Question about Roper RAS6233KQ Top Load Washer
Water leaking from the bottom of my washer while spending out
    President:
  • 2,468 Answers
The drain pump on the motor is leaking,you need to remove control panel,then under the panel there will be 2 brass colored clips,unsnap these and remove them,then the whole cabinet will tip toward you remove the cabinet off the cleats and set aside,the pump will be at the base of the machine in front of the motor,there are 2 clips holding the pump on remove these and the hoses to replace pump,they leak around the motor shaft seal and leak when pumping out
Posted on Mar 22, 2011
Water leak from the bottom of washer
Hi friend, thank you for your post!
I understand that water is leaking from the bottom of your Frigidaire washer. There are many components that could cause a washer to leak the bellow (gasket), leak from drain hose, drain pump, or water valve. Since it could be any one of these underlying issues I would recommend having a technician come out to diagnose and repair your appliance. Hope this is helpful. -Matt
Jul 30, 2014 | Frigidaire Washing Machines
Should I buy a new washer? I have a great Kenmore, Heavy Duty, 70 Series, model 110, serial number C83193200. Yes, it was made in 1983 and now leaks water from the bottom front onto the floor.
It could be a dry rot hose or the pump could be leaking might be an easy fix it depends whether you want to repair it or spend allot of money on a new dryer are u pretty handy i could assist you on how to fix it .
Nov 24, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
I bought an Admiral washer Model No. ATW4475VQ. I bought it from Home Depot. The first washer was delivered, and when I did a load of laundry, water leaked from the bottom of the washer. I did not see any...
It's impossible to tell. from your description.
Usually a new washer is set up with new hoses. If the installers aren't complete idiots that should be good.
You can look at where the water lines come out of your wall and make sure it isn't wet there.
You could also test the water pressure at your house and make sure it isn't extremely high. Sometimes these new units can't take overly high water pressure.
Good Luck!
Mar 27, 2017 | Whirlpool ATW4475VQ Washer
Whirlpool Gold Ultimate Care II washer is leaking oil and water. Water is not leaking from the hose connection but seems to be coming from bottom of washer, as is the oil. Is it dead?
never dead just depends how much time and money you want to spend
new pump $60.00 dollars
new coupling $22.00
new tub seal $15.00
transmission and tub seal $236.00
specialty tool spanner wrench $16.00
this is just parts if you decide to replace installing yourself
Jan 27, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Water is leaking from the bottom of the machine and will not fill up
Your water leak can come from 3 areas:
1) drain hose on back of washer is coming off / splitting / getting loose
2) water pump is leaking (cracked?) or has a gasket that has deteriorated.
3) hose between tub and water pump has come off / split / became loose.
Since your washer isn't able to hold water, it makes it easy to remove the clothes, and lean the washer forward to see what is going on. Most washers' mechanicals can be acessed from either the bottom, or from the back via access panel. The water leaks are generally a pretty easy repair.
Sep 18, 2010 | Admiral Washing Machines
Water leaking from the bottom of washer
I had this problem the other week we turned the machine around and took off the water hose got to the water pump and found 5cents, hair pins, badges ect in there once cleaned out and put back together worked great again and no more leaks!
Apr 26, 2010 | KitchenAid KAWS850L Top Load Washer
Water leaking from bottom of washer
Tub Seal is leaking and needs to be replaced
Jun 11, 2009 | Washing Machines
Amana LW7503 washer is leaking water out the bottom
sounds like a faulty hub andseal kit , heres the part number R9900552 just about a hundred bucks. the only thingnot included int he kit is a 3m sealant( water tight and always flexible), as well as a "SPANNER wrench to remove the center hub. as a technician i get 375 for the job, ifyou wantto attemp it does come with complete instructions as to how to install, but this one id reccomend a pro(sorry but hate to have oyu spend themoney and time yourself, and wind up breaking something else
Mar 02, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Washer leaks water from bottom
Water pump or hose came off or broke but i bet its the water pump
Feb 06, 2009 | Kenmore 23822 Top Load Washer
Roper RAS6233KQ Top Load Washer Logo
179 people viewed this question
Top Roper Washing Machines Experts
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
