I have a Teac SDB440 set top box. when powered up, the power light blinks nonstop. please advice. Thanks. Dihan.
SOURCE: JVC 42 INCH PLASMA POWER LIGHT BLINKING ONLY NO PICTURE
sound like you have a problem w/ your tuner or your unit in had protect itself
Posted on Jan 25, 2007
Slinteriors
  • 8617 Answers
SOURCE: remotes
Heres the link to phillips universal remotes this should have the info you need.
http://www.universal-remote.net/philipsmagnavox.html
Posted on Apr 09, 2008
SOURCE: idigital RM-810 universal remote code to suit Teac SDB440
http://www.chunghop.com/en/products_view.asp?id=302 contact the manufacter
Posted on Aug 24, 2009
SOURCE: DVB820 set top box error message
check C14, C15 and 278R33 (3.3V supply. cheers
Posted on Feb 23, 2010
eagle338
  • 4889 Answers
SOURCE: Sony KDL-40V4100 when turned off
Can you please count the number of blinks in between each pause so that I can tell you what the problem is? Its a self-diagnostic error code that makes the diagnosis a lot easier
Posted on Mar 25, 2011
I am unable to find the owners manual for the Teac MC-DV100 SuybWoofer
For almost any set-top box, there isn't a sub-woofer output. Without that output (it would be labeled on the STB), you can't hook up a subwoofer directly to it.
HOWEVER, the model number you give isn't just a subwoofer: it's a whole sound system with a subwoofer attached to it. If you have the whole sound system, you just hook the STB's audio output to the amplifier's "Aux Input" (it might also be called "line input").
If your model doesn't have that (can't tell from the web), you'd have to buy an "AV Receiver" that has at least a 5.1 set of outputs. These start at maybe $150 new, $50 on eBay. MAKE SURE YOU BUY A RECEIVER WITH A "powered" SUBWOOFER OUTPUT!! You connect the receiver to the STB, and the subwoofer to the receiver.
Jul 15, 2015 | Teac Audio Players & Recorders
I have a Aquos LC-37GP1U new out of box. Have the blinking light issue. Power on for 2 seconds and then shut off. Replaced the power supply board as it was cracked. Still didn't help. Should I be...
You have to check if the replacement power supply board is the same part no. as the original one, it is printed on the board itself.
I don't think that the fault came from defective electrolytic capacitor because like what you have said, the unit is new out of the box and you've already replaced the power supply board which is most of faulty electrolytic capacitor came from that board.
You've mentioned also that the original power supply board has cracked, I've suspected that the main board also has been damaged because the blinking led light error codes will be encountered if the power supply board or main board gone to malfunction. If you've confirm that the power supply board is the same part no. like the original one, then I would advice you to replaced the main board.
Please let me know if you need further assistance.
Have a great day!
Mjsazon
Nov 27, 2011 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
I have no power, i called a repair man, he said unplug it then push the reset button...i get a blinking green light for a few seconds...now what?
The set if it has a DM unit when unplugged should blink for 70 seconds and allow you to turn on.
If it does not, if when you try to turn on green light comes on and goes off---do the self check:
Press and hold both the menu and input buttons for 5 seconds and release both; power light should blink a two digit error code at least 5 times. 2 blinks, pause and 2 blinks is the most common.
If the set has a reset button on the front it has a DM unit---built in receiver--even if it fails the green power light will blink nonstop.
Again, if you try to turn on and green power light comes on and then goes off---do the self check and let me know what you find.
If this information was helpful rate this solution as "very helpful" as I do this here for free.
Also let me know what you do or do not find as I am here to help you.
REGARDS, SD TECH
Aug 11, 2010 | Mitsubishi WS-65511 65" Rear Projection...
I have a digital set top box model teac dv-b800.this unit now has a flashing c-100 code has soon has you power same up and nothing else.Can you tell me the problem.
appears to be a known issue with your model of set top box and teac is aware of the issue, but will only repair for free if you are within your 12 month warranty period, if you are outside warranty, consider repairs as they are approx 60.00 and the fix appears to resolve the issue.
Cheers!
Feb 14, 2010 | Audio Players & Recorders
Mar 10, 2009 | Televison & Video
Replacement Power Chord and Black Grill top/back Teac A-3440
service info here:
http://www.hifiengine.com/manuals/TEAC/A-3440.shtml
Join the reeltoreel group on Yahoo groups . There's abunch of guys that might be able to help you find parts.
Please rate my help if you could.
Thanks
Jan 24, 2009 | Audio Players & Recorders
Kv-32s120 standby LED blinking no sound or picture
How many times does the timer light flash between pauses?
Sep 05, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Set to box problem
Where did you grab the firmware for it? I can't find it anywhere!
Aug 30, 2008 | Teac Audio Players & Recorders
Remotes
Apr 09, 2008 | Televison & Video
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
