Question about Toshiba Satellite A100-S8111TD Notebook
My Toshiba Laptop is not starting. When i turn on my laptop its showing only power LED and Black screen. Please help
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 135 Answers
Please check whether your laptop RAM is working. If you are having two RAM's remove one and start the laptop. If it is working shutdown the laptop and fix the next RAM to slot and switch on.
If it is not working consider to chang the RAM.
If you found the solution is helpful please vote for me, Thank you.
Posted on Mar 22, 2011
Testimonial: "Thank you very much. Quick response. The problem was loosen RAM. Now it is working fine."
Toshiba A305 black screen
You can start by removing the HDD and testing, replace if necessary. Reseat the Memory Mods as well. Has there been any damage? Drop? I assume the blinking LED is the HDD?
Apr 26, 2013 | Computers & Internet
Black screen on toshiba protege r705-p35
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Oct 15, 2012 | Toshiba Portege R705-P35 Laptop
Black screen please help
The Connection between the motherboard and display must be broken. I think you will have to change the display.
Car Headlights
Aug 28, 2012 | Toshiba Satellite M115-S3094 Notebook
I turned off the touchpad on My Toshiba Satellite m55-s329 laptop which disable the mouse and keys to function. So I had to hard start my laptop. When it turned back on my screen was blank (black). The...
Please connect a USB Mouse and keyboard then power on your laptop it will boot your win xp then re enable your touchpad by going to device manager. It will work.
Sep 13, 2017 | Toshiba Satellite M55-S329 Notebook
My laptop wont show any video, when i press the power button, the fan turns on and the blue led shows up around the power button, but no video just a black screen.
In most cases this means a dead video processor on the motherboard. There are places you can send the motherboard to or change it out completely
Aug 31, 2009 | Toshiba Satellite A65-S126 Notebook
I re-started my toshiba A135 laptop, and the screen went black
There are dozens of possible root causes for your problem I guess.
But exactly the same happened to me in fact on a packard bell laptop. After my son forced it to reset, it didn't start again. Only one led was lit. After a long search I found that the battery had died and this prevented the laptop to start even when the power supply was plugged in.
Try this: remove the battery, connect it to the power supply and restart.
Hope that helps
Jan 24, 2009 | Toshiba Satellite A135-S2276 Notebook
Start up
yr problem should be from the screen to really confirm if yr laptop is truly on cos u dont just gudge by seing the power led on. to check if yr system is on press the caps lock key or press the fn+num lock key if the indicator led comes on then yr system os on now troubleshoot yr screen by checking the module,connector n fuses. if the caps lock led doesnt come on then yr system just powered on because it saw a power source in that case try to replace the memory(ram) next the processor.
guess this helps
thanks for using fixya
May 26, 2008 | Toshiba Satellite A135-S4427 Notebook
Toshiba won't start
Hi, what happens when you push the button? Lights, sounds from inside the laptop, anything flash on the screen?
Sep 27, 2007 | Computers & Internet
Toshiba Satellite A100-S8111TD Notebook Logo
206 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
