Question about Xerox WorkCentre PE220
Hi,i have Xerox Pe220,i am not able to copy as paper comes out blank but i can print from computer,PLEASE HELP!.
  • 1 more comment
  • iffi_iau Mar 22, 2011
    i have changed cartridge but still not able to photocopy but when i print from computer it prints OK!??
    Thanks, i have changed cartridge but still same problem,i can print from computer,it's just i'm not able to photocopy!? any other suggestion please?
    Thanks, i have changed cartridge but still same problem,i can print from computer,it's just i'm not able to photocopy!? any other suggestion please??
    Genius:
  • 1,570 Answers
Hi
I believe the toner cartridge is the problem, try to replace new and it will works fine or bring back the old cartridge to check if it is working,
Post comments for more help.
Posted on Mar 22, 2011
  • Benjamin Jr Singson Mar 22, 2011
    Hi
    Try to update the printer driver and maybe it is corrupted. Here is the link http://howtodrivers.com/model41890.html.
    Or try to uninstall and reinstall the printer driver.
    If not, the imaging unit is the problem that needs replacement.
  • white
    white Oct 17, 2011
    If i were you i would relace the flexi cable leading to the exposure lamp then the exposure lamp. if its printing the problem has to be comming from at the top. is there power on your lamp? does it move? wat colour is it?
My workcenter PE220 Xerox is displaying scanner locked and it is not printing or copying. What do I do?
The manual says to unlock it. You will probably need the same password that you used to lock it.
Mar 23, 2011 | Xerox Phaser 3300mfpv/x Print Copy Scan...
Hi,i have Xerox Pe220,i am not able to copy as paper comes out blank but i can print from computer,i have replaced new cartridge but same result and put back the old cartridge,PLEASE HELP!!
Iffi,
Are you making copies on the glass or ADF? If you are getting blank copies using both the glass and ADF than your CIS(scanner) unit is bad.
Mar 22, 2011 | Xerox WorkCentre PE220
LSU error in XEROX workcentre pe220. What is the
R/sir,
I have a Fax machine of Xerox make model PE220.From BSNL line connectivity is allways out of order.I want to connect FIXED CELLUR TERMINAL (FCT).After conecting machine give dial tone for outgoing calls.and other end caller received a fax tone on their machine when they want to make a call on my machine.But printer is not printing after some LCD diplayed a massage communication error.Kindly GUIDE me for change in settings.
Thanks and regards
PK Jain
(Pennywise)
Dec 15, 2010 | Xerox WorkCentre PE220 Series
Blank page when I copy or print reports
Re check all the connections. When taking off the paper feed assay, other parts and plug and jack connections were needed to be taken off first.
Make sure the drum seats in its correct position, silver grounds are not bent.
The copy cartridge and Dev housing are not connecting very good somewhere.
Make sure the machine is unplugged.
Try running copies.
Apr 21, 2010 | Xerox WorkCentre Pro 580 Plain Paper Laser...
Xerox PE220 workcenter shows LSU Error message.
XEROX WORKCENTER PE220 , ITS SHOWING LSU ERROR . ITS NOT PRINTING OR COPYING ANYTHING . PLEASE GIVE SOLUTION
Dec 17, 2009 | Xerox Phaser 8500/DN Printer
Xerox DC12 printing black but copy works fine
Yor probles is caused for a pour conection from the fiery with the printer. Check disconecting and conecting again both conectors printer and scanner
Oct 26, 2009 | Xerox DocuColor 12 Printer
Xerox pe220 cannot copy
i have the same problem too with my pe220. fortunately, i just purchased a new one which i planned to give to it to a relative, and I was able to figure out that the cause of the "function impossible" displayed.
the problem just occured this morning and I have tried downloading and updating the firmware too, clearing the memories, etc but cannot get the copier to work (can't print thru the pc also).
i then borrowed the new toner cartridge of the new pe220 and installed on my old one and i was able to print and copy again. the problem then is due to the chip memory.
the problem now is how to reset the serial eeprom chip in order to reuse the toner cartridge again.
hope this helps.
Feb 24, 2009 | Xerox WorkCentre 220 All-In-One Laser...
HPF300 will not copy paper comes out blank when printing from computer and also blank when photocopying
My printer shows is out pf paper and is not.. did everything I could do and even though the paper is still there the printer doesn't print and keeps showing its status as is out of paper.
Could you help, please.
Best wishes
Oivia
Dec 01, 2008 | HP Office Equipment & Supplies
Computers & Internet Logo
125 people viewed this question
Top Xerox Computers & Internet Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
JC Meredith
JC Meredith
Mark Magill
Mark Magill
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
