How do i connect the mouse? Belkin Wireless comfort mouse F5l030-BGP I put the usb in and nothing happens
    Novelist:
  • 107 Answers
Insert your USB receiver into a USB port on your computer. If you are using a laptop, you'll usually find a USB port on the side. If you are using a desktop computer, it's likely located on the front or rear of the tower.
Wait for your computer to install the drivers. You'll see a progress balloon in the bottom-right corner of your desktop screen. After a minute or so, it should show "Success." If it does not, or if there is an error, visit the Belkin resource to download the drivers.
Turn the mouse over and push the switch to "On." The mouse should automatically communicate with the USB receiver. Test the mouse to determine if it has. If the mouse does not work, press the "Connect" button on the receiver and then press the "Connect" button on your mouse. The mouse should be functional.
Posted on Mar 22, 2011
I have lost my usb wireless adapter for my Belkin F5l017usbblk
The best route to take is to obtain another adapter for the mouse since it was wireless. However, if the mouse and your computer have Bluetooth capabilities then you can connect by Bluetooth.
Jul 15, 2014 | Belkin Components Belkin F5l017usbblk...
Belkin mouse f5l030-fdp
try using different pc and check if it working
Jan 22, 2014 | Computers & Internet
Belkin wireless mouse won't connect on power up of PC
A Belkin Mini Wireless Optical Mouse frees you from the restriction imposed by the limit of the wire that your mouse uses to connect to your computer. The Belkin model works up to three feet away from the receiver and operates on a 27 MHz frequency. It's smaller than a regular mouse, making it easy to add it to a laptop case or desk drawer without losing much space in the process. Before you can use the Belkin Mini Wireless Optical mouse, you must install it. The receiver and the mouse should sync automatically; if they don't, you must perform the sync manually.
1 Press the bottom release tab on the top cover of the mouse. Insert the batteries included in the package and replace the cover.
2 Turn on your computer. Plug the Belkin USB receiver into a USB port on your computer. The drivers will install automatically.
3 Press the sync button on top of the USB receiver and then press the sync button on the bottom of the mouse to connect the two devices.
Warning
  • close Before you can install the Belkin mouse, remove drivers for other wireless mouse types on your computer.
Jul 17, 2017 | Belkin Mini Wireless Optical Mouse...
Hi my mouse has worked for years. I just changed the battery in the mouse and now it will no longer work. The jump drive turns red when I push the mouse up to it then nothing happens. I went to Control...
From your description, it sounds like the wireless connection between the mouse and the USB receiver (jump drive) isn't resetting. Here are the steps to reset the connection after changing batteries:
With the computer on, mouse on, and receiver installed in the USB port...
1. Turn the mouse over and aim the front at the receiver, like this:
thomascha103_8.jpg 2. Press the "connect" button on the bottom of the mouse. It's small and round, next to the power switch.
3. Then press the "connect" button on the receiver
(the connect buttons always have to be pressed in this order)
4. When you press the button on the receiveer, the light will turn on. Keep the mouse pointed directly at the receiver until the linkage is complete and the light turns off.
That whole process has to be completed in under 60 seconds. If it takes longer, you'll have to start over.
At least, that's how it works for me. Here's a link to the user manual with other helpful troubleshooting tips:
http://cache-www.belkin.com/support/dl/f8e825-usb.pdf
Best of luck!
Jan 20, 2011 | Belkin Mini Wireless Optical Mouse...
Belkin wireless travel mouse not connecting to Mac
If you have a usb extension cable try plugging it in so you can place it on a firm surface when you press the sync buttons. Have heard of some issues with activating both mouse and fob buttons at once because of difficulty in reaching the fobs sync button.
Aug 13, 2009 | Belkin F5L017 Mouse
Microsoft wireless mouse 3000; put in new battery, still nothing
nikcorra2488,
try this: plug in the USB key & check for the green light. Then go to start, control panel, & double click mouse (with whatever mouse works). Check the hardware tab and see it the computer is recognizing that the mouse is there. If it is there, it should be working fine. If not, then perhaps you need to reinstall the USB port drivers. Sometimes this will happen when you've upgraded from 1.0 to 2.0 USB ports.
Hope this helps.
-samson39
Jul 26, 2009 | Microsoft Wireless Notebook Optical Mouse...
Connecting wireless mouse
No, you cannot as the USb plug which came with the mouse is the "Recieving unit" while you wireless mouse is the "Transmitter" unit & they both must be used together.
Apr 16, 2008 | Belkin DBF8E825USB Mouse
Belkin Wireless Mouse
Today I tried pressing the reset button on the bottom of the mouse, and at the same time pressed the button on the top of the remote reciever. I'd pressed both in the past, but never at the same time. This seems to have fixed this problem. I hope it's a solution for others also.
Dec 21, 2007 | Belkin Wireless Keyboard/Optical Mouse...
Wireless mini mouse
Normal 0 Disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Nov 20, 2007 | Belkin F8E825 USB Mini Wireless Optical...
Computers & Internet Logo
1,427 people viewed this question
David Payne
David Payne
