Question about Kenmore 44832 Front Load Washer
Kenmore 44832 hot water won't stop.
Hot water won't stop filling machine, how do I fix this? I have the 44832202 model washer.  It's about 4 years old.  For the past few months, whenever filling the washer, the inlet valve allows only hot water to enter regardless of what water temperature selection is made or what wash cycle is chosen, even COLD/COLD.  Also, once the hot water starts filling, it almost never stops on its own but causes a "F09" error for overfilling.  When that happens, PAUSE must be pressed and the water pipe turned off.  When the cycle is resumed, the valve can be reopened and water will not flow into the drum.
This does not seem to be happening during the rinse cycle.  Cold water is usually what enters the machine during all rinses.  I checked the inlet valve voltages during various stages of filling and found that the hot side solenoid has no voltage across the prongs no matter what wash temperature is selected.  Meanwhile, the cold valve has 115 V.  I'm not sure if this is a problem with the solenoids or if it originates in the Central Control Unit.  I also checked the resistance across the leads to the hot side and found it to be open.  On the cold side, there was a measurable resistance.
While I'm tempted to replace the valve first, I'm not sure if that is really the problem since it appears to be working fine during the rinse cycle.  That suggests to me that perhaps it's the inputs to the valve that are messed up.  Has anyone run across this before?  I'd sure appreciate some help on this one before I spend around $300 for a new CCU.
Thank you.
  • Anonymous Mar 25, 2014
    only resistance was in top part of water inlet valve 130 ohms,all others ck. out @ 0?
  • 1,142 Answers
If your washer is overfilling, check these:
Water-inlet valve
Water-level switch
Water-inlet valve Adefect in the water-inlet valve may mean that it's no longer able toshut off completely when the electricity has been turned off to it. Ifthis occurs, the valve may leak and drip water into the clothes tub. Intime, the water may accumulate substantially. If this happens, you needto replace the valve.
Water-level switch Adefect--or an obstruction--in the water-level switch may mean that itcan't tell the water to shut off. So the machine overflows. This switchsenses the water level in the clothes tub. It's usually a diaphragmdevice with a small, clear tube attached between the switch and thebottom of the washer's outer tub. As the water level in the tubincreases, the pressure on the air in the tube increases. When thepressure reaches a certain level, it activates the switch, shuts offthe water, and signals the timer to begin the agitate cycle. You caneither clear any obstruction in the tube or replace the water-levelswitch.
Posted on Aug 03, 2008
110.26822690 Washer won't fill...can't get back off to check the problem.
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
Jul 09, 2011 | Kenmore Washing Machines
Hi I have a problem with my Kenmore washing machine,in particular I can not use hot water anymore. When I use my washing machine hot water does not stop at set water filling level (law, medium,high)...
Please post the model number for your washer. It sounds like your hot water valve has failed and is not closing. Unplug your washer's power cord and turn the hot water spigot that comes out of the wall on. If you still get water filling your washing machine, it's definitely the washer's valve and you will need to install a new set (hot and cold valves are both part of the same assembly).
Mar 11, 2011 | Kenmore Washing Machines
Washer won't stop filling even when unplugged?
The soleniod valve is bad.... here is a tip that will help...the problem you have is with the same part but the opposite problem...
Apr 08, 2010 | Kenmore 44832 Front Load Washer
Took water intake valve assembly out to replace - confirming white wire connectors go on the cold and the black on the hot ?
Try it the way you said if it that doesn't work reverse connections. No damage can be done. You'll get cold water if asking for hot and vice versa.
Jul 05, 2009 | Kenmore 44832 Front Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
This is probably due to a pressure sensor fault, control board fault, or maybe as simple as a pipe come off.
The pressure sensor operates by air pressure building up in a sealed tube, and shuts off the water supply valve when the water presure reaches a limit.
Turn off machine, and drain the drum by placing the outlet pipe in a low bowl.
Remove the plug before opening machine.
Unscrew the screws along the top rear of the machine, and slide the lid back to take off.
Inspect the small hoses around the drawer area for wear, damage and if they are still attached. Order replacements if they are damaged.
The pressure switch will be connected to the end of one of them. It can be tested by simply removing it’s supply pipe and blowing hard down it. With a test meter, it can be tested for correct functioning.
If this is not the problem, it is likely the control board is faulty, or very rarely the valve may need replacing if it never turns the water off, and is constantly stuck.
If this leads to you solving the problem, please take a moment to rate as Fixya! so others may follow this advice. Thanks.
Jun 26, 2008 | Kenmore 44832 Front Load Washer
Kenmore Elite HE3 will only wash with hot water, need help!
yes hot water is best in washer /oil and grease will remove.
Nov 06, 2007 | Kenmore 44832 Front Load Washer
Kenmore front loader 44832
1)right wont be a water surge if the water is coming from underneath washer when it is switched of could be that you have a leak and what it is doing is water is collect around the bottom and then spilling over so tip washer back fill it up and see were its coming from, 2)your hot water valve could be sticking on which in that case needs replacing take your lid off and when washer is off try and listen for water flowing through pipe
Aug 13, 2007 | Kenmore 44102 Front Load Washer
Kenmore 44832 Front Load Washer Logo
159 people viewed this question
Sal De
 Brian Main
Brian Main
