Toshiba 50a9ua does not turn on. I checked teh fuse and it is o.k.
  • Anonymous Aug 04, 2008
    Hi I have a toshiba rear projection TV 50a9uo it jsut stopped turning on, I checked the fuse and it is o.k. not sure where to start.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
If fuse ok call repair.
Posted on Aug 03, 2008
Where is the thermal fuse located on a 110.67032600 kenmore elite oasis dryer
If you are talking about Thermal Switches that turn on and off to regulate the Heating Element, They are in the back of teh machine one is close to teh heating Element and teh other is close to the Exhaust
as the Heating
Aug 29, 2014 | Dryers
How do I turn the rotary cutter on and off our toshiba SX4 thermal printer running windows
You can juste select the option in teh windows driver.
Select batch printing and no cutter when you don't want to cut.
Nov 18, 2013 | Toshiba TEC B-SX4 Thermal Label Printer
Toshiba Tecra A8-S8414 keyboard
I'm not sure if it is worth ..but you can get a new keyboard and change it ..To change the keyboard you have to remove teh hinges cover ..remove the screws and slide the keyboard one inch toward teh display ..and lift it up ..pay attention cause it has a ribbon attached on the motherboard and it is sensible
http://www.uspcparts.com/toshiba-tecra-a8s8414-keyboard-p-9904.html
Dec 22, 2011 | Toshiba Tecra A8-S8414 Notebook
Hi i have a toshiba satellite TE2000 and cant seem to get the wifi working and put teh wifi switch on but still not working any ideas
Check the wireless card in the device manager and see if ti has teh driver ..If under network it appears in yellow with a ask sign on it .. this means it is not installed and you need the driver for it .Install the driver from the disk of drivers..or from the support site if you do not have a disk ..
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Download&sn=false
select the model and the operation system .
download and install ..reboot and after that try to engage the wireless again (enable it from button )
Aug 05, 2011 | Toshiba Satellite A105 Notebook
Front blower motor will not work in 1994 f 350 van all fuses are good no power anywhere (at switch, resistor, or blower motor in any position
check the 50 amp fuse in teh engine compartment fuse/realy box. Also check the blower motor relay that the fuse protects.
Alos, check fuse 9, 15 amp in fuse panel in truck.
Test by applying 12 volts to teh orange/red wire at teh blower motor connector. Use a 10 or 12 gauge wire with a 25 or 30 amp fuse in line.
report back
Jan 11, 2011 | 2002 Ford E350
Water leaks in on the front passenger side when the air is used
check the valve that is near teh condencer on under the hood its a drainage valve that just sits there if the end is fused shut for some reason teh condensation backs up in to the car cuasing teh water to come from under teh dash
Aug 08, 2010 | 2004 Chevrolet TrailBlazer
Error code H4-00 and machine is "locked-up" in scan mode
H4 is a fuser error. It needs to be replaced by a tech. Sometimes they can reset this error in service program.
Apr 24, 2009 | Toshiba E-Studio 3511 Color Copier
Screen shuts off
my screen will turn on right after unit is plugged in and stay on for a short period of time, then it shuts off and the red light near the power button blinks and teh tv will not turn back on. there might be problem of loose contact in power supply Thanks
Sep 11, 2007 | Toshiba 32AFX61 32" TV
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
