Question about Behringer XENYX 2442FX Mixer
Noisy headphone amp in ub2442fx - Behringer XENYX 2442FX Mixer
  • Behringer Master
  • 5,603 Answers
Download schematic here:
http://elektrotanya.com/behringer_ub2442fx-pro_sm.pdf/download.html
Scroll down to the small "Get Manual" link and click on it.
The headphone amp is on sheet 13.
Posted on Mar 22, 2011
Pdf manual by ub2442fx-pro
You can download from here... http://www.behringer.com/EN/Products/UB2442FX-PRO.aspx
Sep 30, 2014 | Behringer EURORACK UB2442FX PRO Mixer
I need a new fx push knob for eurorack ub2442fx pro
This place has a great selection of Behringer parts. You should be able to find your knob here: http://www.dbmproaudio.com/behrparts.html
Jan 10, 2013 | Behringer EURORACK UB2442FX PRO Mixer
My EURORACK UB2442FX-PRO has audio coming in but nothing coming out...
The outputs of these mixer needs to be connected to an active speaker.
An active speaker have an amplifier and a preamplifier.
Oct 02, 2012 | Behringer EURORACK UB2442FX PRO Mixer
Behringer Eurorack UB2442FX - PRO mic inputs are intermittent
Check the type of microphones connected and set the proper settings,
and connect it to other mic inputs .
May 21, 2012 | Behringer EURORACK UB2442FX PRO Mixer
Yamaha CP 300 broken headphone jack
Some keyboards use the amp output sockets for headphone use.
You might need some adapters for your headphones.
If it fell in, you would see an empty hole. This would be unlikely because it is held on by two screws. If all fails, buy an amp with a headphone jack input. Plug the keyboard into the amp and use the amps jack.
Dec 15, 2011 | Yamaha CP300 Stage Digital Piano...
Getting distorted sound when connecting from mac pc headphone jack to 1/4" line in input
You are connecting a NOISY unbalnced line to a balanced input. Buy a DI box and then use an XLR to XLR to the mixer inout and run the MAC into the DI with "ground lifted". You will need to make a resistive mixer between the headphone jack and the DI as well. The headphone jack is STEREO. You COULD try a STEREO 1/8 inch splitter to 1/4 inch left and right cable... you MIGHT get away with that. Right now the left and right amps in the MAC are fighting eachother.
Sep 25, 2011 | Samson New Samson Mdr-1064 10 Channel...
Only the left channel on the whole board works. Is there some part that might be replaced to fix the right channel?
First analysis needs to be done to isolate what can be discovwered before opening the unit. Does the sound appear in BOTH sides of the headphones? There are MANY components that can kill the right side including cracked circuit board. Beyond a certain point one would use an oscilloscope to troubleshoot.
Jul 20, 2011 | Behringer EURORACK UB2442FX PRO Mixer
I'm looking for a solution how can i connect my
You can use the compressor in two ways. 1st you can go inline from the main outputs into the compressor out of the compressor to the rest of the world using normal cables. You may also insert the compressor into the main inserts using a cable that is tip, ring, sleeve 1/4", to seperate 1/4" tip sleeve mono plugs. any more questions give us a call at the store 215-736-8055
Jun 10, 2011 | Behringer EURORACK UB2442FX PRO Mixer
When i have my FX on and sending to main they make a horrible clicking (shorting out) sound. if I push the main mix button it shuts off the effects and the noise goes away...bad side...then I have no...
Check the 5 volts to the FX unit, If the voltage is low, the FX processor will keep reseting generating clicks, In a different product, the 5 volt filter cap was degraded and voltage dipped down to 4.5 volts causing resets.
May 31, 2011 | Behringer EURORACK UB2442FX PRO Mixer
Will a Behringer UB2442fx-PRO run 2 main PA speakers plus two passive stage monitors without blowing up?
ALL the speakers will either have to be POWERED or have external amplifiers. The mixer has NO power amps capable of driving speakers. When connecting, make sure that the mixer is powered by the same receptacle as the speakers or amps. Used balanced line for interconnection.
Jan 24, 2011 | Behringer Music
Behringer XENYX 2442FX Mixer Logo
193 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
