All of a sudden the printer can't scan / print wireless. I came home over the weekend, and it stopped. It says there are ports that cannot be used with their current settings.
SOURCE: Printer gave a loud noise & stopped scanning & printing
error e-91
Posted on Sep 05, 2008
  • 1015 Answers
SOURCE: scan from printer through router to pc?
You will need to use the TWAIN software for the printer. From the computer you will be running the scan options thru the TWAIN software. Then the scan files will be pulled from the printer back to the computer. Running scan options directly from the printer will give you the option to print the scan files or send them to a memory card if your printer has a slot for one. If the scanning software is not installed on your computer then you will need to download it from the manufacturer's website.
Posted on Sep 23, 2009
SOURCE: HP J4680 Printer worked fine then suddenly stopped.
Generally a reset or, unplug and re-plug in can clear the problem..
Posted on Feb 01, 2010
Pulkit558
  • 472 Answers
SOURCE: printer suddenly stopped working with quickbooks
  1. Open the QuickBooks sample company and try to print the same form or type of form. If it prints successfully, your company data, form template, or customized report may be damaged.
  2. Reopen your company file and try to print an uncustomized (standard/default) form template or non-memorized report. If the issue occurs again, refer to Verifying and rebuilding the QuickBooks company data and then attempt to print again.
  3. If you were printing a batch of forms in QuickBooks, attempt to print a single form. If successful, try printing smaller batches.
  4. If you were able to print from QuickBooks in the past from this company file:
  5. Turn off the printer, restart your computer, and then turn the printer back on.
  6. In QuickBooks, choose File > Printer Setup and check the printer settings for the specific form you're trying to print.
  7. Click Help in this area for more detailed instructions on these settings.
  8. Ensure that you have the latest printer drivers for your printer. Go to the manufacturer's website to download and install the most current drivers.
  9. Replace the QuickBooks Qbprint.qbp file:
  10. Close QuickBooks.
  11. Rename the qbprint.qbp file.
  12. Open QuickBooks and attempt to print again.
  13. If the issue persists, repair the QuickBooks installation.
Posted on Mar 07, 2010
  • 2386 Answers
SOURCE: Hello, I have a
You have to make sure the following are used on your wireless settings on your router -
Wireless Network Security SSID (32 chr), WEP 64/128bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES)
This means your SSID is less than 32 chars and your running either WEP, WPA. Or WPA2
Then on your printer make sure you have the wireless enabled and Just a good rule of thumb - When putting in a wireless printer just fudge with the wirless/TCP/IP settings on the printer until you can ping the printer from the PC. Do NOT bother running the software installs until you know you have a good ping from the printer as it will just bomb out.
do rate the solution plz
Posted on Nov 25, 2010
How do I fix this: Printing works but suddenly Scan function doesn't work?
I am a Brother employee working for the software technical support department.
We have a solution for your scanning issue posted on our solution site.
Description of Problem 100000024547
I am unable to scan in Windows 7 using the Wireless Network connection. What can I do?
Brother Software Technical Support
http://www.brother-usa.com
Jun 29, 2014 | Brother MFC7860DW AllInOne Laser Printer
This printer is connected to 1 pc via usb and prints via the network from pc 2 and 3.it suddenly stopped printing from pc no 3 but still prints from pc 2
If the printer is printing from pc1 that means the usb port is ok. If prints from pc2 that means the network port is ok, so the problem is not in the printer but in PC3. Check connection of pc3 to the network, check the settings, check recently installed programs - especially firewall or new antivirus version. Scan for viruses - there are some blocking traffic. You can even turn the pc3 back in time using the system restore service.
Hope this helps.
Sep 13, 2011 | HP Laserjet M2727nf Multifunction Printer
Can we use MF6550 for wireless network?
If you use a wireless USB print server like this . Keep in mind that you may not get all functions such as scanning to work but it will allow for printing for sure. If the scanning works consider it a bonus.
Jun 11, 2011 | Canon imageCLASS MF6550 All-In-One Laser...
Wondering what I need to print wirelessly from laptop with this printer
If you printer hasn't a built-in wireless connection and if you haven't a wireless router then -
You need a wireless router plus print server. Connect this print server to the wireless router with a LAN cable. Then the printer is then connected to the print server's printer port.
The laptop's wireless card is then configured with the router's wireless settings.
The laptop is then installed with the printer driver and the printer port needs to be changed/configured with the print server's IP address.
ALTERNATELY
If the printer is connected to a desktop computer on your home LAN and it is also connected to your wireless router. Then you can set this printer as A Shared Printer on your desktop computer, but this desktop computer and the printer has to be powered up for the laptop to print to the printer.
For instruction on setting up a shares network printer, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3668797-setting_up_shared_network_printer
Nov 16, 2010 | Canon PIXMA MP510 All-In-One InkJet...
C4388 scan through wifi?
This is happening because the system doesn't have Network Twain Port drivers installed.
Try installing the twain port drivers and assign the IP address of the printer to scan
Oct 12, 2009 | Xerox DocuColor 12 Printer
Can I print via my wireless network with HP OfficeJet 6310xi?
Nothing helps. Print servers are capable of connecting a multifunction printer for printing capabilities only. For scanning, you have to connect directly to the Computer or by a Multifunction printer with wireless capabilities.
Jan 15, 2009 | HP OfficeJet 6310 All-in-One Printer...
HP C7280 - Just Stopped printing on only One of my computers
Had a similar problem. Try downloading the printer drivers again from HP website.
Dec 02, 2008 | HP Photosmart C7180 All-In-One InkJet...
Does HP LJ 3055 printer scan over the wireless network?
Scan over wireless network is not supported with this printer. You can try set it up and get scanner to work with usb and then change port from usb to HP standard TCP/IP for the device, but I don't think it will work.
Apr 08, 2008 | HP LaserJet 3055 All-In-One Printer
Unable to print
I have had the same problem. 2 computers had been able to print fine then 1 stopped (other was still fine). I use Network Magic as well- noticed that the IP address for the print server was different on each computer.
I deleted the 2 printers on the computer that could not communicate to the server, logged into the server and set its IP address to static at the address listed on the computer that could print. Next ran the set up for the printers on the problem computer again.
Test pages now printed out fine.
Mar 25, 2008 | D-Link RangeBooster G DPR-1260 (DPR1260)...
532 people viewed this question
k24674
jasbo
jasbo
