Question about DISH Network Televison & Video
I'm in the room and using tv 2 on dvr but I see tv1 and don't know how to go back to tv 2. So what I'm trying to say is I'm watching what tv 1 is watching.
  • DISH Network Expert
  • 246 Answers
Himarcos_and_s, my name is Mike Houston of DISH Network and I was going over yourpost and with TV2 showing what's on TV1 you want to make sure the receiver isin dual mode and if that is the case please unplug the receiver for 10 secondsto reset the receiver and you will have your TV1 and TV2 showing differentprograms. If you have any questions please e-mail me at Michael.houston@dishnetwork.com.
Posted on Mar 22, 2011
Have a vip625 receiver i want split the tv1 signal and use the remote in another room
kdsix,
You can split the signal from TV1 if it is connected via a coax cable. All you would have to do is run that TV1 connection into a 2-way splitter, then run a connection from each of the ports to a different TV.
The TV1, however, is still IR so you wouldn't be able to change channels from another room unless it has a clear shot to the receiver. If you have any other questions, let me know!
Tommy Faust
DISH Social Media Representative
Oct 20, 2012 | DISH Network ViP622 DVR DTV Receiver /...
Dish Network remote and receiver problem
Hi Tracy, my name is Mike Houston a Social Media Representative at DISH. With the TV2 remote working for both TVs, you will want to make sure the TV1 input on the receiver is connected to the TV cable (RCA or Coax cable) and TV2 input is connected to TV2 port on the back of the receiver. I will provide you our link explaining in more detail about connections. If you have any further questions I will provide you my e-mail; michael.ouston@dish.com. Here is the link I promised you: http://www.mydish.com/support/same-video-2-tvs
Aug 02, 2012 | DISH Network DVR-625 DTV Receiver /...
How do i change tv 2 with reciever or remote 1, lost remote 2.
Hi this isMike Houston of DISH Network and I see you have lost your TV2 remote. Until youget your 2nd remote you can put the receiver in Single Mode and putTV1 on the channel you want to watch for TV2 and then put it back in Dual Mode.I can help you in getting your TV2 remote so you can watch TV on both setswithout having to change the Mode setting on TV1, I will send you my e-mail andyou can contact me through there; michael.houston@dishnetwork.com.
Aug 08, 2011 | DISH Network DVR-625 DTV Receiver /...
Cant record two programmes at once
Well no matter the DVR, you should be able to record 2 programs at once...but you CANNOT watch a 3rd live while they are recording...also, if your DVR is hooked up to more than one tv and someone is watching something else in the other room, it will not record 2 at once, either. You can watch RECORDED programming while 2 others are recording, but not live tv.
You might want to check how many "inputs" your DVR has...most have 2 which allows the double recording...if you have an older DVR maybe you only can do one at a time. On my DISH box, they call these "TV1" and "TV2".
Hope this helps.
May 14, 2011 | Televison & Video
I have two vip 622 in my house and with one i can watch hd channels on both tv 1 and 2 but on my newest one i can only watch hd channels on tv1 and on tv 2 it says looking for satelite both have identical...
You may have a bad port on the back of the receiver, a cut or disconnected wire somewhere on that side of the system or a bad diplexer if the system is not straight wired to TV2.
The easiest way to verify whether the port on the receiver is bad is to connect that line directly to TV 1 off the back of the receiver. Remember to place TV one on the CHANNEL TO CHECK IF IT IS GOOD. If you have picture then you have a bad diplexer.
Hope this helps. Thanks for using Fix Ya.
Feb 23, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Remote will not work on #2 TV satilight
It could be the distance the remote is from the antenna. Try going to the receiver and pressing the guide button on said remote. Go back to TV 2 and see if it is up. If not go back to tv 1 and with TV1 ON AND TV1 REMOTE IN HAND press MENU-MENU. You will be able to see the remote addresses for the remotes toward the bottom of the page. With TV2 remote in hand press and hold the SAT button in the upper left of the remote until all buttons across the top illuminate. Now press in a two digit number between 2 and 15. Press the pound sign and the SAT button will flash thrice. Now press record a few times until you see the TV2 icon on the screen blink and the address is the same as you keyed. Exit out of the menu with TV1 remote. Go to tv 2 and try. You should be good to go. If your remote worked when you brought it close to the receiver you need to relocate the antenna on the back of the receiver to the room TV2 is in.
Feb 08, 2010 | DISH Network ViP622 DVR DTV Receiver /...
DVR playback in color on TV 2 playback in black and white on TV 1
This is a receiver issue and will need to be replaced as the internal hardrive has an issue that cannot be resolved onsite by a technician. Thanks for using Fix Ya.
Feb 10, 2009 | DISH Network DVR-625 DTV Receiver /...
Adding tv to a dish network dvr
Your upstairs tv is connected via a coaxial cable and you can do a few things to get programming to the third room.
The first is to locate the wire that enters the upsairs room that currently has tv and insert a splitter by cutting the line to that room and running the out ports to the rooms and the in port to the other end of the wire that you cut. This will give you the same picture in both rooms.
If you have a system that does not use diplexers to backfeed the second TV you can backfeed the 3-4 cable going to the TV1 by cutting the line and adding a splitter with the inport running to the 3-4 port on the receiver and one of the out ports going to your tv1 and the other outport going into the UHF side of a diplexer. You will need to cut the Satellite feed into the back of the receiver on the back side of the seperator and connect the seperator to the SAT port of the diplexer. The IN/OUT port of the diplexer will connect to the end of the sat feed cable that goes to the wall plate. This will allow you to go into the attic of outside of the house and find the sat cable that feeds the TV one and break it there and put the IN/OUT port of that diplexer facing the TV1 room and the SAT port connecting to the other end of the cable you broke. The remaining UHF port will be the feed for the new room that you wish to connect. This set up will allow for viewing the same program as that at the TV1 location however you will need to change the channels at the TV1 location or buy an IR to UHF converter to allow you to be able to work the system independently from the receiver. Hope this answered your question. IF you need further assistance please contact me and thanks for using Fix Ya.
Dec 24, 2008 | DISH Network ViP622 DVR DTV Receiver /...
Problem with DISH DVR 625
You can accomplish this by either going to the specific TV and selecting the record option at the time the program is about to come on or you can press menu-8-5 and change the record preferences. You can either set the DVR to record programs to the TV2 location by default or TV1 by enabling the record plus feature. In dual mode without record plus enabled all programs you select to record default to the tuner you are viewing e,g, if watching tv1 and selecting to record a program in the future it will record to the tv1 location.In single mode all recordings default to tv2 so you can continue to watch live tv from tv1. I hope this answers your question and thanks for using Fix Ya. Let me know if I can further assist you.
Dec 14, 2008 | DISH Network DVR-625 DTV Receiver /...
Hi,my brand new UHF remote wont operate the #2 tv??
Go to the tv 1 location with your TV2 remote. Turn TV1 on and using TV1's remote press menu-menu. You will be at the System Info Screen. Take TV2 REMOTE and press and hold the SAT button on the top left until all buttons on the top light up. Release the SAT button. Now key in a two digit number from 1to 16 and press the # key. The SAT button will flash three times. Now press the record button until the remote address for TV2 changes to the number you chose. When accomplished exit out of the screen with th TV1 remote and you should now be able to control TV 2. As a precaution ensure the remote antenna is on the back of the receiver. If you still have difficulty it may be required to move the remote antenna closer to TV2. I hope this answers your question. Thanks for using Fix Ya and let me know if I can of further assistance.
Dec 12, 2008 | DISH Network DVR-625 DTV Receiver /...
Televison & Video Logo
54 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
