Question about Samsung SpinPoint T133 HD400LJ 400 GB SATA II Hard Drive
Doesn't spin and make beep - Samsung SpinPoint T133 HD400LJ 400 GB SATA II Hard Drive
    Sergeant:
  • 275 Answers
Not much you can do with it, those are the sounds of a broken hard drive. I hope you backed it up.
Posted on Mar 22, 2011
Constant beeping from Cavalry external HD
Can't say exactly what it means technically speaking, but my experience with such a problem is that the drive is 'dead'. Of course trying it on another computer would be constructive.
Dec 14, 2017 | Cavalry Storage Computers & Internet
Memory upgrade on gx280 beeps on boot but doesn't start. memory beeps 1 234 5 6
When your computer emits beeps when you power on the computer, it's usually means that you have a memory issue. Try re-seating the memory modules and power on the computer. If you have more the one module, insert one at a time and power on the computer. The other issue is if that model supports 4 gig memory.
Aug 30, 2012 | Dell Computers & Internet
My fisher & paykel 7.5 kg excellence smart drive doesn't spin
Check the out of balance switch (under the larger Grey board)
for corrosion on the terminals and replace if faulty.
Jul 03, 2012 | Fisher and Paykel Washing Machines
Spin cycle doesn't work
bad drain pump or clogged drain line. some units have drain trap you can clean,if so you can clean it out yourself but will make a huge mess if you don't pinch close the drain hose between the tub and pump.
Nov 12, 2011 | Haier HLP21N Washer
Hi, i have a toshiba aw1150s washing machine. it was working fine all along, until it reaches the spin stage. it will empty the whole tub of water. when it tries to initiate a spin, it shows E2 and...
check the safety door switch,, its not going to spin unless that switch is working, ( you can by pass it to test it, Jump clip a jumper between the 2 wires ,, if that fixes the problem replace the switch
Jul 14, 2011 | Washing Machines
Hi, I have a colleagues laptop here which seems to power up for a few seconds but then doesn't go any further. There is definitely power getting through the motherboard, and the HDD spins up, but...
I believe that is a No Post issue.
Its not the hard drive because you said " and the HDD spins up, but it seems as though it doesn't reach POST" or else you 'll be getting errors associated with the hard drive
There are some laptops even though it has a RAM NO POST issue will not beep
" no display and no beeping at all "
For us to determine if this a Motherboard Issue we have to disconnect all parts that can be disconnected. Disconnect the hard drive, Memory (RAM), battery, if you have a Modem daugther card, Express card, PCMCIA Card.
Try Turning the computer on using the Power Adapter hooked up on the computer. If you are still getting issues Definetly that is a Motherboard have gone bad but we really need to check up other parts that are disconnected
If Motherboard is good you will be getting video but it will stop on the POST screen and you might be hearing beep sounds as well. That means that the Motherboard is fine. Put the parts that are disconnected and clean the metal contacts as well one at a time and try to isolate at what part that is bad
Jul 05, 2011 | HP Compaq nx6325 Notebook
Doesn 't spin
Hi just read your posting.Just a couple of questions.Does your machine drain the water out?Does the machine beep and show an error code in lights?Please reply with additional information and I am sure I can help you rectify this fault.
Jul 20, 2010 | Fisher and Paykel GWL11 Top Load Washer
Radio problem, keeps beeping and saying code.
On the controls on the steering wheel hold the vol + & - for a couple of seconds and this should bring up the 0000 on screen and then its a case of spinning the wheel control on the side and holding + & - to set it.
May 21, 2009 | 2000 Renault 181
PC boots up, but no display and hard drive does not seem to spin
Actually you do want to hear one beep.
This is POST. Power On Self Test.
No display is a video problem. Swap the card for a known good video card. You should be able to get into the BIOS with that. Presario’s are quit.
While in the BIOS see if the HDD is shown. It doesn’t hurt to check the connection inside. Please keep yourself grounded when inside the PC. For the Compaq Presario S4020WM site go here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=us&dlc=en&product=326832&lang=en&
Dec 04, 2007 | Compaq Presario s4020wm (DK214AR#ABA) PC...
Samsung SpinPoint T133 HD400LJ 400 GB SATA II Hard Drive Logo
398 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
