My HP 1120NR Mini _ with XP re-installed, everything is OK, but when folding the running computer, and then open it ....How to chage it back from the hibernate state to working state ? ("fn" and "fn+f1" can't work !)
    Sergeant:
  • 236 Answers
You need to set or choose the Windows XP power scheme according to the way you want it.
1. on the desktop, click on start at the bottom left of the screen
2. on the pop-up window, click on Control Panel
3. in Control Panel window, double click on Power Options
4. in Power Options Properties window
5. under Power schemes, click on v for a list to select the appropriate power scheme.
6. under Settings for power scheme selected, customize as necessary and then click Save As...
7. click Advanced tab
8. select desired Power buttons action ... close lid, press power button, press sleep button
9. click Hibernate tab
10. under Hibernate, if required, click the check-box to toggle the Enable hibernation
11. click OK to exit Power Options Properties
Posted on Mar 22, 2011
Install windows xp on hp mini with an external DVD rom
This notebook will not run properly with XP as an OS. There are no drivers as XP was obsolete before this notebook was first made.
Jan 14, 2014 | HP Mini 210-1030NR Netbook
Hard Disk Adapter
Why would you go back to XP after having 7?
Installing any operating system:
When you first boot the computer you will see a screen that says press: F1, Delete, etc to enter setup. Once you are in setup (BOIS) navigate with keyboard arrows to find 'boot sequence'. select boot from 'cd'. Remember you have to go back and set this to boot from hard drive after you load the OS (Operating System).
Make sure you save your files, everything will be gone. Also, backup all of your drivers or download them from the internet and store them on a USB flash drive. As you may not be able to access the internet to load them.
Boot from CD>going into setup>install xp>delete partition>create>partition>setup will format drive>quick is fine>will have some prompts for selections, etc.
I hope this helps.
Oct 21, 2013 | HEWLETT-PACKARD HP Mini-Notebook...
I dont know how to change the language on my HP mini from french to english
What operating system are you using?
from the keyboard hold down the windows key then press the letter R.
The run box should come up, type in intl.cpl
This will open the regional settings of the computer
The first tab should be format. Change it to english.
Clicl the third button (apply) on the bottom and then click the first botton (OK).
Note: Only applies for computers which has other languages installed.
IF you are using windows xp there may not be a way but to grab a XP english cd and reinstall it.
May 31, 2011 | HP Mini 1000 Netbook
How to unlock password for a HP 2140 Mini-Note
If you are talking about the login to Windows password then here is one way to do it:
Create a bootable USB stick using this tool: http://www.pendrivelinux.com/yumi-multiboot-usb-creator/
Use the image from Ophcrack to load onto the USB: http://ophcrack.sourceforge.net/download.php Choose the XP LIVE CD Option
1. Download the YUMI exe to your desktop 2.. Save the LIVE CD of Ophcrack to your desktop. 3. Plug in the usb stick you want to use (make sure it is at least 500MB. 1GB if possible) 4. Run the YUMI EXE and follow the instructions. Make sure to choose the USB Drive Letter ("D:" E:" etc) 5. Choose the Ophcrack ISO for the image. 6. Install to USB 7. Click Finished and exit the program and close any other open programs. 8. Restart the computer. Leave USB plugged in. 9. As soon as the computer restarts, tap the F10 button to enter the BIOS Menu. 10. Scroll to the Boot / Advanced Menu and change the boot order to USB first, HDD second. 11. Save and exit BIOS. Computer will restart. 12. Once booted up the computer will bypass the HDD and boot into the USB 13. elect Ophcrack from the list and hit Enter. 14. Follow the on-screen instructions to have Ophcrack force the password.
(If you're using Linux then use the Linux LIVE CD Image instead of XP)
May 03, 2011 | HP Mini 2140 Notebook
When I turn on my 1120NR mini netbook - all I get is the cursor. Nothing is running. When I first bought it - it started up and worked for about 20 minutes. I have only had it a month.
Hello.
I would strongly suggest that you return this mini to the manufacturer for a replacement. It has not worked correctly. If it was brand-new and only worked for 20 minutes, there is a serious problem. Sounds like a faulty motherboard.
Hope this helps.
Jan 11, 2011 | HP Mini 1120NR PC Notebook
I was given an HP Mini 1120NR netbook as a gift. The system came with Linux OS installed. My system crashed due to a power failure while I was restoring my system and simulatneously charging my battery,...
first error is step on, never install OS with bad or dead battery
rule 1. so why not stop now and do step one right.
if battery is bad it must be removed and replaced.
as most are this old. ,never seen own old battery like this still good.
