Question about True 72 cu. ft. / 2039 liter Commercial Freezer GDM-72F
MY TRUE GDM-72 FRIDGE ballast needs to be changed. Where is the ballast located?
3 Suggested Answers
  • 1262 Answers
SOURCE: GDM-49
http://www.truemfg.com/pdf/InstallManuals/GDM/gdm_english.pdf
Go to the above web site. It should be the installation manual for your unit. It has lots of good stuff.
Hope this helps
Posted on Nov 20, 2009
  • 1262 Answers
SOURCE: My GDM-72F Freezer lamps holder burned out and I
yes, the ballast must match the bulbs. no other way to make it work correctly
Posted on Aug 21, 2010
Why gdm 72f cap tubes
That freezer is meant to have a stable load an example is storage. A supermarket application would require a tx valve.
Apr 28, 2014 | True 72 cu. ft. / 2039 liter Commercial...
How to put hardstart kit in compressor GDM-72
depends if it is only a two wire hard start.. then wire it parelel with the run capacitor . place line to line and load to load . load goes to compressor and line to power which is usualy realy the neutral for a 120v compressor since the hot runs to a overload and straight to the compressor
Sep 13, 2013 | True 72 cu. ft. / 2039 liter Commercial...
Where are the Freon nodules for a True GDM-72 cooler?
SEALED SYSTEM REPLACING COMPRESSOR ON COMMERCIAL FREEZER
Aug 08, 2013 | True 72 cu. ft. / 2039 liter Commercial...
What cause problem making noise during start-up?
could be a dirty condenser coil check it and clean it. make sure the condenser fan is working too. located on the bottom.
Dec 26, 2012 | True 72 cu. ft. / 2039 liter Commercial...
True gdm 72 goes below 20 degrees
Usually a blocked condenser fooling the thermostat into running overtime. Possibly thermostat fault but less likely
Apr 14, 2012 | True 72 cu. ft. / 2039 liter Commercial...
True GDM-72f freezer Fans don't start
Thermo fuse has failed on the core plate, tells the freezer its cold enough to start blowing air, you can bypass it but not recommended. hope that helps, Russ
Jun 11, 2011 | True 72 cu. ft. / 2039 liter Commercial...
My true cooler freezer in side fans dont turn on i run it for 15 min. the make is gdm-72f
first place to look is in the evap where the defrost/ fan delay is located. It is usually attached to the "U" tube on the evap and senses the temp. It prevents circulating warm are after a defrost. It could be bad and keeping the fans from running. Start there and let me know if I can be of further help
Jan 27, 2011 | True 72 cu. ft. / 2039 liter Commercial...
To cold its freezing drinks
You need a cold control. (easy to change)
Its where you turn it colder or warmer.
Go here
www.marcone.com
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Sep 04, 2010 | True 72 cu. ft. / 2039 liter Commercial...
GDM-49
Hope this helps
Nov 13, 2009 | True 49 cu. ft. / 1388 liter Commercial...
True 72 cu. ft. / 2039 liter Commercial Freezer GDM-72F Logo
257 people viewed this question
Top True Freezers Experts
Dennis Boxerman
John Tripp
John Tripp
christian nielsen
Are you a True Freezer Expert? Answer questions, earn points and help others
