Question about Acer Computers & Internet
My computer screens suddenly increases its brightness then goes back to the costumed brightness that I set. How can I stop this? Is there something wrong with my computer or what?
3 Suggested Answers
Pyrhyc
  • 2028 Answers
SOURCE: xps screen brightness low
Press F2 at start up to go into the bios. There is another setting in the bios for the screen brightness while on battery power.
Posted on Jul 15, 2008
  • 76 Answers
SOURCE: Replaced Laptop Screen Brightness Problems.
hi
-try updating the system BIOS of the computer
-visit support.dell.com
-click on drivers and downloads
-click or choose by service tag
-download the BIOS and install it on the computer
cheers!
Posted on Oct 04, 2009
How do i increase the screen brightness HP elitebook 8530p
Sounds like your keybinding/hotkey combo is not doing its job. (or your bulb in the display is going out)
You can open up Control Panel and adjust brightness from there.
Step 1 Click "Start ' Control Panel ' Hardware and Sound ' Power Options" to open the Power Options window.
Step 2 Click and drag the bottom "Screen Brightness" slider to the right to increase screen brightness and to the left to decrease it. Making this adjustment changes the brightness level only for the current power source; if you change power sources, the screen brightness may change again.
Step 3 Click "Change Plan Settings" on whichever power plan is currently selected.
Step 4 Click and drag the "Adjust Plan Brightness" slider to the right to increase brightness for each of the power sources, such as "On Battery" or "Plugged In." If you want high-precision numeric control, you need to access the advanced settings.
Step 5 Click "Change Advanced Power Settings."
Step 6 Click "+" next to "Display" and then "Display Brightness" to expand these options.
Step 7 Click "On Battery" and enter a percentage in the field provided. Choosing "100" will set the screen to maximum brightness; any other brightness will be a percentage of the maximum brightness. To increase the brightness, make sure the number you enter is higher than the current value.
Step 8 Click "Plugged In" and set its brightness percentage.
Step 9 Click "Apply" and then "OK" to close the Advanced Settings window.
Step 10 Click "Save Changes" to save any changes you made on the Edit Plan Settings page. If you only make changes in the Advanced Settings page, the Save Changes button will be grayed out. If that's the case, just click "Cancel."
Hope this helps!
Apr 28, 2014 | HP EliteBook 8530p Notebook
The screen is really dark
Locate the Fn (Function) key on your keyboard. It may be on the bottom left side with dark blue letters. Locate the two "brightness" keys near the top of the keyboard. These will be in the "F" keys, possibly if F6 and F7. They should have little sun pictures or something similar to indicate brightness. Hold down the Fn key while pressing F7, or whichever "F" key your laptop uses to increase brightness. Tap F7 repeatedly until you reach the desired brightness. Fn must be held down as you continue to tap. Hope this helps.
Dec 07, 2012 | Intel EasyNote E4 715 Notebook
Just got the phone today, it was acting fine until I disconnected the charger. Now the back light goes out after a couple seconds every time I try to use it. The light comes back on when I press the...
Try changing your display time out to something longer. Select menu-> settings-> display -> screen timeout -> pick something longer.
You can also set your brightness to not automatic. Within the same display menu, select brightness and uncheck the automatic brightness box. See if that works.
Lewis
May 15, 2011 | Motorola Mobility CITRUS Smartphone
I have one pro view 17" view sonic monitor CRT with win xp as my OS. when i am working in my computer suddenly the contrast and brightness symbol comes on the screen and begin to increase to maximum...
buttons are not working perfect.therefore pressing automatically. you have to remove the panel after power on the monitor, (it may be dangers therefore get support by electronic technician , he will remove buttons and solder new ones or replace the switch panel.
Jan 18, 2011 | ViewSonic E70fb 17" CRT Monitor
I have an acer aspire 5315 and the screen goes black I have tried to go into set up and I have taken out bateries etc but it's still not working . Any help is greatly appreciated thanks
Hello mariawint589,
The following instructions are from the Acer Aspire 5315 user's guide (page 35):
The computer's power management system automatically blanks the screen to save power. Press any key to turn the display back on, three hings might be the cause:
*The brightness level might be too low. Press <Fn>+<right-arrow key> (Increase) to adjust the brightness level.
*The display device might be set to an external monitor. Press the display toggle hotkey <Fn>+<F5> to toggle the display back to the computer
*If the sleep indicator is lit, the computer is in sleep mode. Press and release the power button to resume.
If this solution is helpful please click a thumbs-up rating.
Have a great day,
martyshaw152
Nov 12, 2010 | Acer Aspire 5315 Notebook
hi
cheers!
Sep 14, 2009 | Dell Inspiron E1405 Notebook
When HP laptop is pluged into power source screen goes dim
Right click on the battery icon in the taskbar, go to Power Options or something similiar. Change the plan settings for the power plan you're currently in. Check the brightness ratio for both battery and plugged in mode. This problem might come if you or someone had tinkered with the settings.
Jun 20, 2009 | HP Pavilion dv6000z Notebook
Xps screen brightness low
Jul 14, 2008 | Dell XPS M1530 Laptop
Serious problem
Check WGA if it is correctlly put on and go to DISPLAY PROPERTIES - SETTINGS - ADVANCED -MONITOR
Oct 15, 2007 | LG Studioworks 700S 17" CRT Monitor
Computers & Internet Logo
168 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
