Question about Gateway 420GR PC Desktop
Computer start but monitor goes in power safe mode . What can I do ?
    Sergeant:
    Novelist:
  • 164 Answers
Typically, this happens on a computer which is a few years old, since its batteries will have run out after such a long time.
The motherboard battery is used to store various settings, such as date and time, when the mains power is off. When your computer detects an empty battery, it goes into a low-power mode.
The solution is to replace the button-cell battery on the motherboard of your computer:
  • open the case of your computer;
  • visually locate the motherboard (the main electronic circuit board) of your computer;
  • visually scan the motherboard for a button-cell battery (it looks like a digital watch battery, but a bit larger);
  • remove this motherboard battery from your computer;
  • restart your computer: it should now power up normally (you may get some warning messages during the start-up sequence, but ignore them);
  • set the date and time of your computer using the "Date and Time" control panel;
  • you can now use your computer normally, but you will lose date and time settings when you disconnect the computer power cord, since there is no motherboard battery present to store them;
  • take the motherboard battery to an electronics store and get a replacement;
  • install the new battery in your computer;
  • restart your computer, and set the date and time again; the settings will now be saved using motherboard battery power.
Posted on Mar 22, 2011
    Sergeant:
  • 187 Answers
Try swapping the ends of your VGA cable, then make sure to tighten them. Then reboot your computer.
Regards,
2 Suggested Answers
  • 9 Answers
SOURCE: monitor in power save mode
Man is your machine booting.????
if the machine is booting and no display on the moniter then check the power to the moniter ..... if ok
then if you r using xp os the
go to contol panel >Power options>Power scheme > select always on
Good Luck !!!!!!!!!
Posted on Apr 24, 2009
My 19 " LG Monitor
If you have a problem getting into safe mode using windows Vista or 7, boot up your computer. As soon as it tries to start windows turn off the power. When you try to start it again it should come up with a menu asking if you want to use safe mode or boot normally. Select safe mode.
Dec 14, 2010 | LG Flatron L1750S 17" LCD Monitor
My laptop moniter turns on as usual with the proper reading. I start in safe mode as normal..wait about 10 min and screen goes white
hello
"I start in safe mode as normal."
safe mode is not a normal thing during your windows boot sequence :)
if your display works ok until those 10 minutes of safe mode are over i would say that reinstalling your windows operating system will most likely solve your monitor issues :)
Mar 24, 2010 | Princeton Digital LCD17 17" Flat Panel LCD...
My monitor will not stay on
have you tried running your pc in safe mode, to do this press f12 on start upjust before you see the loading windows bar. choose safe mode if this works then remove you orig video drivers and restart pc.
Nov 28, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Hello I wonder if you can help. When we switch
Had a similar problem like this several times. Try choosing safe mode. Safe mode will load the required drivers. After safe mode finishes the loading process, restart your computer and choose to start windows normally. The problem you mention usually happens when the computer is turned off without using normal shut down procedures. Also happens when you have a sudden power outage.
Oct 24, 2009 | Computers & Internet
Screen goes black. the power light is on, but the picture goes out. if i turn the power off, then on again it comes back for about 5 seconds, then goes black again.
Check to see if this problem follows in safe mode. Reboot and when the Dell splash screen comes up tap F8 until you see the multiboot options. Scroll to "safe Mode with Networking" let the machine boot up and see if you have a screen. If you do, right click on the desktop and set the resolution to 800 X600 and reboot normally. Usually when a screen goes blank in normal mode but shows up in safe mode means you have an incompatible resolution for the monitor or graphics adapter. This may be a driver issue or hardware. If the screen boots up in normal mode at the lower resolution, then try and go to properties again and bump the resolution up a bit, if it blanks again, try to go online and update the driver for the graphics chip.
Sep 08, 2009 | Dell Dimension E510 PC Desktop
5 sec after starting windows the monitor goes to sleep itself.
go to safe mode.. change the power settings for windows...
to go to safemode.. simply restart your computer.. then press f8 several times til you see the boot menu.,.. select safe mode.. from there.. you should be able to boot windows.. change the power settings in control panel
Jul 09, 2009 | HP Compaq FP 7317 17" Flat Panel LCD...
Monitor won't stay on
Restart the computer and tap on f8 button so u can start computer in safe mode, if u are able to restore computer to earlier tiem. IF u are unable to start using safe mode. Ur computer need to reformat. Please insert recovery disc restart computer and tab on down arrow button and follow onscreen instruction...
Jan 19, 2009 | Liquid Video E15LCD1 15"
Monitor automatically clicks into power saving mode
check the primary settings for your default video card.
Jun 08, 2008 | Dell Dimension 4600 PC Desktop
Gateway 420GR PC Desktop Logo
157 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
