Question about Sony SDM-HS75/B 17" LCD Monitor
Hey, i have this sony tft lcd color computer display (SDM-HS 75). It was working fine earlier. I shifted to a new place and reconnected the monitor with the system. But now while booting and error message is being displayed " Information - Out of range 66.8 Khz / 85 Hz". However the system is starting in safe mode. I have tried all I could, but still no success. Please help!.
  • 11,361 Answers
It is telling you that the PC videocard resolution is too high, when you boot up insfae mode, the resolution is lower. Does it do the same when attched to another PC? You should set the resolution to the native resolution of the monitor.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Mar 22, 2011
No display on monitor
There are a number of possible reasons after checking what you have so far. Have you checked that the video card has not been disturbed inside the computer?.
Try starting your computer in safe mode, see link below. Just in case you have a driver problem.
http://windows.microsoft.com/en-gb/windows/start-computer-safe-mode#start-computer-safe-mode=windows-7
Dec 21, 2013 | Sony 15 Inch Tft Lcd Color Computer...
Power supply sony monitor SDM-S204
TRY WITH A OTHER MONITOR ARE THAT OKEY YOUR MONITOR ARE PROBERLY BROOKEN.
ARE THE OTHER MONITOR ALSO BLACK YOUR VIDEOCARD ARE PROBERLY BROOKEN.
ALL CABELS SHOULD ALLWAYS BE SEATED TIGHT.
Jun 07, 2013 | Sony Sdm-s204 20.1" Tft Lcd Color Desktop...
No picture Display when turned on lots of Colour lines, could this be the inverter board problem. the model is Sony TFT LCD Color Computer Display SDM-X72 Serial Number 4530624 Manufactured April...
This is not an inverter problem. The inverter only powers the fluorescent lamps in the back of the LCD panel.
It is probably a fault in the LCD data decoder circuit or a failing connector between the decoder circuit board and the glass LCD panel. If you took it in to a shop, they would probably charge you a full hour's labor minimum - compare that with the price of a new LCD monitor.
Dec 14, 2010 | Sony SDM-HS73P 17" LCD Monitor
My SOny SDM-S204 has no green in the computer display however, the monitor menu window is the correct color
Hello amellows, hi, check the video cable for loose connection, tighten the vga plug screw, try to wiggle the vga plug and see if there are changes on the display. As for the monitor menu, this is usually not affected, the colors are built in its onboard memory.
Mar 31, 2010 | Sony SDM-S204 (Black) 20.1" LCD Monitor
Colors are off on various web pages--red links are blue--pictures and game screens are okay though --Windows XP Pro--TFT LCD Color Computer Display
install the drivers of display new if persist then insert AGP card in AGP slot of grade 8X because that is not problem inbuilt display card does not support games and movie
Mar 05, 2010 | Sony SDM-HX73 17" Flat Panel LCD Monitor
Sony SDM-HS75 tft lcd monitor
Sounds like you need a new backlight. Check lcdparts.net
May 26, 2009 | Sony SDM-HS75 17" LCD Monitor
I HAVE ONE SONY MONITOR MODEL SDM HS75.
IT IS SHOWING LED BLINKING FAST NO DISPLAY IF CAN ANY BODY HELP ME TO SOLVED MY PROBLUME.
ASHOK MY CELL NO.09322133048
email.ashoksharma4@gmail.com
Mar 02, 2008 | Sony SDM-HS75 17" LCD Monitor
Sdm-n50 fault
I WANT THE SYSTEM CABLE OR IT NUMBER EXIST PLEASE
Nov 10, 2007 | Sony SDM N50R 15" LCD Monitor
Range Warning
first, 68.5 khz -85hz means horizontal raster frequency of source signal is at 68.5 kilohertz and repeats vertically at 85 hertz. (hertz means "cycles per second). the sony monitor cannot "read" the signal being sent from the pc. change the screen resolution to a lower number like 75 or 70 hertz vertical.
Jun 05, 2007 | Sony SDM-HS95 19" TFT screen silver LCD...
Sony SDM-HS75/B 17" LCD Monitor Logo
143 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