This LP stink, have one new parked in attic. hated it.
love Linux do but had the slug processor.
1.60 GHz Intel Atom Processor N270
see that processor, its not a real Intel top class processor
its toy grade.
this mini is setup to boot 2 ways
1 is ROM linux inside
and 2, vista?
mine has a rom imbedded Linux in it that runs using alt boot mode.
but is hard coded in the ROM.
called RESIDENT LINUX. (or techs call it Embedded)
is that failing? or the DVD OS failing?>
the note book can have
ROM LINUX (for ever, its in A CHIP, not HDD)
+ boot hdd linux. boot hdd, XP or Vista.
as you can see you could have 2 linux,
one in rom, and newer one in HDD.
but many linux made do not support the silly ATOM processor.
which OSs are you attempting.
why not buy the HP media kit installs.
https://support.hp.com/us-en/drivers/selfservice/hp-mini-1100-pc-series/3875650/model/3860343
here is the driver pages
the media kits are there too.
ask more questions, i played with mine awhile., before parking it.
the claim to fame on this unit
is hDD turned off
boot to rom LINUX and battery lasts 10 hours
can cruse web and read email, on ROM.
very crafty idea but processor is stinker.
maybe ill put in an SSD and see if it can run faster. next winter
Apr 09, 2017 | HP Mini 1120NR PC Notebook
I have an HP mini notebook will not connect.
No problem at all.
Some files of System32 which are important operating system files might have got corrupted.
Take a back-up of all the critical data saved on the computer
Format the whole computer or just format the drive that contains the Windows installed.
Re-install the Windows using the Recovery disc provided by HP.
Immediately install a good combo software including anti-virus, firewall, anti-spyware, anti-rootkit.
Copy back all the saved data. after scanning thoroughly
This is sure to help
Jan 22, 2010 | HP Mini 1000 Netbook
Downloading itunes on hp mini UGH
yes it is possible> go to google> search for the latest Itunes> or else go to the apple website and u wil find the Itunes download> the download is not machine specific so do a normal download
Oct 07, 2009 | HP Computers & Internet
C4400 printer will not install, error 1935 fatal error alert.
Hi Swreardon,
How are you doing?
The issue which you have posted will generally occur if there is a WinTools Easy Installer program on your computer or even it occurs due to corrupted registry.
I can provide you the complete solution but for your clear understanding of the solution and to have a clear view of the solution so that you can easily perform the troubleshooting let me provide you with the weblink which ahs clear instructions:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00292756&cc=us&lc=en&dlc=en
Before using above weblink make sure you perform the steps below :
Step 1: Insert the HP printer software CD in the CD drive and folllow the steps:
If operating system is XP, Start>>run>> type" X:/util/ccc/uninstall_L3.exe and click OK. (where X is the Cd drive ) and follow the onscreen instructions.
If the operating system is Vista: open run window and type: " X:/util/ccc/uninstall_L3.exe" and click OK. (where X is the Cd drive ) and follow the onscreen instructions.
Here are the multiple steps to open run window in vista:
1. Press Windows Key + R to open the Run command window.
1. Open the Start Menu.
2. Click All Programs.
3. Click Accessories.
4. Run shortcut is located here by default.
Step 2: restart the computer and follow the steps given in the weblink above:
Step 3: once everything is completed download nad install the software by clicking on the weblink below:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&product=3655574 (For XP)
and use this link for Vista: http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-57266-3&lc=en&dlc=en&cc=us&os=2093&product=3655574
Do not use the CD.
I am sure the issue will be resolved.
Best of luck.
