Question about Dell 3010cn Laser Printer
Color streak from center to right straight down the paper
I have yet to find a solution, there is no cleaning process that I can find and Dell is useless.
Open the front door and about half way down on the right you'll see a light blue tab. Pull it up and a sliding door will open on the right hand side of the printer. Inside is a slide handle with a swab on it. slide the handle in and out 6-10 times and this shoul help with the problem. Try printing again and if it is still not 100% just retry the cleaning process. I had the same problem and thought it was the fuser, but this worked well for me. You can remove the swab for cleaning as well.
Posted on Aug 16, 2008
When the paper prints, the color is missing in areas. It looks like a streak mark down the page. The black ink is full color, they yellow and cyan have a white, non-printed streak down the center, and...
Inspect the rollers for dirty or damaged surfaces. Clean up any loose toner or other debris in the machine. Note: avoid touching any roller with bare skin; especially in the fuser section or the photosensitive drum in the toner section. Skin oil can cause poor print quality or premature degradation of the roller surface.
Jul 06, 2017 | OKI C3200n Led Printer
I have an HP Laserjet 4, quite old, and it has developed a very prominent streak almost straight down the middle of the page. Staples told me to clean the drum, but my manual doesn't even seem to mention...
Put paper in the manual feed tray. That's the pull down door in the front.
Print something. As the page gets fed 3/4 of the way into the printer, open the top cover. Pull out the toner. Look down at the paper. If you see the prominent streak, you probably have a bad toner cartridge. If the streak is not there, check the fuser. One of the rollers is bad.
While you have the toner in your hand, you should see a flap that is the entire length of the cartridge.
Put you thumb on the flap and pull it down. You will now be looking at the drum.
If you see the prominent streak, that's your problem. See if you can clean it with a soft lint free dry cloth. If the streak comes back, the rubber cleaning blade is probably bad. Replace the toner cartridge.
Feb 07, 2011 | HP LaserJet 4 plus Printer
HP 4650dn printer, two problems: 1) color streaks on the print out 2) black color a bit gray, and turn a a bit white when superimposed on other colors (except yellow)
Please use the Print Quality Troubleshooting Tool for your printer's model at the following link:
http://h10039.www1.hp.com/cpso-support-new/pq/4650/home.html
This will take you through a step-by-step process to diagnose the cause of the problems you have & correct them.
Feel free to let me know if you need any further assistance.
Dec 17, 2010 | HP LaserJet 4650 Color Printer
Drum kits marking up and streaking the paper
You can check with Dell to see if there is a maintenance kit for this printer. I know that there is one for the HP counterpart. You will probably need to replace the fuser, and maybe the pickups and rollers, but as I said I am not sure if Dell has a maintenance kit for these machines.
May 26, 2009 | Dell 3100cn Laser Printer
I'm getting a streak of ink down the paper
change a toner.
when you have the toner out. clean the heater element (glass). make sure the printer is off and the heater element is cool before you do this.
May 14, 2009 | Dell 3100cn Laser Printer
Dell lj 5100 shadow print and black streaks
The mfr. & model don't seem right; Dell does have a 5100 but the LJ designation is copyrighted by HP who has a LaserJet 5100.
The rotating drum that transfers the image to paper is smaller in circumference than the paper is long; this accounts for the shadow and the streaks come from the drum no longer being properly discharged and cleaned for the next pass.
I think you need a new drum cartridge and whether Dell or HP made it, you should be able to buy a drum cartridge here:
Precision Roller
I used them for years while in business and they are great to work with.
Apr 26, 2009 | Dell 5100cn Laser Printer
Skipping while printing
STEP: Disconnect and Reconnect the Printer Power Supply
Additional Information
1.
Unplug the power cord from the wall socket.
2.
Disconnect the power supply from the back of the printer.
3.
Wait 15 seconds.
4.
Reconnect the power supply to the back of the printer.
5.
Plug the power cord back into the wall socket.
STEP: Perform a nozzle clean on the printer.
The following steps will guide you through running a nozzle clean on the 922 printer:
1. Press the Scan Button and the Up Button at the same time to enter diagnostic mode.
2. Use the Up Button or Down Button to navigate to Clean on the LCD and press Menu to begin the nozzle clean.
3. Check the nozzle clean printout and make sure that it is clear of defects and that all expected color bars exist on the page.
STEP: Clear NVRAM on the 922 Printer
1.
2.
Use the Up Button or the Down Button to navigate to the option for Clear NVRAM on the LCD and press Menu to confirm.
3.
Press Menu again when asked if you are sure.
4.
Press Menu again when asked if you are really sure.
