I'm not very acquainted with the BIOS of Emaxx. Where do I set the boot order?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 116 Answers
Set "Advanced BIOS Features/First Boot Device"
Posted on Mar 22, 2011
How to change setting in bios to boot from cd drive"?"
you usually dont have to change the boot order to boot from a cd. the bios should check the cd rom before booting from the hdd. However, if that isnt the case, you can always change the boot order.
go to the bios settings while u turn your laptop on. (It should be "esc" for HP. a message will be displayed at the bottom of the screen indicating the key. if not, try esc, f10, f11, f12. either one of them should work).
go to the boot order settings (May have a different name- boot settings/ boot priority settings/ advance boot options etc.).
Jul 13, 2014 | HP 15.6" Compaq Presario CQ58-A10NR Laptop...
Vista will not load from CD
Your computer is probably set to boot to the Hard drive BEFORE the CD rom in the BIOS. Research how to access the "system configuration" or BIOS when your computer first turns on. Search through the BIOS menus and see if there's a place to set the "Boot Order". Change the boot order to boot to the CD Rom before the Hard drive.
Dec 16, 2011 | Computers & Internet
When I start my computer I get the message PXE E61 Media Test Failure:check cable. Please, help me.
Make sure first boot device is NOT set to network in the bios or maybe the hdd has gone and its looking for a operatin system to load Check cable connections (reseat),
Check jumpers on hard drive for Master/Slave or CS settings,
Check BIOS settings for boot order,
And lastly have your BIOS rescan your HD or reset your BIOS to defaults.
Put 'Hard Drive C:' before 'Network' in the boot order
(If the hard drive does not appear in the boot order, that's why the PXE network boot agents start)
Note : Check that the hard drive is seen in the BIOS setup
Aug 18, 2011 | Computers & Internet
I have an asrock p67 extream4 it sees the optical sata drive in the bios but will not boot from it. I have the dvd drive first for boot. What should be the bios settings to boot from the optical drive?
In the Advanced Boot settings of the BIOS you will see a general boot order setting and then there are 2 others: for the order of the optical units and for the order of the hard disks.
Open the setting for the optical units and put the SATA one first - the IDE one is there first by default.
Jun 11, 2011 | Asrock Computers & Internet
I am presently using fedora12.now i want to install windows 7 is it possible,they cannot taken any booting from the cd,by default grub installer is loading
Hi Thanks for your question
In order to boot from the CD drive you must change the Boot Order in BIOS.
In order access BIOS you must press certain key on the keyboard during start up. Depending on the machine it may be F1, F2, F3, F10 or Delete key. Once you acces BIOS you must find Boot order settings. Again depending on machine this may look different, but most of the time it's a separate Tab or settings may be in general part in BIOS setup. When you find it you have to place CD/DVD drive on the top of the list of Boot Order and before exiting BIOS sace changes. Now your machine should Boot up form CD and you should be able to install Windows 7. Do not hesitate to ask more questions if further assistance is needed. Good Luck
May 08, 2010 | fedora Linux Operating System
I am trying to install xp on a clean disk but when i try to boot to cd i get ntldr is missing..how do i fix this? bios are set to default
Go into the bios and set the boot order to CD drive first and HARD DRIVE second.Setting the bios to defaults often doesn't set the boot order right to install an operating system
May 06, 2010 | Gateway 450ROG Notebook
Only booting after pressing f12 and select boot devise
You must change the boot sequence from your BIOS.
To do this, when your computer starts press F1 or F2 until you enter the bios setup menu. Usually on Toshiba is F1 or Esc key.
Now that you are in the BIOS, you must locate the boot order section. Just go through every page until you see something like Boot Device, Boot Order, Boot Management, Boot Sequence, etc. (its different for each computer)
There, change the boot order to move the Hard Disk or DVD ROM in the top two items in the list.
Save your settings and exit the BIOS.
Your computer will restart and it should boot up normally.
Feb 02, 2010 | Toshiba Satellite Pro A200-EZ2204X...
Can not boot from cd rom...bios boot order is set
Set all in Boot priorty to CDROM
Set Other Boot Device to No.
Jan 07, 2010 | EliteGroup NFORCE 570 SLIT-A Motherboard
Hp pVILLION DV 1000
This error message may appear when the computer BIOS is set to boot from a network and cannot find a bootable operating system on the network or on any of the storage devices included in the notebook PC's boot path.
The following steps are for most HP Pavilion and Compaq Presario Notebook PCs. The boot order can be configured on the Advanced tab in the BIOS settings menu. The steps to modify the boot order may vary depending on the model of your computer. On most HP notebooks the boot order can be configured using the following steps:
  1. Turn on or restart the computer.
  2. While the display is blank, press the F10 key to enter the BIOS settings menu. NOTE: Some notebook PCs use the F2 or F6 key.
  3. Use the right and left arrow keys to select the Advanced tab.
  4. Use the up and down arrow keys to select Boot Order .
  5. Follow the on-screen instructions to change the boot order.
Reset the boot order to the default settings Use the following steps to reset the boot order to the default settings:
  3. Press the F9 key to reset the BIOS to default settings.
  4. Press the F10 to save the changes and exit the BIOS settings menu.
I think it will you to fix your problem.
If still have problem then tell me more about it.
Thanks
Iqbal
Mar 18, 2008 | HP Pavilion Elite M9060N PC Desktop
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
