Question about Toshiba 50H82 50" Rear Projection Television
Toshiba 50H82 Rear Projection TV Auto Focus Error
I have a Toshiba 50H82 HDTV rear projection, with what looks like a convergence problem, but only the green gun and only in the vertical! tried the Touch Focus, and I get a red message on screen that says "Touch Focus Error", the picture is still displayed with a skew on the green color, almost looks like a 3D picture without the funky glasses to make it better! Any help in appreciated, I have a electronics background (not television though) so any technical work I could manage.
Thanks
M
  • joevito Sep 21, 2008
    YES,I THINK I HAVE THE SAME PROBLEM,WHEN I PRESS TOUCH FOCUS,BOTH SETS GREEN LINES ARE MOVING AND AND OK,THE SAME WITH THE RED LINES,ALL OK.BUT WHEN THE BLUE LINES COME ON,THE FIRST SET SEEM OK BUT THE SECOND SET ARE STILL AND THE TOP AND BOTTOM BLUE LINE ARE CURVED!!!! CONVERGENCE PROBLEM? I CAN GET A CONVERGENCE BOARD,# PD1731A-1 - 23599979!!!! AND A COMPLETE BLUE CRT WITH ALL THE CIRCUT BOARDS,#PD1733A & 23599981B,, TYPE P16MAD00BMB {CRT} �{CRT}!!!!! CAN YOU TELL WHAT PART I NEED TO FIX IT!!!! THANKS JOE PIRELLI
  • 1694 Answers
SOURCE: Touch Focus Error
Even if the pix appears to be "OK", the internal convergence
alignment (in servicer mode) must be accurate within certain
parameters for the Touch Focus function to complete w/o error.
Adjustments should be done in "Full" mode,both HD & regular
signal.
Posted on Oct 13, 2007
  • 1694 Answers
SOURCE: Toshiba 42H81 Rear projection "Convergence problem"
Also,check micro fuses F851,F852,etc.
and with a good digital meter, check resistors feeding B+ to
convergence circuit.
I have been using Stk392-110T made by Toshiba with no re-calls.Hitachi also has an upgrade IC.
And be sure to check your soldering of IC pins--good connect,
with no short.....T.
Posted on Oct 25, 2007
  • 5 Answers
SOURCE: TOSHIBA REAR PROJECTION TV 42H81
you have a convergence problem that will require the replacement of the convergence amp ics.
Posted on Nov 29, 2007
  • 4234 Answers
SOURCE: hitachi ultrascan HD pic looks like a 3D movie w/o the glasses
You have a problem with teh convergence circuits. This can be caused either by defective convegence ICs or even bad connections at the pins of these ICs. I would first resolder the pins on the ICs. If that fails, replace them. That should resolve the problem. These ICs are large and black, attached to a heatsink and are marked STKxxx. There should be 2 of them.
Dan
Posted on Apr 03, 2008
  • 1030 Answers
SOURCE: RCA 52inch Model R52WH77 HDTV
may i suggest reading the ariticle the fl231 problem in my tips and tricks section of my profile. YOu MAY have a 5 dollars 30 minuter fix. Determine if you have the convergence option under the setup option of the customer menu. if you dont then congratulations you have a simple fix. i you do have the convergence option and the autoconvergence then you might have other problems. and will have to troubleshoot further. If so ill talk you through some more. THIS set has NO stk convergence ics. my feeling is the fl231 which i see alot on this perticlar model at the shop
Posted on Oct 08, 2008
Shows a red scream
try the auto focus if shows error then try to do it manually in convergence and make sure you align all colors. If still doesn't work, then you will have to have the convergencs chips replaced.. Approximately $250 repair cost..
Mar 07, 2010 | Toshiba 50H82 50" Rear Projection...
How do I know I need a new projection lamp? My tv
This set does not have a lamp. It has 3 crt tubes that converge to create a color picture. The convergance is off a little causeing this affect. Go into the menu and look for convergence or magic focus. You can download the owners manual from Toshiba website to do this. You will need the remote that came with the set.
Nov 30, 2009 | Toshiba 50H82 50" Rear Projection...
What do convergence chips look like
This is what a convergence IC looks like.
Oct 19, 2009 | Toshiba 50H82 50" Rear Projection...
3 d images on toshiba 50hd82
This is a convergence issue, the stk392 ic's have failed on the convergence board, if you want to tackle this issue your self you will need soldering skills and a dvm. This is a common issue with all projection tv's.
Sep 01, 2009 | Toshiba 50H82 50" Rear Projection...
Toshiba 50H82 rear projection TV adjustment
The ser needs to be converged in the factory service mode
Jan 14, 2009 | Toshiba 50H82 50" Rear Projection...
Toshiba 50h82 convergence issue
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 11, 2008 | Toshiba 50H82 50" Rear Projection...
Convvergence problem w/ Toshiba 50H82
You need to replace following ICs, may be 2 pieces in your tv for convergence problem.
IC, STK392-110T
Toshiba Part Number: 23135090X
Please search on net for availability in part stores
Sep 27, 2008 | Toshiba 50H82 50" Rear Projection...
Nov 29, 2007 | Toshiba 51H83 51" Rear Projection...
Toshiba 50H82 50" Rear Projection Television Logo
471 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
