Question about Lexmark X4270 All-In-One InkJet Printer
Printer doesn't print / errorr#1200 - Lexmark X4270 All-In-One InkJet Printer
    Guru:
  • 1,833 Answers
You have to remove the shell from the black base. Clean the goop from under the ink cartridges. Put the silicon on the bars after cleaning with alcohols. Grease the gears sparingly, put it back together. It will work. There are eight black and one shinny screw that need to be removed. Also a white bar with a violet gismo, pull that up to remove, and the paper guides.
Posted on Mar 22, 2011
Service error 140.10 transport motor
This is a generic error message that can be recorded for a wide variety of problems. Basically, any time the Report Server has problems initiating an application it will record this message along with:
- Application name (i.e. WindowsService_21, WindowsService_13, WindowsService_8)
- Error description (and that can vary widely). Examples: "The endpoint cannot be created.", "The report server has encountered a configuration errorr", etc.
For more help visit cbrtechsolutions
Mar 12, 2014 | Lexmark MS410DN Laser Printer - Monochrome...
X1270
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 1200 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
After printing the test page, try to print a document again to verify that the problem is fixed.
Jan 23, 2012 | Lexmark X1270 All-In-One InkJet Printer
Hp laserjet 1200
If you want the printer driver for your HP printer then -
You can download the HP printer drivers from their supportWEB site. Please click on this link and select your model printer to download:- http://welcome.hp.com/country/us/en/support.html
Dec 09, 2010 | Office Equipment & Supplies
Printer lights all flashing E flashing errorr
This is a cartridge problem. most likely one of them has developed incompatibility. simply change one after the other to determine which it is. if you have old used ink cartridges, use them to try.
Take care!
Jul 31, 2010 | Epson Stylus DX5050 All-In-One InkJet...
How do I adjust the darkness of the printing, it is currently set at 2 out of 4 darkness?
You will need to follow below process.
Print quality settings always affects on print resolution and toner usage.
to change print quality setting:
1. go to Start/settings/control panel/printers
2. then go to printer's properties.
3. go to paper/quality TAB. and select the setting that you want to use. you will get following options.
a) 1200 dpi: This setting uses ProRes 1200 to provide fine-line detail at 1200 x 1200 dpi.
b) 1200 dpi effective output quality: This setting uses ProRes 1200 to provide fine-line detail at 1200 x 1200 dpi.
c) 600 dpi: This setting provides 600 x 600 dpi output with Resolution Enhancement technology (REt) for improved text. (this is what you may need to get)
d) Economode: this settings use less toner of your printer. This is useful for mostly draft printings. You can turn this button on freely of other printing-quality settings.
Select the needed settings. Test a print.
And if it is perfect you wont be charge to give recommendation...lol
Aug 12, 2009 | Samsung SRP 350 Thermal Printer
Laser jet produces printouts that are smudged and dark
Remove the toner cartridge and use a soft cloth to wipe the photo drum clean of toner. Put it back and try again, if you still get bad prints, then you need a new toner cartridge.
Apr 01, 2009 | HP LaserJet 1200 Printer
HP2100 laserjet won't print inserted pix in Word 2007 doc
I ended up fixing this problem myself.
I needed to set the printing resolution in the HP printing dialog box to 1200 x 1200 dpi as the HP2100 can print at this resolution.
Select: Print/Properties/Advanced/Graphics. Then set the printquality to 1200 x 1200 dpi.
Rod Salter
Dec 15, 2008 | HP LaserJet 2100 Printer
Lexmark X4270 All-In-One InkJet Printer Logo
18 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