Oct 25, 2008 | HP Office Equipment & Supplies
Open Questions:
Get your wife husband back lost love spells caster in city of New York +27832762854 Have you ever been in a failed relationship? Did you often feel like your partner didn't 'get' you? Are you having many obstacles in your life? Is your love life falling apart? Is your life facing financial ruin? Do you need protection from your enemies? If you seek a lost lover, or want a new lover, we can help. We reunite lost lover`s If you are really in love with someone then this is the spell for you. divorce affairs all kind of witchcrafts bring back lost love spells in NHL Eastern Conference bring back lost love spells in Boston Bruins bring back lost love spells in Buffalo Sabres bring back lost love spells in Carolina Hurricanes bring back lost love spells in Columbus Blue Jackets bring back lost love spells in Detroit Red Wings bring back lost love spells in Florida Panthers bring back lost love spells in Montreal Canadiens bring back lost love spells in New Jersey Devils bring back lost love spells in New York Islanders bring back lost love spells in New York Rangers bring back lost love spells in Ottawa Senators bring back lost love spells in Philadelphia Flyers bring back lost love spells in Pittsburgh Penguins bring back lost love spells in Tampa Bay Lightning bring back lost love spells in Toronto Maple Leafs bring back lost love spells in Washington Capitals bring back lost love spells in Western Conference bring back lost love spells in Anaheim Ducks bring back lost love spells in Arizona Coyotes bring back lost love spells in Calgary Flames bring back lost love spells in Colorado Avalanche bring back lost love spells in Chicago Blackhawks bring back lost love spells in Dallas Stars bring back lost love spells in Edmonton Oilers bring back lost love spells in Los Angeles Kings bring back lost love spells in Minnesota Wild bring back lost love spells in Nashville Predators bring back lost love spells in San Jose Sharks bring back lost love spells in St. Louis Blues bring back lost love spells in Vancouver Canucks bring back lost love spells in Vegas Golden Knights bring back lost love spells in Winnipeg Jets bring back lost love spells in NBA Eastern Conference bring back lost love spells in Atlanta Hawks bring back lost love spells in Boston Celtics bring back lost love spells in Brooklyn Nets bring back lost love spells in Charlotte Hornets bring back lost love spells in Chicago Bulls bring back lost love spells in Cleveland Cavaliers bring back lost love spells in Detroit Pistons bring back lost love spells in Indiana Pacers bring back lost love spells in Miami Heat bring back lost love spells in Milwaukee Bucks bring back lost love spells in New York Knicks bring back lost love spells in Orlando Magic bring back lost love spells in Philadelphia 76ers bring back lost love spells in Toronto Raptors bring back lost love spells in Washington Wizards bring back lost love spells in Western Conference bring back lost love spells in Dallas Mavericks bring back lost love spells in Denver Nuggets bring back lost love spells in Golden State Warriors bring back lost love spells in Houston Rockets bring back lost love spells in Los Angeles Clippers bring back lost love spells in Los Angeles Lakers bring back lost love spells in Memphis Grizzlies bring back lost love spells in Minnesota Timberwolves bring back lost love spells in New Orleans Pelicans bring back lost love spells in Oklahoma City Thunder bring back lost love spells in Phoenix Suns bring back lost love spells in Portland Trail Blazers bring back lost love spells in Sacramento Kings bring back lost love spells in San Antonio Spurs bring back lost love spells in Utah Jazz bring back lost love spells in NCCA bring back lost love spells in Air Force Falcons bring back lost love spells in Alabama Crimson Tide bring back lost love spells in Arizona State Sun Devils bring back lost love spells in Arizona Wildcats bring back lost love spells in Arkansas Razorbacks bring back lost love spells in Army West Point Black Knights bring back lost love spells in Auburn Tigers bring back lost love spells in Baylor Bears bring back lost love spells in Boston College Eagles bring back lost love spells in BYU Cougars bring back lost love spells in California Golden Bears bring back lost love spells in Clemson Tigers bring back lost love spells in Colorado Buffaloes bring back lost love spells in Florida Gators bring back lost love spells in Florida State Seminoles bring back lost love spells in Fresno State Bulldogs bring back lost love spells in Georgia Bulldogs bring back lost love spells in Georgia Tech Yellow Jackets bring back lost love spells in Houston Cougars bring back lost love spells in Illinois Fighting Illini bring back lost love spells in Indiana Hoosiers bring back lost love spells in Iowa Hawkeyes bring back lost love spells in Iowa State Cyclones bring back lost love spells in Kansas Jayhawks bring back lost love spells in Kansas State Wildcats bring back lost love spells in Kentucky Wildcats bring back lost love spells in Louisville Cardinals bring back lost love spells in LSU Tigers bring back lost love spells in Maryland Terrapins bring back lost love spells in Miami Hurricanes bring back lost love spells in Michigan State Spartans bring back lost love spells in Michigan Wolverines bring