Question about Daewoo WM1010CC Microwave Oven
Loose door handle, need to see diagram to see how to take apart to screw handle back on.
  • marktwentyma Mar 24, 2011
    This helped but the handle screws were not accessible on this model. After removing the plastic frame shown in your video, I had to pop off outer face, unfortunately I dropped it when it fell and the tempered glass broke, I think I will replace with regular glass otherwise the glass is so expensive that buying a new oven makes more sense. The handle is nice and tight once again though.
  • 4,924 Answers
Http://www.youtube.com/watch?v=nIdT4kS3noY
take a look on this video ..and it will worth a 1000 words...basically the screws are hidden under the inside cover of the door..and the cover is just snapped in and can be removed if you insert a blade in a point and take it inch by inch ...
Posted on Mar 22, 2011
The bottom of the door handle has broken loose. There doesn't appear to be screws on the inside of the door. Can I order a new handle and replace it (how do I take the door apart) - or am i going to need...
Go to RepairClinic.com. They have detailed exploded views of many appliances. This will show you how to replace the door handle or what you need to do..
Jan 16, 2011 | Microwave Ovens
Replacing door handle on microwave ge profile JVM2070BH02
You will need to access the door handle mounting screws and remove them to replace the door handle. To access these screws on MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. This can be easily be accomplished by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel and pry the plastic up. Work your way slowly around the perimiter of the glass to pop the panel loose. Use care not to pry against the glass. The glass is tempered and also has an RF shield that shields you from harmful microwaves.
With the inner panel removed, the door handle screws are visibile and can easily be accessed with a screwdriver. Simply remove the broken handle and install the new one. Re-insert the inner door panel, gradually working your way around the perimeter of the door glass to ensure it snaps back into place and seats properly.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. On some microwaves, you may have to remove the upper grill cover over the door (if equipped) to accommodate door removal. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
NOTE: Some doors have a hinge pin that needs to be removed, or screws holding the door in place at the hinge.
You can view an exploded view diagram of your microwave at pcappliancerepair.com for reference. Just type in your model number and locate the parts listing for the door. If you have any questions, or require additional assistance, please let me know. I hope this helps you.
Nov 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Door Handle snapped off
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In some cases, you then have to gently rotate the handle to unlock it.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Sep 09, 2009 | Maytag MMV5165 Microwave Oven
Door handle replacement
You remove door latch (nr 3 on diagram) first, then you unscrew the screw nr .8 and remove handle (nr.7).
Below the diagram:
Do not forget to rate the solution.
Thanks.
Feb 12, 2009 | KitchenAid KHMS155L Microwave Oven
Replacing door handle???????
gently pry the plastic from the inside working from the hinges to the corner. you will need to put something in place of the screwdriver when you pull it out to go to the next pry position (about every 2 inches. i use apex bits. you can use anything about the diameter of a cigarette. then the screws for the handle will be exposed . it all snaps back together.
Feb 18, 2008 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Khms155lss1
The handle can only be changed by separating the outer and inner shells of the door. You can pull the outer shell off the inner shell by removing the three screws at the end of the door and then using firm force to pull the shells apart. It helps to gently pry along the bottom, top and inside (nearest the hinges) with a thin flathead screwdriver or other very thin metal object. You don't have to get it all the way loose; just a little is fine. You can then use the two clasps on the back of the door (that hold it shut when it's closed) to pull with. I found that inserting a slim screwdriver into the lower clasp and using that as a handle (not a lever!) gives you a better grip. Hold the outer shell of the door with your left hand while pulling the inner shell in the opposite direction. Be carefull not to twist or bend the clasps; they are plastic and will break. The shells will pull apart and then you can access the screws that hold the handle. Change the handle then press the door shells back together. Make sure they are snug all around. Replace the three end screws and you're done.
Jan 08, 2008 | GE JVM1650 1000 Watts Microwave Oven
GE Spacemaker 1800 Handle Base Replacement
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Dec 06, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
The choke cover (or door gasket on your brand) will come out similar to the diagram shown below.
Then the hidden screws should be visible.
Also, you can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Oct 20, 2007 | Maytag MMV5156AAS Microwave Oven
Bottom screw on handle loose
All my micros had the screw go through the handle into the micro...no need to take door apart, just screw it back in. Why would you need to take the door apart?
Jun 12, 2007 | KitchenAid KHHS179LSS Convection /...
Daewoo WM1010CC Microwave Oven Logo
67 people viewed this question
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Ian Summerfield
Ian Summerfield
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
