Question about Zanussi ZX97 / 5 Bottom Freezer Refrigerator
I have a Zanussi Fridge Freezer bought about 8 years ago. Model no ZI8454 X (built in). A few months ago, I noticed the freezer section was not freezing the righthand compartments and when I took the drawers out, I noticed that water was leaking and then being frozen on the bottom of the left hand side and that ice had developed over the fan duct so no air was able to circulate into the freezer compartment. I defrosted the freezer completely and the freezer was working fine for about a couple of months and then I noticed the same thing happening again. There was a thick layer of ice which had developed from water running on the floor of the inside left compartment. Does this mean the end of my fridge freezer. I live in Australia now and don't know if I can get any spare parts here in needed. Someone please help
HVACRH20
  • 237 Answers
SOURCE: Fridge is warm, freezer is cold!
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves no working. Good job trouble shooting!
Posted on Jan 14, 2007
SOURCE: Zanussi ZX99/5SI
I had this problem with my ZX99. In my case it was caused by faulty temp sensors not making the defrost system kick into place. The defrost cycle works by heating an element for every week or so for a few minutes.
Posted on Aug 01, 2007
eagle338
  • 4889 Answers
SOURCE: Zanussi fridge freezer - fridge not working
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves not working
Posted on Oct 09, 2007
bomark2002
  • 160 Answers
SOURCE: Freezer Icing Up
Try contacting the hotline again and ask them if the freezer has a frost sensor on it. If it does, the sensor is not kicking the thermostat to allow for the unit to defrost.
Posted on Oct 21, 2007
woodchuck789
  • 4070 Answers
SOURCE: zanussi fridge compartment has stopped cooling but freezer is ok
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Posted on Aug 24, 2009
I bought a hisense fridge a month ago, it was Ok when we connected just for couple of days, I turned the temperature up a bit so the freezer can be colder, but now
Hisense is a company that makes cheap budget end televisions. Sounds like the defrost timer may have failed. The cold is created at the rear of the freezer and cold air is vented to the fridge. Have it looked at under warranty.
Feb 02, 2017 | Frost Refrigerators
I bought hisense HR6TFF222 a month ago, and then week later there's a problem occurs on the fridge part (the lower section), it's not working very well, it's warm as in room temperature while...
Ive just had the same issue as the op with the same model fridge. The warranty center said to adjust the front level feet to elivate the front of the unit open both doors , defrost for 8-12 hours at least. This seems to be a problem in the colder months of the year. Once a full defrost has occurred level the feet again , and turn your fridge back on. Problem solved
Dec 10, 2012 | Hisense Refrigerators
The top freezer cools like a fridge, the bottom fridge is warm
The fluxating temps bottom to top and top to bottom freezing are a result of the "air damper and baffle assy" not functioning properly. I would attempt fo make my case with LG that this started while the unit was under full warranty and persists today.
Apr 04, 2010 | LG LRTBC1825T Top Freezer Refrigerator
Fan not working
I have a bosch fridge freezer, I bought it only 13 months ago and the fan has stopped working. How do I go about fixing this problem?
Nov 03, 2008 | Bosch KGU32124 Bottom Freezer Refrigerator
Fridge does not cool
lo1972
Sounds like ice built up on the evaporator coils inside the freezer. thus hindering air flow to the refridgerator section. Is there ice build up in the freezer? This is assuming the temperature control didn't get changed inadverttily.
Hope this helps
handiman518
Jan 16, 2008 | Zanussi ZEBF250W Bottom Freezer...
Oct 09, 2007 | Zanussi ZX99 / 5 Bottom Freezer...
Zanussi ZX97 / 5 Bottom Freezer Refrigerator Logo
51 people viewed this question
Top Zanussi Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
tony denham
Level 1 Expert
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
