Question about Cell Phones
Easily drains battery even when not in use. - Cell Phones
  • 32 Answers
You would have to specify which phone you are using but here are some possible solutions.
Keep in mind that even if the phone is not in use it will use some battery power.
If your phone does not have a strong signal, sometimes constant searching for a signal will drain your battery rapidly
If you are using a smartphone, there may be background apps running, try using a task manager app or use the phones settings to close apps.
Posted on Mar 22, 2011
Battery light stays on and drains battery. Brand new battery, alternator and starter?
What is year--make--model?
If something wrong with wiring circuit, somewhere, replacing the part won't fix it.
Make sure charging system is working properly. To look up wiring diagram, I need vehicle info. The battery lite is on even with key out? Unplug alternator, see if light stays on, check the alternator wiring connector.
Mar 06, 2016 | Cars & Trucks
I have timex expedition watch model T49664 with altitude. It works well for last 3 years then battery died. Twice i change CR2430 even once in timex showroom. But the battery dies in 15 days. Plz help
After changing the battery press and hold all the buttons at the same time to reset this will make the watch and battery works properly so that the battery wont drain easily. I hope I have been helped you.
Nov 09, 2014 | Watches
Battery will not hold charge, something is draining, not a battery problem
Try disconnecting the battery (engine NOT running). Turn everything off. Touch the battery cable to the battery post - if it sparks a tiny bit, you can easily test. If not, use a multimeter (voltage setting) or test light between teh battery post and the cable to verify a drain. If you find NO drain that way, then nothing's draining your battery - you have a battery or alternator problem.
If you DO find a drain that way, then you have to disconnect everything electrical - one thing at a time - until the drain goes away. When it goes away, whatever you just disconnected is the culprit.
Aug 10, 2014 | John Deere Garden
What can be the cause of my baterry easily drained or loss of power even though is a newly replaced baterry in my 93 honda accord lx two door..They even check my alternator and they found nothing wrong...
A mechanic would disconnect the battery and check each circuit for a voltage drain by disconnecting the fuses and breakers. Anything with a relay or way to use electricity such as a light bulb or switch can cause a small short to ground or voltage drain.
Aug 30, 2012 | Cars & Trucks
Battery draining
how old is your battery? if it is more than 4 years old, have it replaced. if the new battery still easily drains, then there is a problem with your alternator. your alternator is not charging your vehicle properly or adequately
Aug 12, 2011 | Volkswagen Touareg Cars & Trucks
Battery easly drain
i thing ur phone is having a shorted parts.... try to visit mobile phone technician near you..... or much better replace battery first.......
Feb 05, 2009 | Nokia 6280 Cellular Phone
I have Canon power shot S2 IS digital camera.I bought it around 2 years back.Now my camera is showing the sign of "change the batteries" even though the batteries are fully charged and the lens does not...
i suggest replacing a fresh battery will most likely solve your prob, overtime rechargeable battery can drain easily, try changing with a new battery and see if it does work well, there might be insufficient current, thats why it tends to drop of voltage easily upon using,
there is a specified lifetime for rechargeable battery, depends on your usage and charging method, theymaybe fully charged but sometimes wont give you enough power to drive
cheers
Nov 26, 2008 | Canon PowerShot A540 Digital Camera
T290i battery easily discharge
U can't handle it anymore, u need to buy a new battery instead, and make sure it is original or even high quality.Never choose ow quality battery cause you're going to experience the same probem if you do.
Sep 27, 2008 | Sony Ericsson T290i Cellular Phone
Battery
i have nokia 7610 but gosh mya battery easily get drained, it tooks 3 hrs of use ,im using the correct battery -5c something like that,, pls help me find the solution
May 28, 2008 | Sony Ericsson J220a Cellular Phone
Nokia 7610, totally blackout
maybe there's a hardware problem..you're phone might be grounded that's why it drains the battery so fast..have it checked
Jan 25, 2008 | Nokia 7610
Cell Phones Logo
107 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