Ink Cartridge and Print Quality Issues on Inkjet Printer
STEP: Verify the Paper Settings and Change the Quality Level
1. Click the Start button, point to Control Panel, and then click the Printers and Other Hardware menu item.
2. Click the Printers and Faxes menu item.
3. Right-click the Dell AIO Printer Model Number icon, where Model Number is the model of the printer to troubleshoot.
4. Click the Properties menu and the Printing Preferences menu option.
5. Click the Quality/Copies tab.
6. Click the Paper Setup button.
7. Choose the appropriate paper type based on what is being used in the printer.
STEP: Verify the Printer Ink Levels
Quality problems are most often caused by low ink levels or one or more colors in the color cartridge being completely depleted. Perform the following steps to determine the current ink levels and to check for missing colors.
1. Click the Start button, point to All Programs, and then click Dell Printers.
2. Click the model number of your Dell printer.
3. Click Dell Printer Solution Center.
4. On the main window of the solution center you will see two ink tanks in the lower right hand corner. Verify that the ink cartridges are not empty
To ensure that the quality problem is not caused by one color missing print a test page and verify that the colors in the CMYK boxes appear correct. To do so, perform the following actions from the solution center window:
1. Click the Maintenance button on the left-hand side of the window.
2. Click Print Test Page.
3. Verify that the Cyan, Magenta, Yellow, and blacK colors are printing without streaks.
Apr 22, 2009 | Dell 922 All-In-One InkJet Printer
Streaks on left side of paper when printing in color
go to the control panel and then printers and fax. double click your printer and click on the tab and button to "clean print heads". after doing this, click on "align print cartridges". this will fix the streaking problem you have
Feb 25, 2009 | Dell 5100cn Laser Printer
White horizontal streaks in documents
I Am Experiencing Poor Print Quality With My Dell™ Printer
Table of Contents
Verify the Printer Ink Levels Using the Dell Printer Solution Center
Clean the printer contacts and print a test page
Clean the Printer Nozzles Using the Dell Printer Solution Center
Dell™ Printer Additional Information
» Verify the Printer Ink Levels Using the Dell Printer Solution Center
Poor print quality of a document or picture may be the result of low ink levels or dirty printer nozzles or contacts.
To check the printer's ink levels, perform the following steps:
1.
Click the Start button, point to All Programs, point to Dell Printers, and then point to Dell (printer model).
2.
3.
Locate the printer's ink levels on the lower right corner of the Dell Printer Solution Center window.
4.
If the printer's ink levels indicate that ink cartridges are empty, click the Order Ink button to place an online order for replacement ink cartridges.
For information about ordering ink for your Dell printer, refer to article: Obtaining Ink for a Dell™ Printer
Back to Top
» Clean the printer contacts and print a test page
To manually clean the printer nozzles and contacts, perform the following steps:
1.
Turn the printer off and remove the power cord from the back of the printer.
2.
Open the printer lid.
3.
Manually move the ink-cartridge carrier to the left by gripping the top of the rubber carrier belt and gently pulling it across towards the right hand side of the printer.
4.
Take a warm, semi-damp paper towel and gently clean the wiper on the right side of the maintenance station.
5.
Lift up on the cap(s) that cover the ink cartridge(s).
6.
Remove the ink cartridge(s), and using a new warm, semi-damp paper towel, gently clean the contacts on the ink cartridge(s).
Verify that the contacts on the ink cartridge(s) is/are sufficiently dry prior to re-inserting into the printer.
7.
Re-insert the ink cartridge(s) back into the correct printer slot(s).
7.
Close the printer lid.
8.
Re-attach the printer power cord to the back of the printer unit.
9.
Press the Power button to turn the unit back on.
10.
11.
12.
Click the Maintenance tab.
13.
Click the Print a test page icon.
A test page prints.
Back to Top
» Clean the Printer Nozzles Using the Dell Printer Solution Center
To clean the printer nozzles and contacts using the Dell Printer Solution Center:
1.
2.
3.
4.
Click the Clean to fix horizontal streaks icon.
5.
Click the Print button.
Note:
The printer will make sounds when cleaning the nozzles that are not commonly heard during normal usage
Mar 19, 2008 | Dell 962 Photo All-In-One InkJet Printer
Dell 1600n: Toner marks down the center of the page.
There are 2 seperate glass areas on the top, the large one is for when you lift the cover to scan or copy, the little narrow one is when you use the ADF. If there is a dot or a spec on the narrow part, it will leave the streak on the page, Clean the narrow part really well. I use a foaming window cleaner, and a razor blade.
You may also want to check to see if there are any small scratches on that glass. That will cause the same thing to happen.
Nov 14, 2007 | Dell 1600n All-In-One Laser Printer
Dell 3010cn Laser Printer Logo
173 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
