Cell Phones Logo
Posted on Mar 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can i remove a number from the "blocked numbers list"?
Anonymous
Level 2:
New Friend:
  • Expert 34 Answers
  • Posted on Mar 22, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
34
Questions
0
Helped
4078
Points
105
Umm there are many ways for example if you have a smart phone you can go into call settings advanced settings then or use *67 and do it from there or simply go to your local provider hope this helps
2answers
How to clear all blocked calls from my KX-TG7871
To clear all blocked calls from your Panasonic KX-TG7871 phone, follow these steps:
  1. Press the "Menu" button on the handset.
  2. Use the up and down arrows to scroll to "Settings" and press "Select".
  3. Scroll to "Call Block" and press "Select".
  4. Scroll to "Block List" and press "Select".
  5. Use the up and down arrows to highlight the number you want to unblock.
  6. Press the "Erase" button, then press "Yes" to confirm.
  7. Repeat steps 5 and 6 for all numbers you want to unblock.
  8. When you are finished, press the "Off" button to exit the menu.
Note that if you want to clear all blocked calls, you will need to go through the list and erase each number individually. There is no option to clear the entire block list at once.
I have a Doro cell phone and wondered if I could block phone calls.
https://phones.brain-start.tech/block-phone-number/how-to-block-a-phone-number-on-doro-phoneeasy-612/
How to block phone number on Doro PhoneEasy 612 Phone Info
Quoting from link: "Start by going to "Contacts" and tap on the contact you want to block. Then, press the menu key at the top left of your Doro PhoneEasy 612. You will see a menu where you will select "Block Number" or "Add to Auto Reject List". The title may vary depending on the model you own."
1helpful
Call blocking is full. How do I free it upp
Hello, Tamara -
To free up space on your list of blocked numbers, you will need to remove one or more of the numbers in your call blocking list.
You will have to decide which number or numbers to remove.
When I have to do that, I choose the oldest numbers in my call blocking list.
Best wishes.
Jan 27, 2018 • Cell Phones
How can i unblock a previously blocked phone number from my blackberry phone
Hello.
First, access your Block List:
  • 1 Press the "Menu" key or option from the home screen on the BlackBerry.
  • 2 Scroll to and select your "Address Book" icon.
  • 3 Click the "Menu" key when your Address Book list appears.
  • 4 Select the "Manage Numbers" option.
  • 5 Click on the "Block List" option.
  • 6 Select "OK" or "Yes" to access the block list in your address book.
Then, remove the number:
  • 1 Select the option for "Number" or "Unknown Numbers" from the block list.
  • 2 Delete the number that you want to unblock or remove.
  • 3 Press the "Menu" key when you are finished.
  • 4 Scroll to and click the "Save" selection.
Hope this helps.
May 26, 2011 • Cell Phones
6helpful
4answers
How can i block a junk fax number in a hp j3640 thanks in advance
Set the junk fax mode
By default, Block Junk Fax mode is turned On . If you do not subscribe to a caller ID service through your phone provider, or do not want to use this feature, you can turn off this setting.
To set the junk fax mode
Press Setup .
Press the right arrow to select Basic Fax Setup , and then press OK .
Press the right arrow to select Junk Fax Blocker Set Up .
Press the right arrow to select Block Junk Fax the press OK .
When prompted, press 1 for Yes or 2 for No .
Add numbers to the junk fax list
There are two ways to add a number to your junk list. You can select numbers from your caller ID history, or you can enter new numbers. The numbers in your junk list will be blocked if Block Junk Fax mode is set to On .
To select a number from the caller ID list
Press Setup .
Press the right arrow to select Basic Fax Setup then press OK .
Press the right arrow to select Add Number to Junk List , and then press the right arrow to select Number and then press OK .
Press the right arrow to scroll through the numbers from which you have received faxes. When the number you want to block appears, press OK to select it.
When the Select Another? prompt displays, do one of the following:
If you want to add another number to the list of junk fax numbers , press 1 to select Yes , and then repeat step 4 for each number you want to block.
If you are done , press 2 to select No .
To manually enter a number to block
Press Setup .
Press the right arrow to select Basic Fax Setup press OK .
Then press the right arrow to select Junk Fax Blocker Set Up and then press OK .
Press the right arrow to select Add Number to Junk List press OK , and then press the right arrow to select Enter Number .
Use the keypad to enter a fax number to block and then press OK . Make sure you enter the fax number as it appears on the display, and not the fax number that appears on the fax header of the received fax, as these numbers can be different.
When the Enter Another? prompt displays, do one of the following:
Remove numbers from the junk fax list
If you no longer want to block a fax number that number can be removed from the junk fax list.
To remove numbers from the junk fax list
Press Setup .
Press the right arrow to select Basic Fax Setup then press OK , and then press the right arrow again to select Junk Fax Blocker Set Up then press OK .
Press the right arrow to select Remove Number from Junk List .
Press the right arrow to scroll through the blocked numbers. When the number you want to remove displays, press OK to select it.
When the Delete Another? prompt displays, do one of the following:
If you want to remove another number from the list of junk fax numbers , press 1 to select Yes , and then repeat step 4 for each number you want to block.
If you subscribe to a caller ID service through your phone provider, you can block specific fax numbers, so the HP Fax does not print faxes received from those numbers in the future. When an incoming fax call is received, the HP Fax compares the number to the list of junk fax numbers you set up to determine if the call should be blocked. If the number matches a number in the blocked fax numbers list, the fax is not printed. (The maximum number of fax numbers you can block varies by model.)
Thank you.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
