Question about Sony Lbt-lcd7di Audio Shelf System
I have a sony hi fi component system LBT-LCD7Di it wont't turn on at all all it does it flashes the on and off button. i unplugged it and plugged it back on but still it does the same thing nothing turns on. i did the troubleshooting but it still doesn't work.
    Brigadier General:
  • 8,546 Answers
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Mar 22, 2011
How do you reset the system.
To reset the component Hi-Fi stereo system to factory settings.
  1. On the stereo system, on DECK B , press and hold the STOP button.
  2. While holding the STOP button, press and hold the TUNER ENTER button.
  3. While holding the STOP button and TUNER ENTER button, press the POWER button.
  4. Unplug the power cord from the electrical wall outlet.
  5. Plug the power cord back into the electrical wall outlet.
  6. Turn on the stereo system.
Sep 30, 2014 | Sony STR-DA3000ES Receiver
My sony hi-fi lbt-sh2000 component sound volume does not increase after long hours playing
example you play music high base and thin you give a high volume.have a automatic sensor inside the player to low the high base.
Feb 06, 2013 | Sony Main Body Of Lbt-Sh2000
Sony LBT W5000
According to Page 46 of the LBT-W5000 Operating Instructions:
"The display stars flashing as soon as you plug in the power cord even though you haven't turned on the system (demonstration mode).
Press DISPLAY (for LBT-W5000 / W300 / XB700 / XB500) or DEMO (STANDBY) (for other models) while the system is off. If the system is in the Power Saving mode, press POWER SAVE / DEMO (STANDBY) (for LBT-W5000 / W300 / XB700 / XB500). The demonstration appears automatically the first time you plug in the power cord, or if there is a power outage lasting longer than half a day."
I tested this today, as my LBT-W5000 was in Demonstration Mode. It definitely works. The only catch is (at least on the W5000), and it's a minor one, you have to reset your clock afterwards.
May 29, 2009 | Sony LBT-W5000 Shelf System
Sony Mini Hi-Fi Component System (MHC-RG660)
I understand the problem. It should be the relay which is not responding, technically not able to connect the system power supply, you will have to replace the relay. The STK chip should be working fine.
Aug 26, 2008 | Audio Players & Recorders
P-301 onkyo pre-amp
Hi juicer, If you use the switched outlet, then everything will be turned on/off when you operate the preamp power switch. Use the unswitched, then you have to turn off each unit separately. You choose which one you want. It wont matter.
What connection do you intend to use to connect the LBT zx6 to the Onkyo preamp??
Mar 20, 2008 | Audio Players & Recorders
Sony LBT W5000
when the hi-fi is off and there is the sony demo push "display" on your remote.. yep yep. peace
Oct 06, 2007 | Sony LBT-W5000 Shelf System
Sony Lbt-lcd7di Audio Shelf System Logo
91 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