back lost love spells in Minnesota Golden Gophers bring back lost love spells in Mississippi Rebels bring back lost love spells in Mississippi State Bulldogs bring back lost love spells in Missouri Tigers bring back lost love spells in Navy Midshipmen bring back lost love spells in Nebraska Cornhuskers bring back lost love spells in North Carolina State Wolfpack bring back lost love spells in North Carolina Tar Heels bring back lost love spells in Northwestern Wildcats bring back lost love spells in Notre Dame Fighting Irish bring back lost love spells in Ohio State Buckeyes bring back lost love spells in Oklahoma Sooners bring back lost love spells in Oklahoma State Cowboys bring back lost love spells in Oregon Ducks bring back lost love spells in Oregon State Beavers bring back lost love spells in Penn State Nittany Lions bring back lost love spells in Pittsburgh Panthers bring back lost love spells in Rutgers Scarlet Knights bring back lost love spells in South Carolina Gamecocks bring back lost love spells in South Florida Bulls bring back lost love spells in Southern Methodist SMU Mustangs bring back lost love spells in Stanford Cardinal bring back lost love spells in TCU Horned Frogs bring back lost love spells in Tennessee Volunteers bring back lost love spells in Texas A&M Aggies bring back lost love spells in Texas Longhorns bring back lost love spells in Texas Tech Red Raiders bring back lost love spells in UCLA Bruins bring back lost love spells in USC Trojans bring back lost love spells in Utah Utes bring back lost love spells in Vanderbilt Commodores bring back lost love spells in Virginia Tech Hokies bring back lost love spells in Washington Huskies bring back lost love spells in Washington State Cougars bring back lost love spells in West Virginia bring back lost love spells in NFL AFC bring back lost love spells in Baltimore Ravens bring back lost love spells in Buffalo Bills bring back lost love spells in Cincinnati Bengals bring back lost love spells in Cleveland Browns bring back lost love spells in Denver Broncos bring back lost love spells in Houston Texans bring back lost love spells in Indianapolis Colts bring back lost love spells in Jacksonville Jaguars bring back lost love spells in Kansas City Chiefs bring back lost love spells in Los Angeles Chargers bring back lost love spells in Miami Dolphins bring back lost love spells in New England Patriots bring back lost love spells in New York Jets bring back lost love spells in Oakland Raiders bring back lost love spells in Pittsburgh Steelers bring back lost love spells in Tennessee Titans bring back lost love spells in Super Bowl LII bring back lost love spells in NFC bring back lost love spells in Arizona Cardinals bring back lost love spells in Atlanta Falcons bring back lost love spells in Carolina Panthers bring back lost love spells in Chicago Bears bring back lost love spells in Dallas Cowboys bring back lost love spells in Detroit Lions bring back lost love spells in Green Bay Packers bring back lost love spells in Los Angeles Rams bring back lost love spells in Minnesota Vikings bring back lost love spells in New Orleans Saints bring back lost love spells in New York Giants bring back lost love spells in Philadelphia Eagles bring back lost love spells in San Francisco 49ers bring back lost love spells in Seattle Seahawks bring back lost love spells in Tampa Bay Buccaneers bring back lost love spells in Washington Redskins bring back lost love spells in MLB bring back lost love spells in AMERICAN LEAGUE EAST bring back lost love spells in Baltimore Orioles bring back lost love spells in Boston Red Sox bring back lost love spells in New York Yankees bring back lost love spells in Tampa Bay Rays bring back lost love spells in Toronto Blue Jays bring back lost love spells in AMERICAN LEAGUE CENTRAL bring back lost love spells in Chicago White Sox bring back lost love spells in Cleveland Indians bring back lost love spells in Detroit Tigers bring back lost love spells in Minnesota Twins bring back lost love spells in Kansas City Royals bring back lost love spells in AMERICAN LEAGUE WEST bring back lost love spells in Houston Astros bring back lost love spells in Los Angeles Angels bring back lost love spells in Oakland Athletics bring back lost love spells in Seattle Mariners bring back lost love spells in Texas Rangers bring back lost love spells in NATIONAL LEAGUE EAST bring back lost love spells in Atlanta Braves bring back lost love spells in Miami Marlins bring back lost love spells in New York Mets bring back lost love spells in Philadelphia Phillies bring back lost love spells in Washington Nationals bring back lost love spells in NATIONAL LEAGUE CENTRAL bring back lost love spells in Chicago Cubs bring back lost love spells in Cincinnati Reds bring back lost love spells in Milwaukee Brewers bring back lost love spells in Pittsburgh Pirates bring back lost love spells in St. Louis Cardinals bring back lost love spells in NATIONAL LEAGUE WEST bring back lost love spells in Arizona Diamondbacks bring back lost love spells in Colorado Rockies bring back lost love spells in Los Angeles Dodgers bring back lost love spells in San Diego Padres bring back lost love spells in San Francisco Giants
Aug 20, 2018 | Sun Computers & Internet
Computers & Internet Logo
74 people viewed this question
Alun Cox
David Payne
David Payne
