Question about Maxtor OneTouch 4 Plus 750GB External USB 2.0/FireWire 400 Hard Drive
Where can i find a part for my exturnal hard drive i need the bottom plate wwhere the plugs plug in my plugin came off where u hook the usb cable and i need to try and get a new one i hope you can help me thank you connie keith
  • 11,800 Answers
There are no spare parts for it - if one has failed you will have to replace the entire case. A cheap one can be found here
http://www.tigerdirect.com/applications/Category/guidedSearch.asp?CatId=2777&sel=Detail;212_159_17366_17366,Detail;212_1025_10669_10669
Posted on Mar 22, 2011
What is the connection plug from Fujitsu mht2080ah to computer?
You can install the hard drive into an USB hard drive adapter case.
Then you can connect it to the USB port on your computer. The computer will see this as an external storage device, then you can copy the files off this hard disk to your computer.
By inserting the hard drive into an USB hard drive adapter you can deleted unwanted files off the hard drive and use it for backups and data transfer from one computer to another computer.
Mar 31, 2013 | Fujitsu MHT2080AH 80 GB Hard Drive
My Apollo 250GB USB hard drive can't be detected
It should be in My Computer after you plug it in. If not, then go to control panel and search for new hardware. Click on system in control panel it should be listed under usb. Maybee it needs a new driver.
May 17, 2010 | Imation Apollo (27223) 250 GB USB Hard...
Unable to type
Flip the unit on its back and remove the battery.
Next remove the memory and hard drive.
In the memory area, you will find a lit. battery with a white 2 wire plug. Disconnect this plug and flip unit over.
Open the cover and hold down the power button for 30 seconds.
This will clear the BIOS and CMOS settings on the Laptop.
Flip the unit over and install the Hard drive and memory.
Next, plugin the battery connection.
Close unit up and plugin power connection.
Power up the 9000 and see if the keyboard is seen.
Note. You may have a defective or dammaged keyboard and may need to be replaced.
You can use a USB keyboard temp. About $20.00 USD at any Walmart
Hope this works for you.
Oct 04, 2009 | HP Pavilion dv9000z Notebook
WD 1tg external fell.
Back Up, Back up, Back up...
OK enough guilt, being in an exturnal case and your problem, first thing to hope for is a bad connection. You should first replace the USB cord (in case of strech failure, now intermintant), if that doesnt work, open the exturnal drives case, and carefully remove, and replug in the cables and connections inside the case, usually a flat cable from the controller board (what the USB cable is plugged into) the other rend of it, is plugged into the hard drive, if it is not seated tightly and bottomed out in the jack, it could become intermintant,. Thats the good news, the bad news? If the fall was "just wrong" then your drive may have been physically damaged, and your data is lost unless it is worth enough for you to pay upwards of thousands of $$ for a professional data restorer to fix all.
Sep 15, 2009 | Western Digital My Book Essential Edition...
Need help with western digital wd3200me passport
if it came with a driver disk or an install disk then try running that before hooking up your harddrive
Jun 01, 2009 | Western Digital Elements powered by WD 320...
Exturnal hard drive not turning on
try a nother USB cable possibly a thicker/better quality
Mar 11, 2009 | Seagate 160GB 3.5" External USB Drive 160...
My seagate free Agent exturnal hard drive
Hi, Sorry to hear you are having problems,
When you open your hard drive, is it locked ? Do you see a pencil with a line through it in the bottom left had corner ?
It could be that the drive has inproper permissions....
So, try this, click on the Hard drive icon (Please be sure it is the external drive, NOT YOUR STARTUP DISK ) then get info on the drive. In this info window, at the very bottom, you should see a check box allowing for: ignore ownership on this volume. Please click this box.
Now, try creating folders on the drive...
If this does not work, I highly recommend reformatting this Hard Drive, that is assuming there is no valuable information on it.
After reformatting it, it really should work porperly.
Dec 16, 2008 | Seagate FreeAgent Pro Desktop - 320GB -...
Today my firewire bus powered mac mini 320GB external hard drive (that i bought this year) stopped being powered by firewire alone and needed the USB plugging in as well to be recognised and used...the...
Hi-
Chances are these large memory hard drive should be plugin with a USB and adapter of its own since 320Gb is too big and needs power to be able to recognize. But if you find it defective you have a year warranty from the manufacturer, you can call them up for a replacement.
Hope this help. Thanks for using Fixya!
Jul 16, 2008 | Computers & Internet
Hooking up a
Your external drive has a choice of USB or firewire, so only connect with the USB cable.
Dec 05, 2007 | Western Digital External USB 2.0 80 GB...
Maxtor OneTouch 4 Plus 750GB External USB 2.0/FireWire 400 Hard Drive Logo
42 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
