Question about Car Audio & Video
I popped a 100uf 16v cap in the c5 spot on my amp...what would cause this and could i replace it with a 100uf 35v?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
You might want to check all of your transistors to make sure they are good. replacing a 16v with 35v is no problem. it is fine to replace smaller voltage with larger voltage, but not the other way around.
Posted on Mar 22, 2011
I have a Panasonic TV pc-29x92 wich has a
Yes there are 2 capacitors that are usually bad one they are both very close to the vertical output. one is a 100uF at 35Vor 25V and the other is usually a 220uF at 25 or 16V- Replace with 100uF at 50V and 220uF at 35V- and observe the polarity(+,- symbols on caps) before replacing.
Oct 07, 2009 | Televison & Video
3-5 error code on mitsu wd-52725(chassis fan failure)
Check the power PWB pico fuse F9A09 and if thats good check the following capacitors all on the power pwb.
Power Supply
C9A52 1000uF 16V
C9A59 1000uF 16V
C9A61 1000uF 16V
C9A62 1000uF 16V
C9A39 2200uF 35V only some versions
have this cap.
C9A40 2200uF 35V
C9A37 3300uF 16V
C9A38 3300uF 16V
Feb 28, 2009 | Mitsubishi WD-52525 52" Rear Projection...
When i switch on my P.C. and my FP 5313 screen it flickers
This is a known problem with a series of components inside the monitor. There are about 11 capacitors that if replaced will allow the monitor to function properly.
The best place to go to read more is http://www.badcaps.net/forum/printthread.php?t=2658
The list of the capacitors that are bad are below with possible replacements.
C922, C925: Hermei LE 1000uF 16V, low impedance, general purpose, replacing with 1000uF 16V Samxon GF.
C201: Hermei LZ 150uF 25V, ultra low impedance, high ripple current, replacing with 1000uF 25V Samxon GF.
C924, C926, C929, C930, C932, C933: Hermei LT 470uF 16V, high ripple current, low impedance, replacing with 1000uF 16V Samxon GF.
C207: Unknown CD110 50uF 4.7uF (general purpose), replacing with a 35V 4.7uF tantalum unit (SCP/Short Circuit Protection pin on TL1451 won't get anywhere near 35V).
C907: WC (with stylized Westinghouse W) SM 22uF 50V (general purpose), replacing with 63V 100uF Samxon GF (used for SMPS controller Vcc filtering).
C905: Hermei HT 100uF 400V, standard, general purpose, leaving as is - generally no problem.
Dec 06, 2008 | HP Compaq FP5315 15" LCD Monitor
PT47WX49E wavy lines
That unit has a history of bad caps throughout the convergence and other circuits. Personally I believe it was an error in the design.... Check and/or replace the following::: C2451, C3007, C7022, C4613, C2507, C7060 all 100uf/16v and C7127, C7128, C7103, C7154, C7136, C3010, C3008, C3002 all 47uf/16v... You can use a higher voltage rated caps such as 35v or 50v for greater reliability.
Bill
Nov 01, 2008 | Panasonic PT-53WX53 53" Rear Projection...
POWER WONT STAY ON
You have bad Capacitors cp150 2200uf 16v, cp111 330uf 35v cp114 220uf 35v this is common with these sets they are on your deflection board green with gold writing 2200uf etc. Look at capacitor cp150 if it has a bubble look on top it is bad so replace all 3 caps.
Oct 18, 2008 | RCA HD52W56 52" Rear Projection HDTV
Power board circuit for L20V34S
I WORK FOR A HOSPITAL HAS SOME 70 L20V34S. THEY HAVE STATRED ALL GO DOWN. CAN SOMEONE HELP ME WITH THE CAUSE OR PART NUMBER FOR POWER SUPPLY OR WHAT EVER THE PROBLEM. THANKS HCC
Oct 12, 2008 | Televison & Video
Using a higher voltage cap
You can use 16v or greater = I ordered 25v to keep the size down, 35v is ok,if you must,you can lean them over 90 degrees.
there is plenty of room............................T.
Dec 12, 2007 | Televison & Video
Clock and oven control display
This solution worked great for me. I can't believe it was only a samll little cap. Thanks a bunch for this.it saved me a bunch.
Its real easy to do if you're handy.
IMPORTANT Turn circuit breaker OFF first
Open oven door
From underneath control panel remove 4 white screws with philips screw driver
this holds white cover strip
remove 4 hex head screws which will loosen the panel.
remove panel and support it's weight as many wires are connected.
remove 2 small plugs on board - you may need a small screw driver to pry away the locking mechanisms on the socket
Remove riggon type flat cable by squeezing black tabs on eand and lift up.
The board can now be removed by unclipping 2 of the clips holding the board while lifting up.
Take board to Radio Shack and ask for a suitable replacement for the C3 cap which is 35 volts and 68uf (microfarads). Remove and replace by careful soldering.
If traces lift off oard use a wire to jumper trace
ensure the cap goes in the same polarity there is negative signs on one side.
You can parallel caps to add uf together.
Voltage should be not less than 35volt slightly higher is OK.
Mar 25, 2007 | Jenn-Air SCE30600 Slide-In Electric...
Car Audio & Video Logo
42 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
