Question about Kenmore Freezer 13.7 cu. ft. Upright Freezer
My freezer makes a loud squeaking noise but it is not constant. Sometimes it is very loud and three hours later the sound goes away and everything sounds normal. I would think if it were a burnt bearing in the fan motor the noise would be constant. The freezer maintains it cold temperature. The sound is best described as a fan belt slipping in a car's engine. Any ideas would be helpful
    President:
  • 670 Answers
It's probally the fan motor. Sometimes adding a drop or oil to the shaft will quiet down a noisy fan.
Posted on Mar 22, 2011
Freezer makes really loud noise
You need someone to check the fans and where the noise is coming from before the repair cost you a lot of money because of damage it can cause. The fan may be hitting ice in the freezer or out of balance because it is worn out. No one can hear what you hear and someone will need to be there to check these things out, Sea Breeze
Jun 10, 2013 | Frigidaire Freezers
Loud clanging noise from Kenmore upright freezer
Check the condenser fan (outside at the rear) and check the coil isn't baking hot. Electronics or board wouldn't cause your symptoms. Check the simple things first!
Jul 10, 2012 | Freezers
After loading freezer a loud buzzing sound started
Is it coming from inside the freezer or outside? If outside either the auto defrost timer is a problem. If the noise comes from the compressor, almost certainly the starter relay inside the electrical cover needs to be replaced. It can be purchased at most refrigeration outlets. If coming from inside, you need to defrost the freezer properly for 12 hours then restart. The noise should go away then.
Jun 12, 2011 | Whirlpool 19.6 cu. ft. Upright Freezer...
My Viking Freezer is three years old. The problem is the constant roaring sound it makes. No one can sit in my kitchen, family room or living room for very long before the noise from this freezer gets on...
There are several fans on your unit one on the top with the compressors, one inside the freezer, and one at the bottom. If you open the freezer and the noise gets louder or stops then you know it is the evaperater fan. Sometimes the bearings start to go and they make louder noise. Also check on the back wall for frost you could have a frosting problem and the fan blade is hitting on the ice
Oct 23, 2017 | Viking 15.9 cu. ft. Upright Freezer...
Whirlpool upright freezer evl209nbtq making noise
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Mar 04, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Sears Kenmore Upright freezer is Making a loud humming sound
change the rubber washers on the compressor should work a treat...
Feb 05, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Buzzing in a full freezer with icemaker model no. 253.44133802
try cleaning vents/drain holes in whole unit this should allow more air to flow.also when did you last manually defrost whole unit.....
Feb 03, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Loud buzzing noise doesnt stop freezer is still working everything still frozen, just loud noise coming from back bottom of freezer where the parts are, and compressor is very hot to the touch. freezer is...
Locate what is making the noise. There is a fan in the freezer behind the rear cover inside. There is a fan underneath accessed from the rear behind the cardboard backing. The compressor is also there with a starter/overload relay which could make the noise.
Aug 20, 2009 | Frigidaire 20.6 cu. ft. Upright Freezer...
My kenmore freezer is making a lous noise that
Is it still cooling ok - or is it going a bit weird ?
It could be the flow control solenoid - that affects where the gas goes - or the compresor motor (big black thing).
If it does not cool at all - it will need a new run capacitor on the compressor.
If it seems to cool ok - but sometimes too much - then suspect the solenoid coil / control for this.
Neither are that expensive.
Aug 07, 2009 | Freezers
Noise
When the freezer goes into defrost mode, some thumping/popping noises can sometimes be heard as the defrost heater melts the ice built up on the evaporator. Quite normal.
Nov 01, 2007 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Kenmore Freezer 13.7 cu. ft. Upright Freezer Logo
668 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
