We are replace are heater core in my cutless oldmobile but we are not she where its at under the hood
    Brigadier General:
  • 4,736 Answers
It's not under the hood. It's under and behind the dashboard of the car on the passenger side. If your car has safety air bags, be very careful not to disturb them or the wiring to them.
Posted on Mar 22, 2011
Where are heater core hoses in 2003 dodge grand caravan?
You will find them under the hood.
Do you know what the heater core is? About the size of a hard-back book, it is a small radiator with engine coolant passing through it. It is located inside the heater case under the dash.
There are two hoses, an inlet line and a return line. Both same size, about 1 inch in diameter. Both hoses come from the engine and go up to the firewall behind the engine. Both hoses connect to the heater core right at the firewall, so there are hose clamps on the end of the hoses.
You can remove and replace the heater hoses right there under the hood, pretty easy too. But if you need to replace the heater core, that comes out from under the dash. Often there is a lot of work to get to the core, as there is a loot in the way.
Mar 14, 2017 | Dodge Cars & Trucks
2002 Dodge Durango barely any heat in front and none at all in rear system Replaced thermostat already still not any better Thinking about a pressurized flush or heater core replacement any ideas on best...
Do a reverse flush on the hoses leading to the heater core. under the hood there are 2 hoses side by side on the fire wall, find the other ends and detach them, get a garden hose and back wash the core in reverse, so you will want to blow water threw the right hose first!
as for no heat in the rear well that's different it has a separate heater core, but under the hood again there is a small electric pump that helps feed the rear heater. good luck.
Mar 06, 2014 | Cars & Trucks
1994 oldsmobile 88 heater core
wow big job, ok here we go, cold engine drain cooling system,loosen clamps and disconnect hoses from core plug ends, under hood, now inside remove right side under dash panel,remove heater floor outlet duct,remove screws and clips that secure core cover,remove cover then core retaining straps and core reverse to put back together
Jan 04, 2014 | Cars & Trucks
Replace heater core in a 1987 olds delta 88
Here's a link on how to replace heater core.
Dec 27, 2012 | 1987 Oldsmobile Delta 88
I am trying to replace the heater core is it inside the car or in engine compartment?
the heater cores on this are replaced from under the hood.i believe the heater hoses connect to the heater core on top of the heater box under the hood.there should be a plate on this box with several screws(bolts),that hold it on that needs to be removed to get to the heater core itself.you may have to remove weather stripping to get to the bolts.there is a holding bracket that holds the heater core to the inside of the box that has to be removed to pull the core out.
Apr 10, 2011 | 1989 Buick LeSabre
Do I have to drob the steering colum in my 1991 licoln TC in order to replace the heater core?
No you do not have to drop the steering column to change the heater core. It should be located under the passenger side of the dashboard. The easiest way to find where it is located would be to look under the hood for two hoses that go from the front of the engine through the firewall and that will tell you exactly where it is located. To replace the heater core you will have to disconnect the two hoses under the hood from the heater core then remove the heater box from underneath the dashboard.
Dec 28, 2010 | Lincoln Town Car Cars & Trucks
Heater core leaking
Replace heater core, usually under dash passenger side. you may get lucky and find yours removes under hood on passenger side .you will have to look Im not farmillier with your truck. if it can be taken out under the hood its not a bad job.under the dash is a lot tougher.
Nov 26, 2010 | 1988 Chevrolet S-10
Find heater core
you can find the heater core of any car by following to heater hoses from under the hood they will meet at the same point on your firewall (wall seperating the inside compartment from hood compartment) If they meet at a box under the hood passengers side firewall then the core is under the hood if those 2 hoses meet and just go into the car from under the hood your core is under your dash at the location the hose go into the car. Your core is directly attached to those 1" hoses (black) 2 of them.
Oct 17, 2009 | 1989 Oldsmobile Cutlass Ciera
Have to replace the heater core on a 1997 Pot.
This is a fairly easy fix. Disconnect the heater hoses under the hood. Go to passenger side under the dash remove the lower panel from the dash to access the heater box. Unplug any and all connections on the lower half of the heater box and remove the lower half of the box should be about six screws you should see the heater core and the evaporator core. Heater core skinnier of the two should have one or two straps holding it in remove the straps and remove the core and replace.
Oct 05, 2009 | 1997 Pontiac Sunfire
Heater core
Pull the panel under the glove box. You should be able to see the heater core. disconnect the two hoses under the hood on the firewall to the heater core. put a pan below to catch the antifreeze. Replace heater core. reconnect hoses.
Nov 15, 2008 | 1990 Buick Skylark
Heating & Cooling Logo
13 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
