Carrier heat pump wiring diaghram to replace capacitor and fan
The wiring diagham is missing on unit capacitor and fan were removed and tested ,capacitor was the problem with unit.the fan is a four wire unit,capacitor has 2 poles.ser. # is z349805 mod.#is worn off .I am able to wire anything if i have diaghram,and have been trying to find one for two weeks.any help would be good.
koolbreezes
  • 540 Answers
SOURCE: ac heat carrier thermastat model no.hh01ad042
GOto the iside unit itself. and remove the door and look for a terminial strip that the thermostat wires from the thermostat connects to and write down the colors wires and the letters they're connected to and connect the same to the thermostat .... they should be... r--red=power w-white=heat y--yellow=cool g-- green=fan! See which wires/ colors they're not using and bend back! Thank-you-very-much!
Posted on Sep 01, 2008
  • 659 Answers
SOURCE: I have a bard heat pump central air in my house
http://www.bardhvac.com/digcat/S3364_TechDoc_CD/QH60/QH60.pdf
I hope this is the correct wiring diagram for you. Good luck with it!
Posted on Mar 21, 2009
  • 116 Answers
SOURCE: My ac fan went out on a carrier ac unit. Need wiring help
use a seperate capicitor for the fan only pick up 1 leg of power from common side of the compressor cap and the other from the contactor or the board in a heat pump situation
Posted on May 11, 2009
  • 127 Answers
SOURCE: REPPLACING FAN AND COMPRESSOR CAPACITORS WITH A SINGLE UNIT
Well, it sounds as if you have a Coleman rooftop unit. If you have a start capacitor with a PTCR (Postive Temperature Coefficient Resistor) then it is different than if you have a Potential Motor Starting Relay. Why are you replacing the run and the fan capacitor?
Here is a link to the documentation that you need. If you do not have a Coleman and it is in fact a Duo-Therm, let me know the model number and I will be able to pull up the wiring schematic.
Thanks,
Jeff
Rate this please!!
Posted on Jul 04, 2009
  • 207 Answers
SOURCE: I need a wiring diagram for my carrier heat pump
call ur carrier supply house near u they will be able to help u unless they r too lazt to help but they have access to all that someplace like whittichen supply or totaline or weathertech
Posted on Feb 26, 2010
My(38ycc030340)carrier heat Pump ac unit blows 5 amp fuse on board in handler in attic when switch stat to heat.
Miss wired or shorted low voltage wiring. Have you changed stat? Animal chewed wires at foundation wall or in attic?
Oct 10, 2016 | Carrier Heating & Cooling
What size capacitor in a Carrier Heat Pump 38yh036300
This is a three ton heatpump must likely it is a 35/5uf capacitor. But if you can read compressor tag it will tell you size it requires and also fan label will do some for it.you will need to ask for a dual capacitor from supply house make sure you pay close attention to hoe wires hook up so you can wire in new on before removing wires make sure you have high voltage turned off to unit.take pic with phone this will help when you rewire
Mar 10, 2015 | Carrier 52CQ-312-4 Comfort Series Heat...
Condenser fan on heat pump does not turn off
If it is just the condenser fan that means you have a fan relay that has welded shut. Turn power off to your unit and trace the wires from your condenser fan back into the control panel at the unit. You'll have 3 wires going to it. 2 go to the run capacitor and one goes to the fan relay. The one that goes to the fan relay is the part that needs to be replaced. If you have no fan relay and it goes to the main contractor, half of your main contractor is welded shut and will need to be replaced.
Sep 18, 2014 | Carrier 52PQ-515---3 Premier Series Heat...
Replace compacitor on Carrier 5 ton 3 phase AC
Your 3 phase unit should not have a capacitor. I'm guessing it's single phase. If it's a single capacitor than the compressor should not be going to it also. To test the motor, common to start plus common to run should equal the ohms you get between start and run. For instance, 1.2 ohms+ 2.2 ohms= 3.4 ohms. Follow the wiring diagram on the inside of the door, send model number!!
Aug 29, 2017 | Carrier Heating & Cooling
Connecting replacement fan motor in HP condenser
What is the model number of the heat pump? What is the voltage that you are dealing with?
Nov 26, 2013 | Carrier Heating & Cooling
My fan motor on a carrier 38ycc024310 has been changed two times should i replace the heat pump or is there an electrical problem
Most Carrier units use smaller horsepower motors with less rpm.
If a universal motor was used that may be your problem.
Check the specs listed on the unit and replace with the correct motor.
Also replace the capacitor.
Dec 18, 2010 | Carrier 38CKC042 Air Conditioner
Fan motor runs backwards
Make sure the capacitor is connected to the start lead, not the run lead(s). Also some fans come with some wires you can switch to reverse the direction. If your motor has them there will be 4 and the label on the motor will tell you how to connect them. Let me know if you need more assistance or if this helps.
Jun 02, 2010 | Carrier 38CKC042 Air Conditioner
May 11, 2009 | Carrier 38CKC036 Air Conditioner
I have a carrier hotel heat and air wall unit, model #52sec312301 aa, date of mfg 2/28/97. installed and unit ran for 5hrs, when the fan motor quit (it only hums). I need information on how to repair if...
Chances are the capacitor is bad. Lets hope anyway right behind the control section is the capacitor it will be a dual one it runs the compressor and fan. First turn the breaker off for unit. access the capacitor make note of the wiring this is where it gets real difficult so many wires in a little space. make labels out of tape it you need to there are two sides to capacitor the fan should only have one wire going to fan side. remove the capacitor you can test the capacitor if you have volt ohm meter. Put in ohm's and check resistance on the fan side. If the meter goes up then down capacitor good. If it runs up and down reverse the leads from the ohm meter and repeat runs up and down. If that checks bad replace the capacitor. but other wise the Fan motor is bad and they are tuff to replace. Can be done but you have to undo the inner part from the outer shell and pulling the whole inside out. You will need long Allen wrenches. Have to remove alot of housing items. let me know what you check on capacitor. ken
Dec 07, 2008 | Heating & Cooling
Compressor not doing much
I am assuming that you are talking about a central ac unit. On a central air unit the outside fan must be running whenever the compressor is. If it's not the compressor will shut off from overheating withing minutes. First you need to shut off the unit for several hours and let it cool completely down. Then turn it on briefly to see if the compressor starts and see if the fan tries to start.( I am assuming the compressor starts and runs.) If the fan won't start try testing the capacitors. There are usually two one for the fan one for the compressor. Sometimes there will be one combo one. Mark the wires and remove the capacitor. Get it tested and if bad replace it. This will probably do the job. If not test for current at the fan motor. Also test to see if it turns freely. The motor may need to be replaced. This will run about $50. The capacitor should always be replaced when the motor is changed anyway.
Jul 09, 2008 | Carrier 38BRC060 Air Conditioner
Heating & Cooling Logo
829 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
