Question about Samsung HT-Z310T Theater System
My Samsung Home Theater System Shuts off about 2 seconds after turning on. The display says PROTECT and then shuts off. Any suggestions?
    Master:
  • 346 Answers
Hello David - That message is telling you the system is shutting itself down because of some electrical abnormality that could damage it or a situation causing it to overheat.
I suggest you first unplug the unit and let it sit for an hour or two. Power it back up. If the warning is still there power it down. Now would be the time to consider whether you have made any changes to the system, even anything as small as moving a speaker.
The most common reason for the error is that there is a short somewhere, usually in the speaker wire itself or at the connector to either the speaker or the system. Overheating is not the issue because of the short time between power up and the message. Detach everything that is attached to the unit (devices and cables/speakers) and power it up again. If the error persists you have an issue requiring service, hopefully under warranty.
If it doesn't that's a great sign and the next step is to attach everything back ONE device/cable at a time, powering the unit down before you attach the next device/cable. Be extra careful with the cable attachment and while you're handling the cable look for any visible abnormality with the cable, bare cable, cracked connector, etc.
Obviously if the error returns right after any connection the problem is right there, most likely a speaker cable and the fix is to make sure the cable is not shorting at the connections to speaker or receiver and if that can't be found visibly replace the cable with a new one.
Good Luck and Thanks for using Fix Ya.
Mikeywaf
Posted on Mar 22, 2011
My ht-z31 dvd surround sound turns on and immidiatly says protect and shuts down. what do i do?
the protect means a circuit overload check that you dont have any wires for your speakers touching or backwardly installed if those are all fine you may have blown a fuse inside the receiver.
May 07, 2011 | Samsung 1000W 5.1-Ch. Home Theater System...
Our Samsung HT-C6900W Theater System shut off yesterday and then said it was in protect mode, now we cant get it turn on. This system is only 3 months old. Can you help?
The problem is with the amplifier overheating so the system shuts down to protect itself.
Make sure the ventilation fan is not block or obstructed.
If this is OK then contact your supplier with the equipments warranty.
May 01, 2011 | Samsung HT-C6900W Theater System
When i turn the system on the display will read "hello" then "protect" then shuts off. Whats up ?
The "protect" function is shutting the syetm down to protect the electronic components inside it. Usually caused by a lackof earth in the plug or extension lead. Plug it straight into the wall and check it, if it is still the same then it could be a speaker wiring short circuit, disconnect the speakers and plug it in on its own and test it
Aug 27, 2010 | Samsung HT-Z310T Theater System
I have no sound..display reads protect...then shuts off
The amplifier board is burnt and needs to be replaced
Jun 11, 2010 | Samsung HT-Z310T Theater System
It keeps on wanting to shut off like it is overheating but yet it is not hot...(Samsung DVD home theater system HT-TX72)
Check you speaker connection first and make sure none of the wires are touching another terminal. The unit might be going into protect mode. If so it should display the words protect on the display before shuting down. Try removing one speaker at a time while turning on the unit after each speaker is removed at a time, to see if it shuts down on you. When and if it stays on then the previous speaker you took off is defective.. If none of this works then you might have a bad Preamp circuit or main amplifier output problem. Disconnect everything from the unit and turn it on, to see if it shuts down on its own, if so then there is a problem with the internal parts of the unit itself.
Nov 30, 2009 | Audio Players & Recorders
Need help with HT-z410
When your home theater's display reads PROTECTION, it means the home theater is over heating and the unit will shut down to prevent any damage. This can happen if the unit is stacked along with other electronic devices or the unit is in an enclosed area that prevents the unit from cooling properly. To decrease the chance of overheating, relocate your home theater to a more open area.
If the home theater display reads PROTECTION every time you turn it on, no matter where or how the unit is placed, it needs service. To set up service call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Jun 29, 2009 | Samsung HT-Z310T Theater System
Once switched on, PROTECT appears on screeen and system turns off
Jun 29, 2009 | Samsung HT-DS1000 System
When powered up, it states "protect" and shuts down.
it is a known product defect. samsung will fix it for you if you send them a lot of money. this helps them keep their prices low.
May 25, 2009 | Samsung HT-Z310T Theater System
Dvd home theather system
The audio amplifier IC are fried and need to be replaced
Mar 31, 2009 | Samsung HT-X40 System
Samsung HT-Z310T Theater System Logo
416 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
