Kleenmaid top loader Washing Machine Mod KAW 793W leaking
Machine leaks from bottom during washing cycle
Problem turned out to be a leak from the top, not the bottom and was caused by debris blocking an overflow trap
Posted on Aug 07, 2008
My Kleenmaid washing machine leaks Crease during whashing.
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Replacing Door seal: http://www.espares.co.uk/advice/washing-machines/a/7/1464/how-to-replace-the-door-seal-on-a-washing-mac.html
Feb 27, 2013 | Washing Machines
Washing machine is leaking from the bottom of the machine and leaking after the wash cycle inside. 622797 style no. The machine leaks during the rinse cycle from the bottom.
Washing machine is leaking from the bottom This video will show you how to find the leak on your washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jun 07, 2011 | KitchenAid Washing Machines
Kleenmaid top-load washing m/c leaks water and then smokes!
It sounds like you are leaking from the bottom of the unit. If you are leaking at the top then you need to check the water inlet valves, and also the drain pump and all water hoses. This doesnt sound like a seal issue.
Jan 02, 2010 | Washing Machines
Leaking water in washing machine
Front loader or Top Loader? If front loader you probably put to much in and at spin cycle the tub hit the hose to the pump and possibly got knocked off?
Oct 16, 2009 | Washing Machines
AEG 6200 Washing machine punping water out of the
Please have the mechanical seal at the bottom
replaced. It is already leaking.
Sep 23, 2009 | Washing Machines
GE washing machine leaks at bottom
If this machine has a place to put pour fabric softener in that's sits under the lid on the cabinet? If so, the hose that allows the softener drain into the tub is either leaking or is disconnected.
Please rate this solution if helpful
Aug 20, 2009 | GE Washing Machines
Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Sep 07, 2007 | Maytag MAT13MN Top Load Washer
Washing Machines Logo
517 people viewed this question
Top Washing Machines Experts
