Question about Harman Kardon AVR 300 Receiver
Hi, I have a Harman Kardon AVR 300 that I picked up at a local sale. When I power it on, it switches fine to each input except the AM/FM tuner (the preset, tuning, & tuner mode buttons don't seem to respond). All other buttons seem to be working. I'm a fairly technical guy, but when it comes down to A/V equipment, I am not very knowledgeable. Any idea what the problem could be? Is there an easy enough fix that I could do myself. thanks
  • 979 Answers
Hello Sir, Hi, you may try the following
  1. try cleaning the switches
  2. if this does no solve the problem, its the selector circuit. this may be digital, so you need to search the IC that selects the FM mode both with tuning. this is fair complicated.
  3. buy a cheap separate FM tuner, run it on auxiliary input.
Posted on Mar 22, 2011
Testimonial: "Thank you."
Why does my avr 100 say OPTI.when i try to play the radio, and no sound comes out
It is trying to input a signal via the Optical digital input. You need to switch the input control on the front panel or remote to Analog.
Feb 13, 2013 | Harman Kardon AVR 100
I'm unable to turn ON my Harman Kardon AVR 300 rds power lisht is in red colour
Hi, Check the speaker wires that they are not shorting. Check the fuses on the back and then unplug it for 10 minutes. Good luck.
Sep 10, 2011 | Harman Kardon AVR 300 Receiver
Hi, I have a Harman Kardon AVR 300 that I picked up at a local sale. When I power it on, it switches fine to each input except the AM/FM tuner (the preset, tuning, & tuner mode buttons don't seem to...
AC (alternate current) receivers have amplifiers in them. Those amplifiers have capacitors in there. What the do is store massive amounts of electrons. What that means is if you touch one it will electrocute you. I have to recommend you take it to a tech to have this addressed. This is purely for your safety.
Mar 22, 2011 | Harman Kardon AVR 300 Receiver
My harman kardon avr 110 will not play thru the fm. what do I need to hook up to make it work?
It's a RECEIVER, meaning the FM tuner is built-in. That's the only source you don't have to 'hook up'. But you DO have to make sure NO OTHER source is selected.
You don't say if it actually TUNES a station or not. Try an antenna.
Register and download the manual for free audio.manualsonline.com
http://audio.manualsonline.com/manuals/mfg/harmonkardan/avr_110.html
Feb 27, 2011 | Harman Kardon AVR 110 Receiver
No sound regardless of input. front panel lights up and functions as per inputs however also noticed pwr supply fan and internal heat sink fan do NOT turn on. Any debugging tips appreciated! Thank You...
The power supply has to be on to some extent or it wouldn't light up.
http://www.retrevo.com/support/Harman-Kardon-AVR-335-Receivers-manual/id/386bh133/t/2/
Does it tune FM? That would indicate some life.
No sound? Is it Muted or a tape Monitor selected inadvertently?
Page 53: Reset the processor...
Processor Reset
In the rare case where the unit's operation or the displays seem abnormal, the cause may involve the erratic
operation of the system's memory or microprocessor.
To correct this problem, first unplug the unit from the AC wall outlet and wait at least three minutes. After the
pause, reconnect the AC power cord and check the unit's operation. If the system still malfunctions, a system
reset may clear the problem.
To clear the AVR 335's entire system memory including tuner presets, output level settings, delay times and
speaker configuration data, press and hold the Tone Mode Button (5) buttons for three seconds. The unit
will turn on automatically.
NOTE: Resetting the processor will erase any configuration settings you have made for speakers, output
levels, surround modes and digital input assignments, as well as the tuner presets. The unit will be returned
to the factory presets, and all settings for these items must be reentered.
If the system is still operating incorrectly, there may have been an electronic discharge or severe AC line
interference that has corrupted the memory or microprocessor.
If these steps do not solve the problem, consult an authorized Harman Kardon service center.
Jan 28, 2011 | Harman Kardon AVR 335 Receiver
My avr 300 goes into standby mode and cannot be turn on. How can i turn it on and what causes this things to happen?
turn OFF avr 300 and unplug the ac power supply and also unplug the speakers terminals,input signal (optical ,coaxial,video1,.etc) after that you turn ON AR 300.
Jun 23, 2010 | Harman Kardon AVR 300 Receiver
My Harman Kardon AVR 254 is not responding. None
I am having the same problems with my AVR 254, did you find a solution?
Thanks
Mar 15, 2009 | Harman Kardon AVR 325 Receiver
AM/FM receiver
the problem is in your tuner for me it is betwen the IC and the IF transformer. if u cant fix it buy new stereo componet.
Apr 16, 2007 | Harman Kardon AVR 225 Receiver
Tuner trouble
This reciver has an RF FET front end. Most manuafacturers use a tuner assembly built by another company. These front ends on these tuner assemblies do go bad from time to time, and sometimes is caused by excessive static electricity. The cost to replace and or repair this front end assembly, will most likly exceed the cost of a new unit, unless you really like it. What I have seen a few people do is buy an inexpensive reciver or tuner, and use one of the unused inputs to play the AM/FM through the reciver that does not work on the tuning. Good Luck Please dont forget to rate this thread.
Dec 11, 2006 | Harman Kardon AVR 230 Receiver
Harman Kardon AVR 300 Receiver Logo
262 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
