discs
I had the same problem, I take it you have a modded wii(chipped), if you use a backup disc it is of a lower quality then original discs, the wii gets read errors without you noticing and tries to read those disc areas again sometimes suceeding and the gaming goes on, sometimes it fails, and a disc read error occurs. Over time the dvd assembly will take some damage it will loose it rigidity it once had and the wii stops reading discs. The problem gets worse if you have standing up, so first thing si to flip it down and try. Otherwise you (or someone you trust) will have to open the wii and adjust the lens sled so it wont flap as much up and down. Hope this helps..
Oct 01, 2007 | Nintendo Wii Console
Video Game Consoles & Games Logo
155 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
