Question about Dishwashers
The lights on the front panel are flashing - Dishwashers
  • 55 Answers
Try flipping the breaker off for several minutes. This may reset the electronic glitch the dishwasher is having. If that does not work you can try to remove the ribbon cable from the touch pad and clean it with an eraser. Often times this will fix this type of issue. If that does not work, the touch pad would probably need to be replaced.
Appliance & Refrigerator Repair
Posted on Mar 22, 2011
What do flashing lights on the front mean?
ever consider paying a repair place to fix.
Jan 16, 2015 | Televison & Video
When I turn on the tv all i get is the welcome screen, and it will not go any futher,there is green light flashing in front of the tv. and it will not turn off with the remote, i have to unplug it.
Hi Andre,
May I know if the LED light at the front panel has a pattern of flashes or flashing continuously in green color.
Please check if you can access the "Self diagnostic screen" by following the steps below.
- To activate, press the front panel "Activity" and "Channel down" buttons at the same time and hold for 5 secs. The Status led will then flash a two digit code. Example, if the error code is "23" the led light flashes 2 times(blink, blink) pause and then flash 3 times(blink, blink, blink). Let me know the error code to narrow down, it will help to diagnose where the fault came from.
Note : the TV must be in shutdown not switched off, or AC power cord is removed because the code will reset to "12" means no error. Use the front panel buttons not on the remote control. If you can't access the self diagnostic, press and hold the "Activity" button on the front panel for 5 secs before entering the "self diagnostic" code.
Regards,
Jdvillanueva
Nov 24, 2011 | Mitsubishi WD-60737 TV
Light on front panel is flashing red. In standby
The power supply has failed on your LCD and will need to be replace or repair.
Check the info from the link below if you're DIY. I could also repair it for you.
Let me know if you require further assistance.
http://www.fixya.com/support/t3771079-lct2701td_t_v_will_not_turn_only
May 21, 2010 | Akai LCT2701TD Television
Maytag Jetclean Dishwasher EQ Plus - Lights flashing
either the control board or the control panel needs replacement. Most likely the latter. There is a possibility that both parts failed also. Usually water gets inside the touchpad, corroding and shorting the touchpad. Good luck
Mar 03, 2010 | Dishwashers
Red light and 2 green lights on front panel on.
This is an error code it means the TV is in protection mode. Which means it has detected a problem and is preventing power up so not to cause further damage. Error codes are generally 2 numbers 1 seq of flashes a pause and a second sequence of flashes. Most common problems for LCD are Video logic / Main input board or the power supply. For more info and possible solutions post your make and model.
For parts and info check.
http://www.RNS-Systems.com
or E-bay
Oct 20, 2009 | Televison & Video
Light keeps fashing for cartridge
Here is something to try:
1. Make sure the new kit is installed and the printer is turned ON.
2. Open the front panel.
3. Hold the Cancel button in until the front panel LEDs flash.
4. Close the front panel
Sep 29, 2009 | Lexmark E250d Laser Printer
All the lights on front panel on my frigidaire FEQBB30DS0 dryer
Sounds like one of the buttons is stuck. You may have to replace the touch keys panel
Sep 04, 2009 | Dryers
Light are flashing
Can you tell me exactly how the lights are flashing. This flashing is a code that will tell me whats wrong witht he printer.
Thanks,
Brad Nelson
Mar 15, 2008 | HP PSC 1510 InkJet Printer
Flashing LEDs
When doing some floor work, I had taken off the front bottom panel of the dishwasher and there was a pamphlet which had electronic information. Dummy me threw it away, but I remember it had code information on it. I am now having this flashing light problem. So check behind the front bottom panel (remove the 4 screws to get behind it) and the piece of paper should be in there. Please let me know if you find it!
Jan 20, 2007 | Maytag 24 in. MDB6100A Built-in Dishwasher
Dishwashers Logo
74 people viewed this question
Top Dishwashers Experts
