Question about Cell Phones
How do I fix my phone once I have switched it from NAM1 to NAM 2?
  • 32 Answers
Nam Cards are your phones way of telling which number it uses. NAM2 would be for an alternate number if you had one.
You will need to switch back to NAM1 so your phone identifies itself with your number.
If you provide your exact model, I can give you step by step instructions on how to do it.
Otherwise, if you remember how, switch back to NAM1 and you should be all set.
Posted on Mar 22, 2011
  • juggalocn420 Apr 06, 2011
    I have a samsung reality u820 that the nam got switched too. can you tell me how to unlock it? i cant get past the first screen cuz my numbe was shut off so i need to know like a factory pass thatd work instead of the last 4 of the phone #
When you change your setting to nam 2 how do you unlock your phone
Go to the keypad, type #43574357* (this number should work) and select system info, and it will display your nam2 phone number on the first (top) row labeled "MDN." The last four numbers is your passcode.This solution ONLY works if you've accidentally set your phone to NAM2 (which means that you've reprogrammed your phone to a completely different phone number, and if you've set up a passcode, that too is changed). Once you've found out your new number and passcode, you are not yet finished, because your phone is still programmed to NAM2. To fix that, you must go to your "Phone settings" and find "NAM select." Then you select NAM1 (and your phone will restart again and prompt you with your OLD passcode, if you set up one). Your phone is now fully functioning again!
Apr 19, 2012 | Samsung Brightside U380 Smartphone Verizon
My brother HIT NAM2 on my samsung flipphone and now i cant get into it
NAM Cards are which number a cell phone uses as its number. Most cell services only provide you with one number per phone which is likely to be NAM1 in your case.
Just switch it back to NAM1 and you should be good.
If you can't figure out how to get to the settings and choose NAM1, then provide the exact model of your phone and I can help you with more details.
Mar 21, 2011 | Cell Phones
Ok i changed my phone system to NAM2 from NAM1 and i cant unlock the phone
try the instructions from this URL...It worked for me.
http://www.blurtit.com/q1652331.html
Dec 28, 2009 | Samsung SCH-u540 Cellular Phone
Unlock my Samsung!!!
enter ##626# and hit send button. it will bring u to option to select nam1 or nam2, select nam1.. go to next screen, enter in the sdc code which is 000000, (6 zeros), enter or next screen, make sure that mid is same as ur cell number, go to next screen, it will show ur number again, next screen, will be sid and nid numbers... they are what they should be, go next screen, then i think there is option to be done, view, edit choose done, next screen then it will program by itself. powering on then off, bringing u back to same screen with the same window of initial programming needed, just go to enter code, and enter the last 4 of your cell number, and it will let u through,.. just remember to go back in to your phone options menu and change the nam setting in there back to nam1 also. then it will power off and on again. program should be complete... you can always also dial *228 and option 2 to reprogram your phone again to
Sep 05, 2009 | Samsung Hue (SCH-r500) Cellular Phone
Changes NAM Settings?
Here's some ideas for unlock codes, most phones use the last 4 or possibly 7 digits of the phone number, 4 or 5 - 0's or 12345.
Basically your NAM settings contain the phone number info for a carrier, and you can put two different numbers in the same phone using NAM1 and NAM2, what you have done is switch it to an empty NAM so it is asking for the rest of the programming info to set it up.If you can switch it back to NAM1 it should work again. Most phones have an option in the menu for phone settings that allows NAM switching without needing a code.
Aug 30, 2009 | Cell Phones
I was locked out of my phone and its in nam2!! HELP!!!
Call your phone company, Users are not supposed to be able to change the Nam systems. They are the only ones who can fix it now. Sorry abou that, hope I was of some help.
Mar 19, 2009 | Cell Phones
Lock code for nam2 settings
Ok i sent an email to sumsung and i got this response
Thank you for your email. If you switched the NAM to NAM2 you will need to calculate the code. Listed below are the steps on how to do so:
1.Obtain the Hexadecimal ESN of the phone. The ESN should be printed on the sticker on the back of the phone, under the battery. The Hexadecimal ESN is the one with letters and numbers.
2.Open Windows calculator by going to Start -> Run -> type in "calc", then click OK
In the Calculator, click "View" then "Scientific".
3.Click on Hex and type in the Hex ESN
4.Click on Dec for the decimal conversion and use the last four digits for the code on the handset
5.Once the code is entered and the menu can be accessed, switch the NAM to NAM1
Jul 06, 2008 | Samsung Glyde SCH-u940 Cellular Phone
Network busy/error 2048
I had the same problem with my old phone the Samsung A660. After 45 minutes on phone with Bell Mobility tech support (which did nothing to cure the problem) I fiddled around with the settings abit, and found there is a setting for something called NAM1 and NAM2. I changed it to NAM1 and I was able to access the browser again! I'm not sure though if the U740 has this NAM1 and NAM2 setting. This what to did for the A660:
  • Press MENU
  • Scroll to (7) SETTINGS, Press OK
  • Scroll to (8) OTHERS, Press OK
  • Scroll to (5) SET NAM
  • Press OK
    Options:
    NAM 1
    NAM 2
  • Scroll to option, Press OK to set
Oct 08, 2007 | Samsung SCH-u740 Cellular Phone
Cell Phones Logo
205 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
