Question about Pioneer GM-6300F Car Audio Amplifier
Pioneer GM 6300F bridged connections shown on rear and in manual are incorrect! ! bridge ! chan B + - - + ! sub !
3 Suggested Answers
etirbynnor
  • 655 Answers
SOURCE: Ccan it be bridged with a 5 ohm subwoofer?
Hello cameron_cran,
The information I found on the amp is that is a 2-channel and is bridgeable. It is stable in bridged mode to 4 ohms. You should be able to bridge a single 4 ohm sub without damage to the amp.
Hope this helps.
Posted on Apr 22, 2009
  • 111 Answers
SOURCE: i wired my dvc sub
1. Check if your power cable is of adequate Gauge 2. Try turning the volume down from the amplifier gain level 3. You could even check to see if your battery is on it's way out and just cant feed the amplifier with the power it needs. (very rare case) do the car lights dim when the volume is not really that loud? 4. There could be an error on the way the subs are connected, double check that you have absolutely configured them to run @ 4OHM. could be checked with a multimeter before connecting to the amplifier. 5. Another rare case is sometimes the fuse block expands when it heats up on loud volumes and can have contact issues so try tightening the socket that the fuse goes into. 6. It could also be a problem with one of the sub woofer or even the amplifier. more details might help me better understand the problem, but i hope this helps. dreamsystems
Posted on Feb 06, 2011
Can a GM 5602 amp see an 8 ohm load bridged, and if so what wattage will it push
The Pioneer GM A5602 can handle down to 4ohms bridged @450W continuous. So not sure of the difference between the GM5602 and the GM (A)5602 but I would bet it would be able to handle an 8 ohm load easily. Probably at about half of the power(225W)...which is still quite a lot depending on what you are planning on pushing.
Nov 09, 2014 | Car Audio & Video
How to bridge an amp to one sub
Left positive and right Negative will bridge the amp. What ohm is that woofer?
Mar 23, 2014 | Pioneer GM-X524 Car Audio Amplifier
Amp pioneer 760 watts keeps blowing both 30 amp fuses when volume is raised
remember this amp when bridged can only go down to a 4 ohm load so if your subs are putting a load to the amp that is anything below 4 ohm than your going to have issues. is used as a 2 channel each channel can to 2 ohm but when bridged 4 ohm and above.
Aug 12, 2011 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Pioneer car audio amp GM 6300F (new)
Does your amplifier have a Channel swith which says 2/3/4 channel mode. If so and you are running the amplifier in Bridged mode, try changing the setting to 2 channel or Bridged mode.
Aug 20, 2009 | Pioneer GM-6300F Car Audio Amplifier
Hello cameron_cran,
Hope this helps.
Apr 22, 2009 | Pioneer GM-X322 Car Audio Amplifier
What are the correct spaekers for the gm 5100t ?
    CEA-2006 Compliant Amplifier Power Standard:
  • 125 Watts x 2 @ 4 ohms <= 1% THD+N
  • 380 Watts x 1 @ 4 ohms BRIDGE <=1% THD+N
  • 75 dBA Signal-to-Noise Ratio
  • Peak Music Power: 250W x 2 (4 ohm) / 760W x 1 (Bridge)
  • 2 Channels
  • Continuous Power @ 4 Ohm: 125W x 2
  • Continuous Power @ 2 Ohm: 190W x 2
  • Continuous Power Bridged @ 4 Ohm: 380W x 1
  • Frequency Response: 10Hz-50kHz
  • THD (1kHz, 4 Ohm): <0.015%
  • Signal to Noise Ratio: >95dB
  • Dimensions: 11 13/16” x 2 3/8” x 12 7/8”
  • PWM Regulated MOSFET Power Supply
  • Balanced Isolator Input Circuit
  • Oversized Screw-Type Power/Ground Terminals
  • 2 Channel RCA Inputs
  • Speaker Level Input
  • Screw-Type Speaker Terminals
  • Hi-Volt Input Level Control (200mV-6.5V)
  • Bass Boost (50Hz, 0/6/12dB)
  • Selectable LPF (80Hz, -12dB/Oct.)
  • Pioneer 1-Year Warranty
I'm assuming the subwoofers were bridged and couldn't handle the power. Make sure you have atleast 300 watts peak power wattage.
Feb 05, 2009 | Pioneer GM-5100T Car Audio Amplifier
Hooking up a new 8" woofer speaker to my amplifier
If I'm reading the amp manual right, you should be able to connect the amp in 3 channel mode. To do this:
  • Connect both left door speakers in parallel to Ch A Left.
  • Connect both right door speakers in parallel to Ch A Right.
  • Bridge Ch B and connect it to the new 8" sub.
  • Set the Ch A LPF/HPF to HPF.
  • Set the Ch B LPF/HPF to LPF.
This should allow you to run all 4 door speakers and the sub from the amp. It will also automatically route non-bass to the door speakers and "only bass" to the sub.
Mar 22, 2008 | Pioneer GM-6300F Car Audio Amplifier
Wiring my subs to my alpine mrv-1000
did you read your instruction manual. does it says "it could be bridged to other amp"?. you can't make a bridge to amplifier that is not bridgeable. bridging an amp is a way which it is made through transistor type ampilfier by bridging more transistor inside and more voltage is required for bridging.
I don't know if we could do to an IC type amplifier. ask an experts about bridging IC types how to bridge maybe they know how.
and if you had an successful bridging, you may have a problem through your speakers, they may hit hard but you will experience some errors through your speakers and easy to worn.
Jan 22, 2008 | Pioneer GM-X962 Car Audio Amplifier
Speakers
400 watts delivered to 300 watt speakers the only way to do this would be to wire two subwoofers in series so that the power needed to drive them will be 600 watts to max, however this will increase your impedance on the speaker (8 ohms) load so what you can do to compensate is get an 8 ohm 600 watt resistor and put it in parallel with the speakers you will then have 4 ohms of impedance at a total capacity of 600 watts of power In other words the amplifier won't blow these out now.
Oct 08, 2007 | Pioneer GM-X722 Car Audio Amplifier
Pioneer GM-6300F Car Audio Amplifier Logo
148 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
