Question about Refrigerators
I have a 680 unit. The light does not turn on when i open the refrigerator. How do i check or replace the bulb
    President:
  • 2,468 Answers
The light bulb is behind a plastic shroud change it first,then it can also be the door switch,they just pull out of the door frame and you can jumper these 2 wires to test the switch 0or use an ohmmeter to test the switch and bulb while disconnected from the unit
Posted on Mar 22, 2011
Refrigerater light not working on whirlpool gold
Turn power off, remove bulb and use a battery and piece of wire to check if it works OR use a circuit tester to check if there's any electrical resistance (if yes, bulb is shot and needs replacing) otherwise replace bulb and turn power back on.
Does the light normally come on when the door's opened? If it does then there's a switch that opening the door MUST operate. Find it, and with the door open, operate the switch. The light should turn on &off. Clean the switch - often fail with time and a buildup of gunge.
Mar 30, 2015 | Whirlpool Refrigerators
Sub zero 680 manual
I need a better model number to help you. 680 crosses as a lawn tractor.
Oct 29, 2013 | Refrigerators
The four refrigerator lights on my Viking VCBB363 refrigerator do not come on when the door opens. One of the 40W, cylindrical bulbs is black, and obviously burned out. Do I just need to replace it? Unless...
They are not wired in series. Replace the bulb burned out and check the door switch of unit. If that is not working neither will any of the bulbs.
Sep 12, 2017 | Refrigerators
Refrigerator turns off and on (intermittently) unpredictably
There's probably something sticky inside the button between the plunger and the housing or the spring inside is weak. Try to clean it out. If that doesn't work then replace it.
Oct 04, 2009 | Refrigerators
Sub-Zero 680 - Service light flashing/need to change the filter
The service flashing means that you had a long run time over a period of time. You can reset it by turning the unit on and off or if you have a door alarm button hold that for 30 seconds and that will clear the fault code. If it comes back you have a problem that needs to be addressed such as cleaining the condensor. There is no factory filter on these units. If there is a filter it is most likely under the unit, which can be accessed by removing the kick. THe kick plate is held in place by two phillips head screws, remove them and have a look. If it was done by a "professional" they should have put an inline shut off valve for easy replacement of the filter.
Nov 20, 2008 | Sub-Zero 680 / S
Sub Zero Model 680 - Light in Fridge and Control Panel out
Try wiggling light switch side to side kinda hard, (the light switch is the one on the left) it should come on, showing you its a bad lt. switch.if that fails install 1 new 40watt,(long) appliance bulb. but it is going to be the switch or the bulb considering there wasn't any wiring work done on unit. part# for the light switch is 3060140 make sure the back of the switch is white not black (black is a fan switch) Good Luck !!!
Sep 01, 2008 | Sub-Zero 680 / F
Lost light Whirlpool Regal refrigerator
two ways might first un plug the unit take the bulb ou and with your finger pull up on the contact inside the light socket ***** the bulb back in and try it if that doesn't work unplug the unit and with a mall screwdriver pry out the switch un plug one wire and with a meter check it to see if its working right or just replace it
Mar 12, 2008 | Refrigerators
Refrig lights go on and off intermittently when opening and closing refrig door
check door light switch with ohmmeter. Check for melted insulation near light "terminator". Look for wiring diagram in ziplock behind compressor grille. Second switch at door turns compressor off when door opened. I had these problems with a 695 which I would assume is probably similar in design.
Dec 26, 2007 | Sub-Zero 680 / F
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
