Question about Sony Ericsson Cyber-shot C905 Cell Phone
No earpiece - Sony Ericsson Cyber-shot C905 Cell Phone
    President:
  • Sony Ericsson Master
  • 2,246 Answers
Http://www.sonyericsson.com/cws/products/accessories?cc=au&lc=en
see the page above to see the compatible ear piece to your phone, and you can buy it after see the accessories
Posted on Mar 22, 2011
Headset earpiece assembly has become detached from headband assembly. The post does not want to go back into the hole on the earpiece assembly bracket. What do I do?
The headband post can only be inserted into the earpiece when the earpiece has been sufficiently rotated. (Note that the hole and post are a 'D' shape, not round.) The installed ear cushion is preventing you from rotating the earpiece sufficiently.
Remove the ear cushion from the earpiece by carefully pulling it off so you do not damage the clips that hold it on or the gasket material between the cushion and the earpiece. There are six clips, three on each side.
Now you can rotate the earpiece into the position where the headband post can be inserted into the earpiece.
Carefully reinstall the ear cushion by pressing it onto the plastic clips. Note that it can only be installed one way with the internal plastic support towards the headband.
Oct 01, 2013 | Bose QuietComfort 3 Acoustic Noise...
Earpiece
Be certain your radio is turned off when you initially plug in the earpiece, then after turning on the radio, immediately press the PTT on the earpiece. On most models this initialization syncs the earpiece PTT to the radio. We have experienced a few older model radios which require the radio's PTT to be pressed once, followed by the eapiece's PTT, to initialize, but this is rare. The other possiblity is the earpiece was not made to match the radio you are using it on. The position of the rings on the 2.5mm and 3.5mm jacks can make a difference between models of radios.
Best regards.
Jun 27, 2012 | Binatone Terrain 750 Twin - Black
Low earpiece volume on nokia 6103
Have your earpiece retested on another device if you have. If issue occurs on another phone w/ the same earpiece, then you're gonna need to buy another earpiece and if the problem only occurs w/ your device then I suggest you do a master reset.
Dec 29, 2011 | Cell Phones
Can I connect my garmin nuvi 1310T to my Jabra BT2070 bluetooth headset earpiece
You probably cannot. Some bluetooth devices act like phones, and others act like earpieces. The Garmin acts like an earpiece to offer a hands-free speakerphone while driving. Your Jabra earpiece wants to pair with a phone, not other earpiece-type device.
Apr 18, 2011 | Garmin GPS
Nokia 1208 earpiece problem
Hi, Earpiece can get damaged if there is dirt or the earpiece is totally damaged.
You can clean up the earpiece and see if it will work, if it doesn't work, you will need to replace it.
Thanks for using fixya.
Sep 30, 2010 | Nokia 1208 Cellular Phone
Cant hear out of earpiece, only speaker
two possible causes. either your earpiece is faulty or the flex cable is faulty. because the earpiece is on the upper side, it is linked through the flex cable and if there is a cut on the flex cable, then that may affect the earpiece lines. also, poor contact of the earpiece may cause that. open unit, ensure the earpiece has contact, check the earpiece itself and finally the flex cable.
Regards
Aug 18, 2010 | Motorola Mobility i776 Cell Phone
I cant hear people talking but they can hear me, and i can text
The problem with your phone is that the earpiece on your phone is bad that is why you cannot hear the party calling you or hear anything while you call.
All you need to do is to replace the earpiece on your phone and you will see that you can hear whoever you are talking to on your phone.
Change the earpiece on your phone and you will see that the problem is solved. meanwhile, you can keep using the headset pending the time you will replace the earpiece.
Take care.
Jul 25, 2010 | LG CHOCOLATE VX8500 Cellular Phone
AIR PIECE IS NOT WORKING
If the earpiece of your phone is not working, it means the earpiece of your phone is bad and will need to be replaced.
All you need to do is to change the earpiece of your phone and you will see that you can hear what people are saying while making or receiving calls.
Change the earpiece as advice and you see your problem with the earpiece is solved.
Take care.
May 06, 2010 | Cell Phones
My phone only works with the earpiece or speaker
the Motorola phone your talking about is not specified.First the problem can be solved.
It is an earpiece problem.The earpiece it faulty and it needs a replacement.
NOTE:
Some Motorola phones earpiece is attached to the flex of the phone, while some as an earpiece, which the flex is it can still be fixed.
Mar 15, 2010 | Cell Phones
Trying to connect my bluetooth to a new cell phone
turn on your cell; go to settings; find bluetooth settings;turn on bluetooth; find audio device choose search; then turn off the earpiece the light will be red next: turn on the earpiece again the light will flash blue and, the cell will find the earpiece the earpiece will flash blue slowly; once a minute
close the cell; use the earpiece
Sep 01, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Sony Ericsson Cyber-shot C905 Cell Phone Logo
24 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
