Question about Kenmore Kitchen Appliances - Others
Kenmore oven mod/n 629.46799894 flashing code f1 and beeping and turns off or wont heat up over 325 need parts to fix
Powerman
  • 68 Answers
SOURCE: my GE double oven is flashing F1 and beeping
The F1 error is similar to the F7 error and the fix may be similar. It indicates that the touchpanel needs to be replaced. The problem is really one where the insulation is breaking down between two sections of the ribbon cable which connects the touchpanel to the electronic control. I have solved the problem by placing slip of paper between the two secions of the ribbon cable. The slip of paper should be worked down into the slot. It will only go about 1/8". A piece of file card material works well. See attachec photo. If you have a metal touchpanel, you will also have to add slips of paper at the edges of the metal slot. __Be sure and turn off the power to the oven at your circuit breaker!____There are usually three small screws at the bottom of the touchpanel. The panel may need to be pushed upward to release it. Have a friend available to hold the panel while you work on it. Do not allow the panel to dangle by the wires.____Please let me know if this works for you or if you have any questions. You can reach me at hutchipop@yahoo.com. I have shared this solution with over 830 folks. Most report success.
Posted on Jun 06, 2007
fridgetech
  • 473 Answers
SOURCE: oven beeping f1 and f3
Here are the error codes for your range:
F1 Circuit board defective Replace control board F2 1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked 1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
2. Check 8-pin connector. Check and replace oven temperature sensor if necessary F3 Oven temperature sensor is open (above 3000 ohms) Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor and control F4 Oven temperature sensor is shorted (below 500 ohms) Check resistance of oven temperature sensor, check for shorted wiring between oven temperature sensor and control F5 Internal watchdog circuit has detected a failure Defective EOC (Electronic Oven Control) F6 Shorted buttons Check push buttons and dome switches on control F8 Logic interrupted (lock motor switch sequence) Check door lock switches and wiring
Most likely problem is the oven temp. sensor. Should check around 1100 ohms at room temp. I would replace that first because it is the easiest and cheaper than an oven control.
Posted on Nov 23, 2007
aborcass
  • 2651 Answers
SOURCE: Maytag MER5770AAW Oven
f1 is a bad range control/ touchpad, here the part number for a white clock for model number MER5770aww 74008106 approx 150 bucks
Posted on Apr 08, 2008
SOURCE: Stove reads "F1" on the display and beeps
Go to www.applianceaid.com/images/ge-built-in-oven-faultcodes
Posted on Sep 20, 2008
docjohn174
  • 943 Answers
SOURCE: F1 error on SS Amana Convection wall oven
hi in the amana fault codes it says to replace the clock.its faulty thanks
Posted on Oct 16, 2008
Have a kenmore double electic oven that wont stop beeping...it displays "f1" in the screen. how do i get it to stop beeping?
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 02, 2010 | Kenmore 47722 / 47724 / 47729 Electric...
Can you tell me what an F1 error Message means - 30 minutes into baking, I got beeping and an F1 error message. Canceling did not turn the oven off and the only thing I could do is turn it off at the...
"F1" code clearly indicates that main control board has failed. The possible fix for this kind of problem is you have to replace the faulty circuit board. This is the only solution and you cant repair anything else in this unit when F1 flashes.
Thank you !!
May 30, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore oven control beeps and shows F1
According to Kenmore's list of error codes, F1 means EOC (Electronic Oven Control) failure, and the solution is to replace the EOC. You might look into that. The part itself costs around $80, as far as I can see.
Aug 24, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Oven turns on by itself and F1 flashes on the digital clock
Without being able to look up the error codes for your model (number please!), I would guess that the oven control triac has shorted out or the relay is stuck on (I assume the oven runs at maximum temperature). In any case, the oven microcontroller knows something is wrong, so it says F1 and beeps for help.
Aug 10, 2009 | Kenmore Kitchen Ranges
GE Profile Double Oven F1 Error
&*&^%rt
Aug 08, 2009 | GE Profile JTP56 Electric Double Oven
Oven can not heat
f1 is the code for a faulty oven control or as you know it the clock replace it
Feb 12, 2009 | Kenmore 96532 / 96534 / 96539 Electric...
OVEN FLASHES -F1- AND BEEPS, CANNOT TURN BEEPING OFF
IF you already tryed unplugging it to reset the clock and it didnt fix it you must replaec the electronic control. F1 means analog to digital failure. AKA replace electronic control.
Nov 19, 2008 | Kenmore 92002 / 92004 Kitchen Range
F1 Error on Maytag Electric Oven
Found something on the net that said it may be a heat sensor so I returned my new touch pad ($220) and put in my old one that was giving me the F1error. I bought a heat sensor ($55) and crossed my fingers. It WORKED! F1 was no longer flashing and the oven's back up and running.. so much for the error codes.. F1 = touch pad and F4 was supposed to be the sensor..
If you're fixing it yourself and think it may be the touch pad, I recommend going through SEARS. Even though the touch pad was an electrical part they still allowed me to return it hassle free and most companies wont accept returns if it wasn't installed by one of their service professionals. So I was more than happy to get the $220 back when it turned out to be the heat sensor. Only downfall is that I had to wait 2 weeks to get the part. Hope this helps anyone with the same error.
Nov 14, 2008 | Maytag Kitchen Ranges
Oven "beeping" wont stop
Sep 12, 2008 | Kenmore 47722 / 47724 / 47729 Electric...
Kenmore, F1
I really need to know the make and model but most F1 are a bad control board.. F1 Analog to Digital Failure Disconnect from power for 30 seconds - if display reappears - replace control board
Aug 27, 2007 | Ovens
Kitchen Appliances - Others Logo
108 people viewed this question
Top Kenmore Kitchen Appliances - Others Experts
Charles T Nevin
Charles T Nevin
Sal De
Are you a Kenmore Kitchen Appliances - Other Expert? Answer questions, earn points and help others
