FRIGIDAIRE WINDOW A/C UNIT COMES ON BUT FAN DOES NOT RUN
  • 17,130 Answers
Possible failure of the fan motor or the capacitor to the motor. It will be good to test the voltage on the fan motor at the time of the AC start- when the compressor is running. If there is no supply it can be fault in the switch of the fan control.
If not as mentioned the fault can be due to the motor burn out or a faulty capacitor.
Posted on Mar 22, 2011
I"mworking on a frigidaire french door. Model LGHN2844MFO The evap fan would not run until I unplugged unit
Electrical fan motors cannot run without electricity. The fan ran while it was unplugged? Please expand on the problem description.
Nov 01, 2016 | Frigidaire Refrigerators
Frigidaire AC window unit, model fam185r2a (18,500 BTU) only cools for a few minutes before it cycles off and just fan blows. Then a few min later cool air cycles back on. Is this a thermostat issue?
The window units normally have a sensor thats attached to the front of the indoor coil. This controls the thermostat. I usually pull this sensor away from the coil because it stops cooling before the room is cool. It is attached to the cold coil so it senses the coil temp, not the room temp. You can normally see it when you remove the air filter. Don't break it! It may be a wire or small copper tube
Jun 10, 2015 | Frigidaire Heating & Cooling
I HAVE ICE SHOOTING FROM MY A/C UNIT
If this is a window unit then make sure the water is draining all out and don't run the unit on low the slower the fan speed the the colder the coil temp which on low usually the coil temp will get down to 32 deg which will form ice.
Jun 15, 2014 | Frigidaire FAK104R1V 10000 BTU Portable...
My fan wonT shut off
Good Morning Judy,
I understand that the fan will not shut off on your Frigidaire air conditioning and heat, air conditioner, model# LRA18HMT2, even when you have turned your appliance completely off. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit break, for 3-5 minutes. When power is restored, turn your air conditioner to any cycle and let it run for 5 minutes before turning it off. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 14, 2014 | Frigidaire Heating & Cooling
Frigidaire window air conditioner, new, fan won't run
slide out and spin blade by hand. should be able to tell if anything restricting rotation
May 05, 2013 | Dometic Rooftop RV Air Conditioner
Frigidaire window air condition unit
Hello,Lilo The styrofoam pack MUST stay in place.When in operation the air tempature is so cold the unit will condensate(create water)if not insluated.Your unit would LEAK all over the place.The blower fan is a PLASTIC composit and should not rust.
Apr 24, 2010 | Frigidaire FAC126P1 wall/window Air...
No more cooling.
check filters and depending on how new the unit is they dont operate as cold as the older units did
May 17, 2009 | Frigidaire FAA065P7A Thru-Wall/Window Air...
Frigidaire 12000 BTU A/C window unit
The reason that it's doing that is b/c at first its running only with the fan butwhen the compressor clicks on it trips the breaker if you have other items running off that circuit "unplug them" [even turned off items can still consume some power]. Then try to running only the ac unit see if it works a 12000btu takes a lot to run, if this doesn't work the ac may be to much for your circuit to handle and a smaller unit may be needed.
Aug 06, 2008 | Frigidaire FAA065M7A Air Conditioner
Heating & Cooling Logo
42 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
