Question about Honeywell Heat/Cool Thermostat
How do I wire just for heat on the non programable thermostat that has heat and cooling
    Genius:
  • 1,015 Answers
If you want heating only then wire to R and W on thermostat. Thanks
Posted on Mar 22, 2011
Tip
The Honeywell TH811U1003 thermostat is a universal programmable thermostat that...
The Honeywell TH811U1003 thermostat is a universal programmable thermostat that gives you electronic control of 24V AC heating and cooling systems. It also has the capability to be used on 750mV heating systems
One of the best features of this thermostat is it’s big clear backlit display. The current temperature, the set temperature and the time of day are displayed at all times. Simply touching the screen also activates the back light feature.
This thermostat has a menu programming guide the helps you through the process of setting up your schedule. You are able to select multiple days and customize the thermostat for any kind of unique schedule you may have. This thermostat also let’s you take it off the wall and still be able to program it. This lets you watch TV and program it at the same time.
There are built in backups that will hold the time for you if the power goes out. This t-stat will also update for daylight savings time. There are HOLD features that allow you to modify your program and hold it and then go back to the original.
Change reminders that are built in include the air filter, UV light, humidifier service and of course the batteries of the thermostat. The blower of you furnace can also be programmed to run extra to help increase the air quality in your home.
If you decide you want to know the outdoor temperature you can purchase an additional sensor and then hook it to you thermostat. The outdoor temperature will then be displayed on you thermostat. This feature also gives you the capability of using the sensor to monitor indoor temperatures remotely.
This thermostat will keep you very comfortable as the variation typically in temperature from set point is less than 1 degree F. The thermostat after a period of time learns the characterizes of the way the house or building heats and cools and then adjusts to get the most efficient operation of the heating or cooling system while maintaining a very close temperature tolerance.
By changing a few of the parameters in the thermostat this can be can be configured for either single stage conventional heat/cool systems or any single stage heat pump system.
Specifications of the Honeywell TH8110U1003 Thermostat
  • Description: VisionPRO Touchscreen 7-Day Programmable 1 Heat/1 Cool
  • Conventional and Heat Pump Thermostat
  • Application: Gas, Oil or Electric; Heat Pump; Millivolt
  • Programmability: Universal Programming from 7 Day to Non-Programmable
  • Changeover: Auto or Manual
  • Color: Premier White
  • User Interface: Touchscreen
  • Switch Positions (System): HEAT-OFF-COOL-AUTO
  • Switch Positions (Fan): AUTO-ON
  • Power Method: Battery or Hardwired
  • Terminal Designations: R, RC, C, W (O/B), Y, G, S1, S2
  • Dimensions (in.): 4 9/16 in. high x 6 in. wide x 1 1/4 in. deep
  • Mounting: Horizontal
  • Electrical Ratings: 20 to 30 Vac
  • Frequency: 60 Hz. 50 Hz
  • Setting Temperature Range (F): Heat: 40ª F to 90ª F. Cool: 50ª F to 99ª F
  • Setting Temperature Range (C): Heat: 4.5ª C to 32ª C. Cool: 10ª C to 37ª C
  • Differential Temperature (F): 1ª F
  • Differential Temperature (C): 0.5ª C
  • Stages: Up to 1 Heat/1 Cool
  • Outdoor Sensor: Yes, optional outdoor or indoor remote
  • Remote Sensor: Yes, optional outdoor or indoor remote
  • Sensor Element: Thermistor
  • Currents (Heating): 1.0 A running
  • Currents (Cooling): 1.0 A running
  • Currents (Fan): 0.6A running
  • Operating Humidity Range (% RH): 5 to 90% RH, non-condensing
  • Comments: Selectable to and Heat Only or Cool Only
  • Features: Screen lock
on Jan 15, 2010 | Hardware & Accessories
Tip
Th811u1003
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Specifications of the Honeywell TH8110U1003 Thermostat
on Jan 15, 2010 | Heating & Cooling
Removed my non programable Honeywell RT 5220D replaced it with a Honeywell RTH6350D to run my Goodman Heat Pump. First I labeled the wires then connected wires as follows: AUX, G, C, O/B (orange wire)...
Leave the factory jumper between R & RC. Connect the wires to the new stat just as you have them labeled. Use a piece of thermostat wire to make a jumper from AUX to E terminals. Your new thermostat should give you instructions on how to access the installer set up. You are going to set it up as heat pump with aux. I see this is 2 days old but if you need any help let me know.
Feb 13, 2011 | Honeywell Programmable Thermostat Heater
Installing 1 1/2 ton Weatherking Heatpump and ADP WAK351807P2 air handler 1 /1/2 with 7.5KW back up heat kit. Can't seem to get the thermostat hooked correctly. I understand the Weather King product...
O energizes the reversing valve when the thermostat is set for COOL. B energizes the reversing valve when the thermostat is set for HEAT.
The O/B is usually a orange or black wire.
You can't hurt anything if you choose O or B incorrectly. Hook one of them up and run the unit. If set for COOL and the unit runs cool inside it is correct. If set for COOL and the unit runs warm inside it is not correct.
If the inside temp is opposite from your setting change the wire to the other terminal.
Remember to disconnect power from the air handler when changing thermostat wires.
The defrost control board on the outside unit should be marked correctly for O or B.
Your thermostat may have a slide switch rather than a separate terminal.
Oct 30, 2009 | Weather King 10AJA6001AH Air Conditioner
A/C unit will not shut off
pls the connection of the thermostat is
C- COMMON
R- LINE
G - FAN
Y - COOL (compressr contactor)
W- HEAT ( heater contactor)
after you check the voltage 24 v between r and c slect cool then set thermostat at low temp the fan will start after the compressor will start
Apr 27, 2009 | Heating & Cooling
Wc wiring on thermostat
sounds like you have a heat pump the w2 on old thermostat is for a second stage heat. If you can give me a little more information on type of system you have (forced air furnace with heat/cool, Heat pump or boiler)? How many wires are on old thermostat? Is it a no programmable or programmable? How old is the furnace?
Jan 17, 2009 | Honeywell Programmable Thermostat Heater
I had an old thermostat that i had to change need wiring diagram
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
Dec 20, 2008 | Honeywell Electronic Programmable...
Honeywell Heat/Cool Thermostat Logo
51 people viewed this question
Top Honeywell Measuring Tools & Sensors Experts
Dan Webster
Dan Webster
Bill Long
richie46
Are you a Honeywell Measuring Tool and Sensor Expert? Answer questions, earn points and help others
