We need the Test Procedure of CRL Breaker - Computers & Internet
    Sergeant:
  • 187 Answers
Try to download this test procedure if it suits what you're looking for.
Source(s):
http://smcelectrical.com/?q=system/files/
Regards,
Posted on Mar 22, 2011
Ms9540
You have set the reading suffix as a Tab + CRL
You need to disable that function on the barcode manual.
Just go to the page that is indexed as Suffix and read disable CRL(To do so, read first the set barcode, then the specyfic suffix barcode and finally EDIT/SET/OK(depends on each manufacturer)
Mar 03, 2014 | Computers & Internet
MY JETS WONT TURN ON
The threaded knob should not be related to the problem, it just controls how much air gets mixed into the water jets. One possibility is that the electricity is off. These tubs should receive power through a Ground Fault Circuit Interrupter (GFCI) type of circuit breaker for your protection from electrical shock. Check your circuit breaker panel(s) for a breaker with a little square white or yellow "test" button. Refer to the label (if it is there) to see if it refers to "tub" or "spa" or "bath" or something like that. You may have to turn the breaker handle off (push extra hard to make it reset) and then back on again. If the breaker handle is in the "on" position and the "test" button does not "trip it off," call an electrician. If no luck there, check the bathroom for an electrical outlet with GFCI protection, again looking for white or yellow (or red) buttons - one should be engraved "test" and the other "reset" as the electrician (I hope it was an electrician) may have supplied the tub from this outlet (not actually up to code). Plug an appliance or light into the outlet. If it doesn't work, push the reset button on the outlet and test again. If working, now test the spa. If that doesn't work, test every other GFCI outlet you can find - in the kitchen, other baths, garage, outdoors, basement, etc. using the same testing procedure. If you find a GFCI breaker or outlet "tripped" that restores the tub, that indicates there is something wrong with your electrical system that could cause you to get electrocuted, and requires that you hire a qualified electrician to investigate the problem. The same is true for any GFCI outlet that does not "trip" and/or "reset." If this doesn't fix the tub, the problem may not be electrical but some other problem with the system, indicating a plumber or spa tech may need to be consulted. Note: these GFCI breakers and outlets are supposed to be tested and reset once every month. How many of us do that? Well, at least as often as we test our smoke detectors, I suppose.
May 20, 2013 | Home
I have a GE Profile JT952series Electric Double Oven and the keypad is not turning on the bottom oven
Check your breaker box to make sure the breakers are ON.. these typically are double throw breakers.. it is possible one of them has been thrown open.. so flip that double throw off and back on.. then check..I have seen one side of these breakers fail.. unusual.. but it happens.. then a replacement is in order.. regardless. visually it may appear the breaker is closed..but upon closer inspection.. one side may be "spongy/open". There are always exceptions..so examine the breaker box carefully.
If one breaker is open..it would be wise to keep an eye on things to determine how it got that way in the first place. If the breaker will not close or throws/pops again..you either have a bad breaker or a wiring problem..in some cases the element may have grounded out..or burned a wire.. etc.
Next thing to check for is a bad element.. Remember..this is a 220volt hot circuit with a high amperage breaker.. BE CAREFUL.. USE CAUTION.. Failure to do so could result in serious injure or DEATH.
Turn off power at the breaker box to the oven.. test the working over to make sure the power is OFF.
Remove the oven racks
Remove the screws at the base of the element
Pull the element toward you
Note how the wire(s) are connected
Disconnect the wires.. checking for broken or lose terminals..if lose or broken..repair.
You will need a volt ohm meter for the following..
Test the Element for continuity. Place each probe on the terminal ends (manual will have ratings) generally if you have continuity it probably works..
Test for a grounded/short.. one probe to element the other to terminal end..if you have continuity.. it's shorted out. Test both terminals
Replace with a new one if needed.. reverse procedure. Turn on the power .. and test for proper operation.
Again.. 220 VOLTS..HIGH AMPERAGE.. USE CAUTION..not doing so could result in injury or DEATH
After you have done the above..and get an all pass..then it's on to controllers and temp sensors.
Best of luck
Apr 19, 2011 | GE Profile JT952 Electric Double Oven
What is the exact size of tacker on T32M Arrow staple.
http://www.technologylk.com/ Toll Free: (888) 663-9830 CRL Arrow Regular-Duty Staple Gun t32m_9480.gif.axd?width=200&&height=200 divider.gif
Part Number: T32M Our Price: $45.86
Product Details:
  • All Steel Construction
  • Chrome Finish
This CRL Arrow Regular-Duty Staple Gun utilizes double leverage for speed and easy operation. Commonly used by displaymen, upholsterers, TV servicemen, and other special trades. Features all-steel construction, with a chrome finish. The handle locks down so the stapler fits compactly in a pocket.
Dec 18, 2010 | Office Equipment & Supplies
No heat in car coming through cold thermostat changed what else should i be looking at ? the car is actually a KA on a 51 plate but there is no listing for it !
try flushing your heater core.Disconect both hoses from core add a crl that you can buy at any hardware store.Block one hose file it with the crl and let sit for awhile and that may solve your problems
Jan 12, 2010 | 2001 Ford Escort ZX2
How do I fix a squeaky car door?
Some good old WD40 would take that nosie away or you can use soe motor oil on the henge. I hope this helps.
Jun 09, 2009 | CRL Fixed "All Glass Look" Window-Side and...
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
