Question about HP Deskjet F4180 All-in-One InkJet Printer
Everytime I go to print a document, it won't print. I go to open all active printers and it has documents I've tried to print in the past that didn't end up printing, and I go to delete or cancel the document to clear it and it won't do it. And then it says error.
    Scholar:
  • 80 Answers
1. make sure to check if the hardware is able to make color copies, that way u can be sure there is no harware issue. 2. You can download and run an HP utility tool that can help you fix the problem instantly from this page: http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?cc=us&lc=en&lang=en&softwareitem=mp-91788-1 3. If you still get the same issue, restart the computer and check the print queue. If there are no print jobs in the queue, you resolved the issue. 4. If print jobs remain in the queue, check the connection between the HP printer and the computer, make sure USB is properly seated if its a USB connection, otherwise if it's wireless, make sure both devices are connected to the network. 5.If issue still persists,make sure the printer is set to online. 6.Manually clear the print queue, restart the comp then try printing again. &. If #6 doesn't resolve the issue.Restart the print spooler by clicking on Control Panel, then double-click Administrative Tools .Double-click Services--In the list of Services , double-click Print Spooler . The Print Spooler Properties window opens, then click Stop to stop the Print Spooler. Click Start to restart the Print Spooler.Click OK and restart the computer.Try printing again. 8. If print jobs from one specific software program are getting stuck in the print queue, the issue might be with the software program or the print driver.Close the software program from which you are trying to print, and then open it again.Print a document from the software program.If the print job gets stuck in the print queue again, try printing a document from Notepad to determine whether the problem is with the program or the driver.Repeat the steps earlier in this document to manually clear the print queue.Type a test message in Notepad and print it, making sure you select your HP product as the printer. If you can print the document from Notepad, but not from the software program, contact the software program manufacturer for assistance.If these steps resolved the issue , you do not need to continue troubleshooting. 9. Remove and Reinstall HP software, then try printing again. If these steps resolved the issue , you do not need to continue troubleshooting. If the issue persists , continue to the next solution. 10. A power reset drains the power from the product and returns to the same settings after restarting. A power reset is a common troubleshooting step, and you can perform one for conditions like print jobs getting stuck in the queue. With the product turned on , disconnect the power cord from the rear of the product.Unplug the power cord from the wall outlet.Wait at least 15 seconds.Plug the power cord back into the wall outlet.Reconnect the power cord to the rear of the product.If the product does not turn on by itself, press the Power button to turn it on. 11. If you have tried all of the preceding solutions in the order presented , and the issue is not resolved, try HP forums.
Posted on Mar 30, 2011
Everytime I copy from the adf top feeder, I get a black line running down the copy. I've cleaned, reset, etc., and I sitll get the black line every time. Help!!!???
CClean The MX882 ADF (Automatic Document Feeder)
Be sure to turn off the power and unplug the power cord before cleaning the machine.
  • The power cannot be turned off while the machine is sending or receiving a fax, or when the received fax or unsent fax are stored in the machine's memory. Make sure if the machine completed sending or receiving all the faxes before disconnecting the power cord.
  • The machine cannot send or receive faxes when the power is turned off.
  • If you unplug the power cord, all the faxes stored in the machine's memory will be deleted.
    Print the necessary faxes or save them to the memory card/USB flash drive before unplugging the power cord.
  1. Open the Document Tray.
  2. Open the Document Feeder Cover.
  3. With a soft, clean, lint-free and dry cloth, wipe off any paper dust from the inside of the Document Feeder Cover (A).
  4. After wiping, close the Document Feeder Cover by pushing it until it clicks into place.
  5. Close the Document Tray. speed printer service
    http://www.smoothprinterservice.com/
Dec 18, 2012 | Canon MX882 All-In-One InkJet Printer
I just replaced 2 of the ink cartridges, and now the printer isn't printing anything at all on the paper. I ran the clean printerhead function, and it printed the results of that. But, when I go to...
Make sure the problem isnt with the PC, print a document but dont send it to the printer, print it to a document(it will be listed as shown here)d_schrute_3.png
If the document contains the text/pictures you wanted to print then the job is spooling properly. Make sure your printer drivers are up to date by downloading the latest from HP Customer Care. Also try copying what you want or screen shotting it and pasting it into word or another program like paint or notepad.
Aug 20, 2011 | HP Officejet 6500 Wireless All-in-One...
My Dell V505 printer won't print documents from the computer, when I press print the printer prints a page of dash's and ticks. there is ink in the cartridges. i've disconnected the power....
Turn the printer off.
Disconnect the AC power.
On your computer, click Start
Click Control Panel
Click Printers
Select the Dell Printer
Uninstall it
Restart your computer
Turn the printer on
Allow the computer to reinstall the device-device for the printer.
Print a test page.
May 09, 2011 | Dell AllinOne Multifunctional (v515w)...
When printing, sentences over lap so the document is unreadable. Also it may only print the first line of a document.
I've seen word documents do this sometimes and fixing it has worked differently each time.
1) Open the document and press CTRL + A (select all) on the keyboard and then CTRL + C (copy), then start a new document and press CTRL + V (paste). Save the new document as something different and try printing again.
2) Open the document again and select all and copy again,but this time open wordpad (a different program to Microsoft Word) by going to Start > Programs > Accessories > Wordpad, and paste the text into wordpad. This may change some of the formatting. Now, select all again, and copy, and start a new word document and paste.
Copying the text out of word and back in seems to work more often. Sometimes the best program to copy out to is notepad, but you lose pretty much all of the formatting when you copy back into word.
3) If this doesn't work, you could try to update your printer drivers, and if that doesn't work, as a last resort, you can delete the printer and create it again via the Control Panel > Printers.
May 04, 2011 | Office Equipment & Supplies
Authorware Printscreen doesnt print actual document fullsize
Try printing document thru your printer rather than Printscreen feature. Or Printscreen feature copies to clip board which you should be able to open and paste to new document then use your printer set up to adjust. Make sure your printer set up is set to scale to fit page.
Aug 24, 2009 | Adobe Macromedia Authorware 7 Full Version...
I can't print image. I have a BMP image, and I want to print this image. How can I do that?
Try copying and pasting the bmp image into a (Word) document. (Other applications such as powerpoint and graphics programs would also work). After resizing the image you should be able to print this document.
Step by step... open the bmp image with an application such as Paint. Do a Select All, then a Copy; open up Word, and Paste into the document. Then resize the bitmap within Word.
Jul 09, 2009 | Datamax I-4208 Thermal Label Printer
Printer DeskJet 820Cse didn`t work
test page printing but doc files not printing....
HP DeskJet 6940
Sep 26, 2008 | HP Deskjet 6940 InkJet Printer
HP Deskjet F4180 All-in-One InkJet Printer Logo
137 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
