Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
How do I remove the closed caption from this tv. I have gone through the menus and so far nothing works. The closed caption menu does not let me select turn off CC. How do I do it?? I have talked with comcast and its not any of their system doing this. Thank you.
  • Sharp Master
  • 8,457 Answers
Take the tv original remote used the remote push a CC button to all off.Closed Captioning will disappear.
Posted on Mar 22, 2011
Sharp TV does not show Closed Captioning
Turning Closed Caption Off or On
Depending on which type of equipment you have with Cox, the steps are shown at the above link.
Some programs do not support closed captions at all.
Jan 18, 2018 | Sharp Televison & Video
Dear Problem Solver, I have a Sony Bravia KLV-37S400A and I don't know how to turn off closed captioning when watching recorded movies on a TAT SKY DVR (India). I went through all menues on both the TV...
Only captioning on the recorded movies only wright?U check the movie menu itself?Sometime the movies menus itself have the close captioning functions is on?Check the movies menus make sure all the close captioning functions are off too.
Nov 07, 2010 | Televison & Video
Close Captioning will not turn off
I don't know your TV, but closed captioning normally operates from the remote and/or the menu. There should be a CC button on the remote that will run through the three or four choices, including off. Also, when you go to your setup menu (on-screen) you should be able to find closed captioning on one of the sub-menus and turn it off there.
I hope this helps.
Oct 11, 2009 | SNK Magnavox 42MF438B/27 42 in. LCD TV
How do I remove the sub text
First figure out which device is causing the problem. It can be DVD2.gif, VCR, TV etc. Whichever device it is: access menu of that device, scroll down looking for CC, Caption, Closed Caption(or similar) if none of these exist go to audio or video menus and look there for same. Press select and change
Sep 26, 2009 | Sony KV-27S26 27" TV
Can't remove the closed caption from running on my tv
Press CAPTION button on remote. Press 0 key to cycle through the caption settings including OFF
Go to: http://www.retrevo.com to download manual.
May 29, 2009 | Sanyo DS19330 19" TV
Closed caption / universal remote
Couple things to try:
On the remote - Press "Clear" button
May have to turn off CC in the TV menus. Try Menu on the remote and look for closed caption there.
If remote doesn't work, can try with buttons on TV itself to get into menu and turn it off.
Here's a link to the manual for that remote:
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=innovage&dv=universalremote&md=jumboremote&kw=&st=&ar=&dt=&so=&pg=1&file=others/innovage/jumbo-manual.zip
Mar 28, 2009 | One For All URC-4330 Remote Control
Turning on closed captioning
Some older telivisions don't have the option hoever caption with always be under the menu. Or if your playing a DVd then under the language set up.
Feb 12, 2009 | JVC AV-20220 TV
Close captioning
Hi ckay31,
If your remote is not allowing you to navigate through the menus, you may need to replace the batteries.
If this does not work, in the meantime you should be able to navigate the menus using the menu button on the TV. The Closed Captioning option should display under Channel Settings.
If you are still unable to get your remote to function properly, I recommend you contact Westinghouse Customer Service at (866) 287-5555. You may also view your product's manual at http://www.westinghousedigital.com/pdf/15_User_Manual.pdf
Thank you,
Jason,
Go Ahead. Use Us.
Jun 16, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Captioning
Try getting into the tv menus with the menu button on the remote or the menu button on the tv. Find closed caption or CC and turn it off in the menus.
Nov 02, 2007 | RCA Universal Remote 3 Device Remote...
Closed Captioned
Assuming whatever your TV receiving from has close caption. (Not all TV channel has close caption) Solution 1) Get a new universal remote that support your model and has close caption button. Once you program in the code for your TV model and it works then all button should also programmed including th close caption button. Solution 2) Search online for the owner manual and read see how to turn it on using buttons on TV (if possible). Solution 3) Get new TV with close caption. (If you have an old old TV with bad and huge pixels then this solution is the best. Your eyes will thank you.)
Aug 25, 2006 | Panasonic CT-32G11 32" TV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
362 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
