Question about Roland Boss CS-3 Compression Sustainer Pedal
Hello, My Boss CS-3 Compression Sustainer pedal is having issues. I bought it around 6 months ago. When I first discovered the problem, it didn't work at all when turned on. It just made this feedback noise and I noticed this noise was only affected by the "sustain" knob"... A few days later I tried it again and it "did" work but with a fuzzy distorted sound when I pick a little hard on my guitar (Again only affected by the "sustain" knob) I checked everything from cables to batteries. I even tried it with a power supply with the same result. Thanks in advance.
  • Roland Master
  • 5,603 Answers
Make sure you use Alkaline battery and NOT rechargeable type... the rechargeable battery will NOT work in the pedals (their voltage is lower even though they are labeled as 9 volt replacement).
Other internal problems can be due to cracked circuit board or broken solder joints. These are very common as people step on the cables when plugged in. This breaks the connection inside. A fuzzy sound often occurs when one of the contacts is marginal due to bad solder at the jack terminals.
Posted on Mar 22, 2011
Testimonial: "Thanks"
2 Suggested Answers
Clasty
  • 33 Answers
SOURCE: how to set up foot switch in order
Personally I recommend the following set up:
Distortion>Effects>Compression/Noisegates/Sustain
This will ensure that the signal won't have any odd hiccups due to an odd pedal setup. But if you play around with different orders, you can end up with some very interested sounds.
Posted on Nov 24, 2009
Testimonial: "thanks u much ..."
What does bt mean on my ME70
we had the same thing happen and discovered it was low batteries
Feb 02, 2013 | Boss ME-70 Guitar Multiple Effects Pedal
Why is my vintage boss dd-3 very quiet on the repeats even when level is turned up full?
Assuming you have the feedback level turned up....can you hear any difference at all when adjusting the feedback?
Aug 17, 2012 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
Just bought a ps-6 today, tried it through my overall set up the pitch shifter, detuner & super bend are fine, as soon as i use the harmony setting it takes a sweet medium gain lead sound and adds the...
By ading in the harmony signals you are combining 3 signals so gain is probably going to be high you will have to reduce it before it goes to the amp or turn down the input gain of the amp.
NEVER use a pedal in the external effects loop of an amp as the levels are wrong.
Jul 26, 2011 | Roland Boss PS-6 Harmonist Pedal
I actually use boss ml 2.. it works just fine for the past few month. but all of a sudden now. its just wont work. i even change the batteries. what happen was. while i was playing. it suddenly shuts off...
The first thing I would do would try a 9V AC Adapter to rule out a battery issue completely. But if you have changed the battery already, this shouldn't be the issue. Does the red light come on at all? The next thing I would check involves removing the back cover of the pedal and making sure the input/output jacks are okay. Do you see any hanging wires, loose solder, or smell a burnt smell? If you have only had this pedal for a few months, you may be able to send it back to BOSS for replacement under your warranty.
Mar 04, 2011 | Boss Mt 2 Metal Zone Effects Pedal
Distorts my sound
The problem is probably due to the output level being to loud, thus distorting the unit following the CS-3. (other pedal or amp). Try backing down on the level knob.
Hope that helps!
Mar 04, 2011 | Roland Boss CS-3 Compression Sustainer...
My DD3 pedal doesn't work. Checked the battery and the adapter. The light won't go on it will only light momentarily when I click through the modes. Any help would be appreciated. Greg
Check all connections including the battery clip if you use a battery, and the adapter jack if you use the AC adapter. Also check you guitar cable connections as the pedal turns itself off if the guitar plugs have a loose connection. Make sure the guitar jacks on the sides are tight and don't need tightening. Any of those issues could cause the pedal to operate sporadically or not at all.
It could also be and IC problem internally on the pedal's circuit board, but before you open anything, check all the connections non electrical issues can occur more often on pedals.
Feb 19, 2011 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
I recently bought a Korg Pitchblack Tuner. It tunes correctly, (maybe a little slower than my Boss) but it will not power other pedals with the daisy chain. I am using a standard Boss wall wart which...
The tuner uses around 500 ma which may be nearly all your wall wart can put out... DO NOT overload the power adapter by daisy chaining other pedal power loads on it.
Feb 08, 2011 | Korg pitchblack + Tuner
How to set up foot switch in order
Nov 24, 2009 | Boss Mt 2 Metal Zone Effects Pedal
How to set up with amp and distortion pedal
With everything switched off. I will surmise that you are using the onboard battery with the foot pedal and not a power supply.
1. Plug lead from guitar/instrument into INPUT side of pedal
2. Plug lead from OUTPUT side of pedal into amplifier INPUT.
3. Turn amplifier volume to about 10 o'clock - to stop blowing your ears out.
4. Turn volume up on guitar to acceptable level.
5. press foot switch on pedal and adjust pedal controls to suit your type of distortion.
6. Play like Hendrix.
Good Luck
ps Just as an after thought rechargeable 9volt batteries are the way to go. I've been using them for years as I always get caught up in the power cable.
If you're going to add another pedal like a Phaser, Compressor, Flanger or what just use small connect leads between each pedal but always, always put the compressor pedal last in the line.
Sep 12, 2009 | BOSS AUDIO SYSTEMS Boss Ns2 Noise...
Boss digital delay pedal DD-3 won't stay on
I have seen a somewhat similar problem before. A switching diode had become faulty and needed replacement. I have no way of telling you where to look but if you have a volt ohm meter you can test them individually without removing them. The diode you are looking for would be in the circuit which connects to the switch. Use your probes to get a reading in one direction(one probe on each end of the diode) and then a reading with the probes reversed. If the readings are close or infinite in both directions you will want to unsolder the diode (making careful note of its orientation) and test it again. If the readings are still the same or close you will need to replace the diode. I forgot to mention to use the 2000 ohms resistance scale or the diode test function if you have one. Hope this helps.
May 03, 2009 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
Roland Boss CS-3 Compression Sustainer Pedal Logo
489 people viewed this question
Top Roland Music Experts
Michial Gueffroy
Alex McGaughan
Alex McGaughan
Level 1 Expert
Are you a Roland Music Expert? Answer questions, earn points and help others
